Mitchell wrote: I like the bed! Plan to add on the loops that allow 2" x 4"s slot into the sides?
No plans to add...
But...that's because they're already there!:
DoctorBlade wrote:ClemSparks wrote:I'm a geek, so that's what I thought you were referring to.DoctorBlade wrote:Just to be clear...my "Hello McFly" comment was an allusion to the truck in "Back to the Future"...not directed to you, Doc.ClemSparks wrote: uhhh...yeah. Last photo shows them. Though...I'd rather something a little less...uh...period correct. Hello McFly!helps to out the glasses on, I suppose![]()
So...I'm gonna make like a tree and get outta here!
Nice, you gonna add wooden sides? I think it would look good. The truck looks much better with the body lift removed.
Also I had a wacky idea the other day you might like, but it's not that cheap because it requires a relocatable winch: winch-powered crane (swing arm with pulleys) on the bed near the cab. Could be useful if you often lift heavy stuff from the ground onto there.
No new photos today, but it now has a nice rebuilt caliper on the driver front, new brake pads, and the wheels are straightened out (directionals are directional, after all)
Clem
GameboyRMH wrote: Nice, you gonna add wooden sides? I think it would look good. The truck looks much better with the body lift removed. Also I had a wacky idea the other day you might like, but it's not that cheap because it requires a relocatable winch: winch-powered crane (swing arm with pulleys) on the bed near the cab. Could be useful if you often lift heavy stuff from the ground onto there.
I will probably make some sides at some point. I do like the crane idea. I could use it to lift heavy stuff up there to move around on my new property (it's got a trench full of trash I'll need to clean up, over time).
Clem
