Okay most of these build threads are about the cars but few are about the support rigs! So this is dedicated to all those hard working beaters. Also the race car works perfectly fine and is not needing any attention so I have been forced to look elsewhere for projects:
I purchased this truck back in June of this year but here is the skinny:
85 3/4 ton suburban 4x4 heavy duty diesel chassis. power plant is from a rusted out 87 or 89 3/4 ton gasser TBI v8 350 SBC with manual trans.
There is a lot of mystery from this truck, I purchased it off of my GF's family but I know the vehicle came from Texas sometime in the mid 2000's so it only had minor surface rust issues but a day of sanding followed by a day of bedliner took care of that.
Didn't have to to much to get it to run, gave it some fluids and a battery and it started right up!
I bought the truck to haul around my 86 rx7 rallycross car, I have a 20' car hauler (18' deck, 2' dovetail) and this is basically operation overkill but it fits plenty of equipment and I can sleep inside of it comfortably so I don't need to pay for a hotel.
here are the highlights:
all of this for only1200 dollars with working 4x4 (1350 if you include the battery and gas needed to run it):
14 bolt rear end, 8 lug all around
poly bushings for the leafsprings
NP208 T-case
350SBC TBI
hydraulic clutch master/slave
heavy duty diesel cooling system (radiator is waaaaay too big)
still retains the hydroboost system
parking brake works!
GM muncie SM465 (now with ZF-meritor tractor shift knob )
285/75/16 tires with healthy meat left, minimal wear and weathering
rear AC (functional)
4.10 gears
remote mounted differential breathers (F&R)
sealed 7 way/4 way combo w/ class 5 hitch
stock this had the 6.2L with the turbo 400 auto trans.
I acquired this 'mess' of a truck around May-June 2012 and I have begun getting it road worthy as a tow vehicle and random off-road adventure bus.
This truck had spent 90% of its life in Texas until my girlfriend’s family bought it. This is a 1985 ¾ ton suburban that originally came with the 6.2 diesel but it pooped out on it and her folks had another suburban either 87 or 89 350 gasser EFI that had a manual transmission/t-case but the body and suspension was bad.
So the 2 trucks became one, motor/trans set went into the ¾ ton with a good body.
Here are some of the before shots:
