1 ... 12 13 14 15 16 ... 26
759NRNG
759NRNG UltraDork
3/28/20 6:51 p.m.
Nuttin' better than Db13 thrashin' the "D" while in self cv19qteen  I say.....hey where's my SPB Crowd Control??
Dusterbd13-michael
Dusterbd13-michael MegaDork
3/28/20 7:04 p.m.
In reply to 759NRNG :
Hopefully it will make noise for you tomorrow!
I really want to drive this now. Nobody on the roads and great weather
759NRNG
759NRNG UltraDork
3/28/20 9:03 p.m.
Especially NOBODY onthe roads......careful bro!!!!
Dusterbd13-michael
3/29/20 1:31 p.m.
Not going to make noise today. But, closer!
Had to take care of some family stuff.
Hopefully this week sometime.
Dusterbd13-michael
3/29/20 6:51 p.m.
Also:
The kenwood ez500 i purchased in 2002 for this car died. Well, mostly dead. Regardless, no longer really operable. I just ordered a new head unit from crutchfield. Also pulled out the onld single channle punch amp that leys 500 wats at 2 ohms. We'll see if the old jl 12 dies....
Dusterbd13-michael
3/30/20 8:42 a.m.
I picked up a bypass regulator from ebay. We had used one on the amc challenge car to step down from an efi system to a carb. I figured it worked then, it works now.
And it was 35 bucks. Just took it apart, cleaned all the aluminum chips out, and modified the bypass poert by stepping up two drill bit sizes on ghe oriface. Figured that would give me finer control of the amount of pressure reduction. I didn't take pictures.
Wound up at a 3/16 oriface for reduction of fuel pressure.  Now, its actually adjustable from zero to 10psi. Instead of 15psi minimum.
Dusterbd13-michael
3/30/20 9:31 a.m.
using E36 M3box as a workbench to polish valve covers while on the phone for work.
Theyre coming out good enough for me. Not show quality, but neither is the car.
AngryCorvair
3/30/20 9:33 a.m.
False.
Dusterbd13-michael
3/30/20 10:14 a.m.
False.
It photographs well.
And is probably nicer than i think. Im the guy that sees every single flaw in whatever i build.
SkinnyG
SkinnyG UltraDork
3/30/20 11:08 a.m.
You need to just look at pictures, not the actual car.  You won't see the defects if you look at the pictures.
Dusterbd13-michael
3/30/20 12:01 p.m.
Good idea skinnyg!
Just shipped the efi. That was $90!!!!
Dusterbd13-michael
3/30/20 3:42 p.m.
its alive!!!
Not drivable yet, but alive. And idles better out of the box than the megasquirt did.
wawazat
wawazat HalfDork
3/30/20 3:44 p.m.
Well done!  Looking forward to drive reports.
759NRNG
759NRNG UltraDork
3/30/20 4:02 p.m.
its alive!!!
Why was I thinking all Mopar V8's had the dist up front?
Daylan C
Daylan C PowerDork
3/30/20 4:03 p.m.
Big blocks have them up front at an angle. LA and Magnum small blocks have them at the rear.
Dusterbd13-michael
3/30/20 4:07 p.m.
Daylan is correct.
I think all fords are up front though.
wawazat
wawazat HalfDork
3/30/20 4:09 p.m.
Yup small block and big block Ford use front mounted distributors
759NRNG
759NRNG UltraDork
3/30/20 4:36 p.m.
Well waddya know I learnt sumpim today........bonus thanks  DC
TVR Scott
TVR Scott GRM+ Memberand Dork
3/30/20 4:50 p.m.
I'm the same way.  I can hold my own flaws in my heart forever.
My daughter is similar - she made me a cake for my birthday the other day, and she got totally stressed-out about her frosting and decorating job.  It looked great.
Dusterbd13-michael
3/30/20 5:05 p.m.
Im really excited. I have to tidy up some wiring, check rev limiter settings, and chase some dash issues as well as the head unit swap. Fill cooling system, and see what its like when it gets up to temp.
But fires right up and holds idle. Done. Finished. Happy. Even has good response blipping the throttle.
Floats are adjusted, fuel pressure set. Fast idle set.
Close. Very, very, very close. But time to quit for the night.
SkinnyG
SkinnyG UltraDork
3/30/20 5:52 p.m.
Smoke Show!
Smoke Show!
Smoke Show!
AngryCorvair
3/30/20 6:10 p.m.
Rev limiter?  You mean valve float?
Professor_Brap
Professor_Brap SuperDork
3/30/20 6:22 p.m.
Valve float is the limiter on my carbie car.
Daylan C
Daylan C PowerDork
3/30/20 6:25 p.m.
Vavle float was the limiter on one of my TBI cars. Maybe I was doing it wrong.
Dusterbd13-michael
3/30/20 6:26 p.m.
I've never taken this engine higher than 6500. And its still making power there.
Figure that's high enough for a street small block......
RZ59KrrrGiwUybXwXA5dDdHh44VHINTMsjaJV9cUkwxkNw5UUh1WEDCTcjLFaeGa
