Presented by Nine Lives Racing
stafford1500
stafford1500 GRM+ Memberand HalfDork
11/2/18 2:54 p.m.
Spoilers and wings both add drag and downforce. They make the air do things it does not really want to do and that work equates to drag.
There is less drag increase with a wing compared to a spolier for the same amount of downforce, due to how the devices make the downforce.
The case of F1 cars is a trade-off of straight away speed Vs cornering speed. They simulate everything to figure out what the best trade-of is going to be fo reach track. This is the case for any/every professional series. The level of simulation is the main difference.
Robbie
Robbie GRM+ Memberand UltimaDork
11/2/18 3:06 p.m.
what about the front 'scoops' (I don't know the technical term)? For example on the gt40 air comes through the grill and out the hood in large quantities. Does that create much down force? Seems like it would.
I know there is a radiator in there usually heating up the air, but still.
z31maniac
z31maniac MegaDork
11/2/18 3:14 p.m.
I guess I'm thinking of the long, low-angle spoilers lower powered cars tend to use on road courses to reduce drag versus trying to add downforce, compared to AutoX classes where the spoiler is nearly straight up like an air brake to add downforce in classes where airfoils are prohibited.
sleepyhead
sleepyhead GRM+ Memberand Dork
11/2/18 3:28 p.m.
it all depends on the car and the implementation
wings will almost universally add drag, just because of the struts and the wing shape, plus what ever drag due to circulation that the wing is creating ("making the air due what it doesn't want to do")
There are some limited scenarios where a spoiler will reduce drag (even one sticking straight up, albeit fairly small in height) because it's moving the stagnation point and increasing the circulation, which is causing flow that was detached from the rear window to now attach to the rear window.
although, that observation was on cars from the 70's.  Then again, we've started to see similar with the small "add on" strips added to the top trunks of hybrid models.
One of my favorite professors always responded to design questions of "should we do that?"  with:  "well, you certainly could... whether you do or not is up to you.  It's your design, after all."
stafford1500
11/2/18 3:52 p.m.
There are more effective ways to reduce drag than extend the length of the car with a decklid extension. Such an extension is still likely to make downforce based on the pressures above and below.
For Robbie: The top exit radiator does generally make downforce, but mostly front downforce. It also provides a more 'simple' design to take care of engine heat without having to model the entire underbody.
SleepyHead is right that a lot of modern cars are getting widgets added to control airflow. Most (but not all) are directed at keeping the wind noise in the cabin to a minimum. Some are for flow conditioning around the rear of the car to reduce drag. Both of those are high on the list of making new cars better for the general customer base.
One of my professors was often noted for saying "It Depends!" to nearly any question about how/why to do anything.
Snrub
Snrub HalfDork
11/2/18 4:30 p.m.
Dusterbd13 said:
This thread gas sent me back down the rabbit hole of research of miata aero for the challenge car.....
This doesn't apply as much to a G35 that you may want to look half decent, but the easy stuff is:
Cut vents in the hood - see FM pressure picture/diagram. I cut slits in the hood, hammered underneath against a metal tube against the hood to get aero efficient flares. Cut down the rear bumper, etc. Run a roof of some description, or DIY. Tuck the fender at the rear of the front tires. Create a "crusher" style front air dam (google) with wood splitter. A successful V6 MR2 team in Champcar DIYed their rear wing. DIY a diffuser.
Robbie
11/2/18 6:19 p.m.
This guy has made some pretty cool YouTube videos on vehicle aerodynamics.
https://youtu.be/quDLzxmJl5I
aDwzT6wN7bNvfq5vZfLlWiAYeublNFpM6ChmaCI7X1hXctZX3VNTSgnl66vzFXDP
