1 2 3 4
a_florida_man
a_florida_man Dork
12/31/24 1:15 p.m.
So, as to the OTHER subject in this thread... HRPT.
Who has done it?
At first I enjoyed the concept, but as I dig into the particulars and the logistics.... it seems like the crowds, lines, and traffic might get old kinda quick no matter what level you buy in at.
We are considering our own agenda and cross country road trip plan that would be a little less peoplely.
Thoughts? Suggestions? Comments?
wawazat
wawazat SuperDork
12/31/24 3:09 p.m.
I did the HRPT with my Dad in 2019 and we had a great time.  I'd recommend it.  My Cougar wasn't ready so we took Plan B, aka my Yukon.  2200 miles for us-MI to NC then bouncing around the Carolinas, KY, TN, IN, and OH then home.  Saw a bunch of great cars and met a bunch of people enjoying them.  I'd do it again for sure though Dad is now too old and frail.
Lines weren't too bad.  The daily drives were great-rolling car shows with spectators in many areas.
a_florida_man
a_florida_man Dork
12/31/24 6:00 p.m.
In reply to wawazat :
Thanks!
Did you do the full event?
wawazat
wawazat SuperDork
1/1/25 4:19 p.m.
Yes we did-Long Haulers!  10 hour run to Charlotte from Detroit then ran around the southeast ending up at Norwalk, Ohio so a short drive back home.  We really enjoyed ourselves.  I've got all the swag from the event on a piece of plexiglass in my garage.
a_florida_man
a_florida_man Dork
1/1/25 6:56 p.m.
2024 Had one more lesson in mind for me.
Cam bearings.
I've installed many many sets of them, and I've never had an issue.
This time... no bueno... the cam would NOT turn by hand.
At first I thought it was me. So I had another set in stock (lol that is hoarder speak that one uses to justify a mountain of NOS auto parts with having a $40 set of bearings laying around.) I knocked out the first set and carefully installed the second set.
No improvement.
Both attempts had set the same pattern in the bearings. #3 and #5 were the biggest offenders.
Hmmmm... where are the old bearings that had last run in this engine.....?
You see, I bought this engine disassembled, so while I had knocked out the cam bearings that it last ran with, I had not pulled the cam.
Looking at the old ones, they looked to have been HEAVILY honed or sanded. Ughhh.
This is starting to make sense. The rods and mains show advanced wear as compared to the age of the engine and the wear on the pistons and bores. If someone had opened up the cam bearing clearance... well that could account for the rods and mains.
But what to do about it all now?
To the internet....
Folks discussed all kinds of hand sanding and honing. I even found cam bearing sized dingle ball hones.
Yikes? Right? Not what Id like to imagine doing.
Then I found a machinist that had a novel (to me) suggestion.
Take an old cam and cut 45 degree slots in the journals, deburr and use it essentially as a reamer.
Guess what?
It worked like a charm.
I would also add, for this step, clean off assembly lube, and use cutting oil.
Rotate the cam 5 or 10 times, slide it forward where the journals pop out of the bearings, clean the cutting groves, slide it back and repeat until the cam turns easily and  smoothly .
The bearings don't look like OEM any more, but they are smooth like butter.
In my mind I can imagine honing and sanding leaving behind grit and also removing a lot of material that did not need to go. the reaming seemed to just cut a smooth bore and that was all.
With that behind me, I've been checking for correct and compatible parts for the whole build before finalizing the engine assembly.
2025 has been a lot smoother so far. :)
a_florida_man
a_florida_man Dork
1/3/25 7:35 a.m.
It's a shame to cover all of this up with an oil pan.
Oh well...
a_florida_man
a_florida_man Dork
1/3/25 7:40 a.m.
Swirl port "193" heads. Universally hated?
Low end torque and fuel economy are goals here so meh...
Besides these are in perfect condition.
I do have to admit it was a significant departure from the normal sbc head for gm.
a_florida_man
a_florida_man Dork
1/3/25 7:43 a.m.
This was a cool find.
The only original 1957 engine part on the car.
Braided line for the oil pressure gage.
a_florida_man
a_florida_man Dork
1/3/25 7:47 a.m.
A little more advanced mock up.
Since I'm building this from scratch everything has to be mocked up for compatibility and to identify missing hardware (50% or more is missing or wrong).
Intake bolt length is key, too long and some can hit the pushrods.
maschinenbau
maschinenbau GRM+ Memberand PowerDork
1/3/25 8:37 a.m.
