Ok well let's get this on. Suspension arrived today, as well as some nuts and bolts and stuff I ordered from McMaster.
First thing was to take apart the old suspension. Everything still in good shape after 2 seasons of beating, amazingly.
As you can see, there was quite a bit of crud on everything:
more interestingly, a lot of stuff had gotten under the dust boots, which again supports my thought that I'll just do without from here on out, and make sure to clean the shock shaft after events.
The offset top hats once cleaned up were pristine, though a lot of dust and stuff had gotten into the bearing. I spent some time cleaning the bearing, got the action nice and smooth, dried it all out, and regreased. Looks like new now.
For this setup, since I'm not lowering the car I'll just re-use the stock perch to mount the lower threaded section. I don't need the whole perch (and it makes adjusting more cumbersome) so out with the grinder and off with it!
And then some assembly. These fronts are 8" 250lb springs with tender springs so they stay aligned under fool droop. Also got fixed camber plates. With the car going up, I want to maintain the 2.5* or so I'm running right now with the offset top hats at the lower height.
Before installation, I used a die to chase the threads on the balljoint and the one tie-rod end I'm going to re-use, and put on new locknuts (note that the tie-rod ends use a 1.0 pitch thread - so can't really get these at the local auto parts store). I just ordered bags of a few sizes that I use on the suspension, because you can never have too many of "the right size" nuts and bolts
So, bolted it all up, no problemo.
Here's the camber plate and installed...
blingy for now
So granted the car hasn't been driven so it will settle, but after bouncing up and down on the bumper for a while, the height with the adjusters near the bottom is about the height I was at before, if not 1/2" higher. I'll do measurements after driving the car and letting things settle. But that's good news, since the old height was as low as I'll ever want to go, while now I have the ability to go up a few inches if I want to do some trail-running, or a rough course, or go with larger tires. Time will tell. Bouncing on the car it certainly feels more firm than the old setup, but not "stiff" and definitely not as stiff as the WRX (on 330# springs).
So that's it for now. More once I do the rears and get it back on the road I guess...
