Ok, so here's the rest of the last event recap...
A few of our MR regulars were missing this time, due to schedule conflicts or other reasons. Nonetheless, four of the top five points cars in the class were present (minus Josh Sennet in his turbo ETA), so while we're used to bigger MR classes here, the main competition was still present.
The first big improvement was the weather. 70s with "light" wind (at this venue, that means under 20mph). So that made everyone's morning much more pleasant than last month's arctic blast-fest....
The morning course we worked first and ran second, letting the entire field of AWD cars tear up the course, adding large ruts and bumps. The new venue is a lot of fun with a ton of space, but the deep gravel and substrate is going to take some time to compact down so it holds up better. Rome wasn't built overnight, and neither is a fresh rallycross venue in this case.
So on to our runs. The course was rough. Brutal rough, indeed. I can honestly say that this is the first time I've rallycrossed where I was quite certain that there was going to be a major suspension component damage (LCA, shock tower, or something). Spent lots of time on the bump stops, and took a lot of hard hits on the skid. In one area there were some less-prepped cars getting a big bounce into the air (the course was corrected soon thereafter). And there were a few places where the wrong line could very well lead to a debead, though I don't think anyone did.
From the start Nick was neck and neck with me in his e28, which he's added a few new things to and subtracted some more weight from. We went back and forth for the lead all morning, with me taking a 3-4 second lead into the lunch break ultimately (5 runs). I only got one cone all morning by some minor miracle (my video shows a ton of very near misses that were closer than planned). Nick had one or two also.
Chris in "the Beast-stang" once again had his hands full. The course had a lot of fast sections that entered into some very loose sections, especially if you went wide. For the smaller cars we managed to keep it fairly tidy (though I spent some time in the deep stuff myself)
Chris was having control issues though. Three cones on his first run and a whopping seven cones on his second. AFter that he laid down a couple fairly clean (+1 cone) runs with fast times and looked like he might be getting a handle on the car and the course (also had the fastest single raw time run of the day for RWD classes). On his last run of the day I'm not sure what happened but after a pretty dirty run he came sideways through the finish and punted about half of the finish box side cones, for a +8 on that run. Overall, he was running slightly faster times than Nick and I, but had 20 cones after the morning session (compared to 1 for me, 3 for Nick, and 1 for Eric in the ETA), so he was pretty much out of it by then.
I spent my last two runs with a rock in my brake dust shield, deafening everyone on course with high-pitched screeching for two runs (and annoying myself into a couple distracted sloppy runs).
In the afternoon, the course setup was better, going through a lot of "shrubbery" areas that were a bit more firm, but still with some deep, loose areas. I really enjoyed the PM course and it lent itself well to getting a good rhythm and dancing the car through the transitions. But Nick had the rhythm too and beat me on all of the first four afternoon runs. With us only separated by tenths of a second going into the 5th run, I tried to focus a bit more on my lines and knocked a full second off of run 5 and a further 1/2 second off of the final run (6). Nick seemed to plateau after his 4th run and his next to were more or less the same time, and I pulled off a win by 4.6 seconds overall.
In the meantime, after his first run of the PM, while we all idled in grid waiting for the next run, Chris's electric fan cut off due to a bad relay, and nobody heard it since his car is so loud. Unfortunately this resulted in the coolant massively boiling over. He went back to paddock and wired up a direct line for the fan to stay on all the time, added coolant in, and came back out to run, but apparently it was longer than the allowed mechanical break and he was docked a DNF run. Kind of a moot point since he was out of the running due to cones by that point anyhow, but kind of sucks to have insult added to injury there. After that he decided to call it a day and put the car on the trailer, not knowing if the engine was ok after the overheat and not wanting to risk it. That sucked because we love running against Chris to see if we can keep with him on raw time, in particular. He did stay to work the course in the second half of the session.
So that's the competition wrap, really. Eric is making progress on driving the ETA as well (for a guy who's had his license for less than a year, that's pretty good). And that car has new springs on it and looked better on course. Next event we should have closer to a full turnout, with some of the regulars hopefully coming.
The we went up a hill to take some photos of the cars and the venue.
and came down the hill...
So....I haven't taken any pics yet, but there was some damage/issues to the car from the beating the morning course laid down on it, and some things I need to do soon:
The rear passenger floor is dented in a few inches. I must have landed it on a pile of gravel or something. It actually popped the center "drain" panel out halfway and it was open about 3" when I noticed it. I was wondering how I was getting all that dust in the car during runs, lol. Shoudl be a pretty easy fix...I can pound it pack down and tack weld it. Not an issue.
Another issue is the high-pressure fuel pump is buzzing. Loud. I don't think that it's the usual "because it's dying" thing. I think the extra-rough course combined with me running a lower than normal fuel load (~1/2 tank) might have allowed some junk in the bottom of the tank to get sucked into the system. My visual inspection of the tank when I first set up the car didn't show any rust in there, but who knows. The plan this weekend will be to pull the rear filter and check that, check the pump screen, and check for other possible clogs. I didn't notice any fuel starvation on course or on the drive home, so hopefully it's just a minor issue. If not, I have another (used but working) HP pump that I'll throw in the toolbox in case this one dies.
The course broke my passenger mirror. Really. Didn't break the glass, but the mechanism that holds it in place is totally shot, so now it just points at the ground. That's annoying......
Cut those damn dust shields off.
Think about spacers to get me an inch or so of ride height. At this venue, this height is going to result in a lot of dented floors and who knows what else.
After my battery tray and the little cubby on the other side of the trunk were both about 3" deep in water after sitting for 2 weeks (a few days of rain), I need to redouble my anti-leak efforts around the trunk/taillights, and also make some drains. Thought I had all that solved last year, but apparently not.
And I'm sure I'll think of a few other things later. A few photos by Eric Helgesen...
ETA boys
Shawn/Katie and the RX-7 of doom
It has to be tow-started...but still took second in PR
It wouldn't be a rallycross if Jeremy Miller didn't lose his front and/or rear clip. On this occasion it took down a cone or two on its way off the car....
The Miester
Nick with his course-work goggles (much-needed)
2-1
Alp running in PR
Chris discussing the Stang
We roll R/V style
