1 ... 4 5 6 7
aussiesmg
aussiesmg MegaDork
4/28/15 11:07 a.m.
On top of that they were excellent to deal with, extremely prompt, communication was awesome and the driver was a great guy to chat with.
Kudos to Fountain City Towing, Tennessee
865 773 8972 Edward
edwardh80
edwardh80 Reader
4/28/15 11:32 a.m.
aussiesmg wrote:  photo 20150426_220726_zpsozqibud7.jpg Patched a split hose to the turbo on the side of the road shortly later  photo 20150426_231742_zpsxocjlpdb.jpg But we had already hurt the engine, which we rolled the dice on and resulted in this.  photo 20150427_021858_zpsddeqtkwk.jpg It's Cummins time
I'm curious - what hose did you split? I assume an oil line, and you ran the engine dry for a little bit?
aussiesmg
aussiesmg MegaDork
4/28/15 11:41 a.m.
In reply to edwardh80: It was the oil line from the turbo so it was under pressure, we tried to get off the road quick enough but simply ran it too long and hurt the bottom end.
We were on US75 and it was dark, parking this rig on the side of the highway was far from safe, we threw in a gallon of oil and got to the next exit. Then we rigged our line repair, which was done with the help of a local guy who happened to stop by and went to get us some 1/2 hose, then we filled it with oil and started it but we knew it was toast, there was a bottom end knock.
We decided to push our luck to see if it would make it home, at that point the engine was coming out anyway. It didn't go far and boom, shrapnel actually struck the floor after bouncing off the road.
bgkast
bgkast GRM+ Memberand UberDork
4/28/15 11:57 a.m.
In reply to aussiesmg:
Go big or go hole.
Mad_Ratel
Mad_Ratel Reader
4/28/15 12:59 p.m.
:P
i figure some gigantic motor needs to go in there... something you have to cut a "vent hole" in the hood for...
Dusterbd13
Dusterbd13 SuperDork
4/28/15 1:21 p.m.
Something from a freightliner perhaps?
They regularly go a million miles.
edizzle89
edizzle89 HalfDork
4/28/15 2:03 p.m.
bgkast wrote: In reply to aussiesmg: Go big and tow home.
FTFY
tuna55
tuna55 UltimaDork
4/28/15 2:12 p.m.
TunaDad's hauler is powered by Cat, although I don't know which one. He has pretty good luck, and gets way better fuel economy than you quoted towing a two-car enclosed loaded trailer.
aussiesmg
aussiesmg MegaDork
4/29/15 6:26 p.m.
In reply to edizzle89: Towing the rig was going to happen anyway, unless we tried, unfortunately it failed quickly thereafter.
That said plans are afoot, it could be very soon that we will be doing a swap, 12 Valve ISB Cummins is the plan. Maybe a few tweaks along the way to make the towing less demanding.
Kenny_McCormic
Kenny_McCormic PowerDork
4/29/15 11:59 p.m.
Mad_Ratel wrote: :P i figure some gigantic motor needs to go in there... something you have to cut a "vent hole" in the hood for...
Detroit 12V71?
Mad_Ratel
Mad_Ratel Reader
4/30/15 6:38 a.m.
Detroit 12V71?
Had to google that.
yes this. very much this.
except with these added.
tuna55
tuna55 UltimaDork
4/30/15 6:50 a.m.
Which ISB?
The last Cummins I designed in was a QSX. I think Ignorant, er, Caffeine somethin or other now used to work at Cummins and can provide insight.
Mine was a QSX15, probably too big for your application. Here's one on ebay though.
http://www.ebay.com/itm/like/121513103867?lpid=82&chn=ps
We used it to start a small gas turbine.
chandlerGTi
chandlerGTi UltraDork
4/30/15 9:17 a.m.
Detroit 12V71?
Had to google that. yes this. very much this. Detroit Diesel 12v71 Hotrod photo DetroitDieselHotrod12v71.jpg except with these added. 16V-92 Detroit Diesel photo ph-10049.jpg
He has that in mongo, and wants to swap it out. They aren't great engines. ISB/ISM will be the right size.
Gearheadotaku
Gearheadotaku GRM+ Memberand PowerDork
5/2/15 8:05 p.m.
Haven't kept up on the thread, ouch this sucks. As I watch, hopefully I'll learn a thing or 2 about these diesels
Toyman01
5/2/15 8:20 p.m.
In reply to chandlerGTi:
Detroits are great as long as you like automated rust proofing and working on nasty oily vehicles. You almost can't kill the things.
This is the proper way to feed a Detroit.
Kenny_McCormic
5/3/15 2:35 a.m.
They are leaky and temperamental at best, but they sound ridiculous.
mndsm
mndsm MegaDork
5/3/15 7:36 a.m.
I don't care what happens, but now I want to see one of those ridiculous 23 speed Eaton's in it too because of that one thread.
Toyman01
5/3/15 8:09 a.m.
Kenny_McCormic wrote: They are leaky and temperamental at best, but they sound ridiculous.
Yes they do. https://www.youtube.com/watch?v=6vaeoOEsHPY
Probably one of the best sounding engines in my book. Certainly the best of the diesels.
aussiesmg
aussiesmg MegaDork
5/3/15 8:45 a.m.
This will do for a long distance hauler.
https://www.youtube.com/watch?v=iQG8qGjR_i4
aussiesmg
aussiesmg MegaDork
5/31/15 6:33 p.m.
The replacement of Sampson's engine is underway, with the help of Les the new engine has been sourced.
Seems Oklahoma is a little damp right now
Toyman01
5/31/15 7:09 p.m.
Cool. Glad to see it coming along.
Gearheadotaku
5/31/15 8:17 p.m.
I'll assume thats a Cummins engine? Same size or bigger? Oh wait, that was a dumb question
SVreX
SVreX MegaDork
5/31/15 8:24 p.m.
You've got mail.
aussiesmg
aussiesmg MegaDork
5/31/15 8:24 p.m.
It's the Cummins 5.9 12 valve replacing the 6.6 New Holland, and you knew that Jeff.
Gearheadotaku
5/31/15 8:35 p.m.
is this the first time you replaced an engine with a smaller one?
1 ... 4 5 6 7
sboLj3bm6G84b2cIkTTnMCHZLsmTCgZRVfOlD2xB96xeYP1p3JMULG0qyoB1RPdW
