I have noticed my LS swapped S10 generates a ton more underhood heat than it did when it just had a 305 SBC (big surprise). The radiator and fan are keeping up with cooling the engine in its stock form, but I am worried a bit, both for when I add more power, and more so for cooking wiring, plastics, etc underhood much faster than they would be otherwise.
A quick view of how it is stock:
The airdam is attached to the leading edge of the bumper:
View under the bumper. The large round objects are the mounts for the core support, and the radiator is inset into it, so it sits back from the airdam, obviously.
From the various pieces of plastic attempting to redirect or block airflow, I think GM didn't really try to create much of a low pressure zone behind the radiator, they just tried to keep turbulence from preventing air flowing through it:
I can't remember if this foam was stock, or if it was on the 3rd gen F-body I used as a donor for the 305.
I am wondering if a second airdam below the core support would lower the air pressure in the engine compartment to the point that it could extract a bit more hot air to the underside of the car while I am driving. Something like this:
I'm not really in a position to do a bunch of detailed analysis. I suppose I could see if my gopro knockoff still works, rig something up, and tape some tissue paper strips under there, but I wanted to see if this idea is sound or not at all. If so, would it also make sense to create a horizontal surface from the front of the stock airdam to the new airdam? I'm wondering if there would be some weird effects from air getting trapped between the two if I don't. Would it also make sense for the new airdam to be lower than the stock one? I don't want to go too low, so I can still get a jack under it easily.
Is this whole idea stupid, and I should consider coming up with some hood vents (would rather not due to rain) or some vents on the fenders to extract heat?