In reply to a_florida_man :
Nice trick with the cam bearings. I've heard that is common practice for Mopar hemi stuff too.
a_florida_man
a_florida_man Dork
1/3/25 10:19 a.m.
In reply to maschinenbau :
Yep, in researching this solution I came across a LOT of Mopar issues with many engines.
a_florida_man
a_florida_man Dork
1/3/25 7:05 p.m.
Things are getting serious...
a_florida_man
a_florida_man Dork
1/4/25 1:44 p.m.
Rebuilt the transmission.
After the Krylon overhaul, I did install new seals..... and the TC is a reman DACCO. The fluid is bright red and SLIGHTLY used so Im hoping for good things...
a_florida_man
a_florida_man Dork
1/5/25 3:03 a.m.
I am running out of excuses. Sunday should be the day!
a_florida_man
a_florida_man Dork
1/5/25 11:23 p.m.
So today was productive... but I didn't get it driving quite yet.
The day started with two transmission pan bolts breaking off. A few hours were spent drilling out the steel bolts from the aluminum case and helicoiling them. Replaced the exhaust manifold flange studs, fitted some v belts by trial and error , etc etc nickel and dime stuff all day.... BUT it is in there!!
The engine mounts in here were not done very well... but before I "fixed" them I thought I'd see if they were located well or if they.needed to be rebuilt AND moved.
There isn't as much room as you might think !
a_florida_man
a_florida_man Dork
1/9/25 8:17 p.m.
She has a pulse!!
Other signs of life...
Not a driver yet BUT the transmission spins the wheels on the Jack stands and the brake pedal does not fall to the floor!
Dusterbd13
Dusterbd13 MegaDork
1/9/25 8:43 p.m.
Fantastic!!
a_florida_man
a_florida_man Dork
1/9/25 9:01 p.m.
In reply to Dusterbd13 :
Thanks bud! Only one leak because I forgot to tighten an oil line.
Runs smooth.
199ish GM replacement crate engine , originally  most lkelly a replacement for a L05 TBI. Built with with factory flatops (no dish  like most L05s), and a factory roller cam, possibly a 9c1 Caprice engine or a HD truck engine?
Anyway, now its got a small summit 8800 roller cam:;
(Hyd. Roller Cam, 204/214 Dur., 112 LSA + 1 Adv, .450/.450 1.5 Ratio, .480/.480 1.6 Ratio, Idle-5800 Range)
,a mechanical fuel pump, and a small cap pertronix converted  GM distributor and its topped off with an 1850 Holley.
Super simple, super cheap, super reliable.
The engine itself was old (GM engine tech center said 2001 or 2011 by the stamping) but super low miles. Heads are swirl port, but MINT condition. since gas mileage and low end torque sounded good, I kept them.
The heads and the engine block were spotless, but the rod and main bearings were wiped out. Additionally someone other than GM had replaced the oil pump. When they did, they cut up one of the oil pan renfrcement rails and welded it to the oil pump body and pickup tube. Weird. I built the engine with new rings (one was missing), new bearings and a melling HV pump. I also noticed that the oil filter bypass valve was stuck open. Maybe that was the cause of the bearing issues? The old one used a fiber check valve so I replaced it with a Melling MFA350.
It has a metal valve.
I kept the OEM single roller cam timing set as it was BEEFY, and like everything else in nice shape.
a_florida_man
a_florida_man Dork
1/9/25 9:06 p.m.
I'm anxious to drive it because I know nothing about the transmission out side of my new seals, TC, filter kit and spray can rebuild.
wawazat
wawazat SuperDork
1/9/25 10:24 p.m.
Yes!  I saw spinny bits in the pics above!!!
a_florida_man
a_florida_man Dork
1/11/25 7:19 p.m.
Maiden voyage!
Nice to know all 3 gears work... lol.
More power than I expected... but maybe that's because up untill now ive been pushing it. :)
Did chirp the tires with little effort.
May be an image of car and text
a_florida_man
a_florida_man Dork
1/11/25 7:21 p.m.
May be an image of text
1/11/25 7:26 p.m.
Good stuff, man!
a_florida_man
a_florida_man Dork
1/11/25 7:27 p.m.
Good stuff, man!
Thanks!
vwcorvette (Forum Supporter)
vwcorvette (Forum Supporter) GRM+ Memberand PowerDork
1/11/25 9:24 p.m.
Awe. Some.
1 2 3 4
v80MnnjCSqwKdhbj0MRGBNiwUjRanjwvyZDRazdlj31ZTNt0hvrYns2EyP9wtK9Q
