EDIT: Made some edits after re-reading my terrible handwriting on my tally sheets, lol.
I've always wondered what this car weighs, but I'm not going to drop a couple hundred bucks to go to a race shop and get on some scales. So I did it the ghetto way today.
I'll preface this by saying that measurements were made with the car in full "race" trim with a full tank of gas. No spare, no jack, no rear seat load panels. Exactly as the car is in competition except with the street wheels on vs. the rally wheels (the rally wheels/tires are 4lbs each heavier than the star specs on the wider euroweaves), so add 16lbs to the top of my meaurements.
I went to Walmart and bought four fairly cheap scales with a metal top. They have a max weight rating of 350lbs each, but the intention was to keep all of them below 200lbs where they're most accurate. To check them I weighed myself on all four and then on my $$ very accurate digital bathroom scale. The cheapos were always within 2-3 lbs of correct, plus or minus depending on where I stood on the scale (I tried different positions - in the middle, on the edge, etc). So that figures out to about a 1.5% margin of error per scale. Figure I'm using four per corner, so my max margin of error is about 6% either way.
I set up the scales in a square with a stiff board across them to distribute the weight, and thin pads in the middle of each one in the "best" position under the boards. I tried to center the tire as much as possible to distribute the weight across all four scales to keep them in the "middle range" where they're most accurate.
I also did each wheel at least 5-6 times with the scales rearranged in different positions, to try to see if the readings were affected greatly. Again, I found that no matter what I did, the readings were never more than about 3% off either direction.
So, did a crapload of measurements (with the car empty) and then did all the same ones with me in the driver's seat (wife reading off the numbers on the scales to me).
Then did a bunch of number crunching, and here's what I came up with:
Empty: RF: 567 AVG (hi: 587) LF: 611 AVG (hi: 644) LR: 520 AVG (hi: 526) RR: 552 AVG (hi: 564) - note that battery is in right rear corner TOTAL AVG: 2250 +16 lbs for rally tires, so 2276.
So I'm pretty confident that the car is a good bit under 2300lbs with the rally tires on in full competition trim. Note that this car has bumpers, all lighting, heater core, two seats, both OEM seatbelts, 6-point harness too, OEM dash and gauges, and a Kirk 4-point rollbar. Hood and trunk are not gutted.
So pretty pleased with that weight, since it's in the ballpark I had estimated in my head (well, I expected around 2200). I do find it very strange that the front left is so much heavier than the front right, and I can't really figure out why that is unless the M42 just naturally rests most of its weight on the driver's side.
And here are my avg. measurements with me sitting in the car: RF: 663 LF: 700 LR: 595 RR: 574 total: 2432
So that's a bit off there since fully dressed with my boots on I'm around 180lbs. But with two of the scales less visible and my wife not interested in getting under the car to read them straight-down, I expected the "me in the car" measurements to be off a bit, perhaps.
Anyhow, not meant to be a "scientific" measurement, but I think it's a pretty good ballpark to say that my car in race trim w/o driver is "right around 2350lbs" but the poor corner balance is somewhat annoying. It could explain why I've always felt the car is more balanced when I have a passenger riding on runs.
I'm not going to do any suspension "tuning" for the time being - I want to run it next weekend first to see how it feels first.
And thinking about how much weight I COULD lose on this car if it didn't need to be street legal......bumpers, lights, 2nd seat, front windows, rear windshield glass, gut hood/trunk, etc.....I think it would certainly be possible to get the car to 2100lbs even if it were bare-bones. I have no plans to do that, though.
Jesse Yuvali just posted up his corner weights for fully stage-rally-prepped M42 car (with all the stage gear...spare tires, tools, etc). That shows 2586 lbs, for comparison.
I don't have a pic of the other two sheets of numbers, but yeah....what a mess lol. This was the "first round" (did two more)
And yes, the car was level all four wheels for every measurements (on blocks)
