Woody wrote:
That car is so nice!
I remember back in the 80's, *Car and Driver* did a test of a modified one. I can't remember who built it. Roush, Saleen, ASC or maybe some company that was modifying Merkurs. I remember it was given the 80's monochromatic look and I think it rode on Ronal R9's.
For the life of me, I cannot remember who build it either. It did have a Robert Yates engine. But I do know who did the pinstriping and graphics...
< This guy.
It was my first full striping job. I had done some race cars and collision work, but never anything major before that.
Didn't Roush upfit with these with a 351 and/or T-5 if you were willing to foot the bill?
I've always wanted an all-black LSC SE w/T-5 swap. We had a Maroon 89 LSC when I was a kid. Some of my earliest memories were riding in the back of that car.
^^ Yeah, that. Swoon
I still say they look good some 20+ years later.
The_Jed
SuperDork
1/11/14 3:25 p.m.
Adjusted the t.v. cable a bit on the white car. Then, for the hell of it, I removed the intake tube from the '87 and put it on the '92. Some of you already know the difference but the others will see in the pics.
![](https://scontent-b-ord.xx.fbcdn.net/hphotos-ash3/q71/s720x720/1555400_10201408718892180_103257280_n.jpg)
![](https://scontent-b-ord.xx.fbcdn.net/hphotos-prn1/t1/q71/s720x720/1551705_10201408719172187_1339359528_n.jpg)
![](https://scontent-b-ord.xx.fbcdn.net/hphotos-ash3/q77/s720x720/1604663_10201408721292240_1868612720_n.jpg)
![](https://scontent-b-ord.xx.fbcdn.net/hphotos-prn1/q74/s720x720/1512523_10201408721532246_1337897267_n.jpg)
![](https://scontent-b-ord.xx.fbcdn.net/hphotos-prn1/t1/q75/s720x720/1535618_10201408722932281_700876524_n.jpg)
![](https://scontent-a-ord.xx.fbcdn.net/hphotos-prn2/q75/s720x720/1501735_10201408723332291_61782738_n.jpg)
I only moved it a bit, just over 1/4". I only want to increase the line pressure a tad.
![](https://scontent-a-ord.xx.fbcdn.net/hphotos-frc3/q81/s720x720/1609846_10201408719332191_1970634307_n.jpg)
'87 on the left and '92 on the right.
![](https://scontent-b-ord.xx.fbcdn.net/hphotos-ash3/q71/s720x720/1524766_10201408721052234_938406316_n.jpg)
Cavernous '87.
![](https://scontent-a-ord.xx.fbcdn.net/hphotos-ash3/q71/s720x720/1558446_10201408720532221_853309925_n.jpg)
Choked off '92.
After swapping the tubes I pulled the car back into the garage. Suddenly the brakes were working great! I guess that was the problem all along! ![](/media/img/icons/smilies/crazy-18.png)
The_Jed
SuperDork
2/19/14 6:59 p.m.
I filled the brake fluid reservoir then bled the brakes and so far the brakes feel great! It took an entire jug of brake fluid, a big jug!
Unfortunately since the brakes now feel 100% I took it out on the highway and discovered O.D. slips. Oh well.
I was going down the highway in drive, which is 1:1, with the converter locked turning approximately 2,700 rpm at 60 mph. The tires are 225/60-16's which comes out to 26.63" diameter. I keep coming up with 3.57:1 rear gears?...
Once all of the snow is gone I'll check out the diff tag and see what's in there.
The car is so composed and buttery smooth, I love it! ![](/media/img/icons/smilies/laugh-18.png)
3.55 is a popular Ford rear axle ratio. Although I didn't realize they went that high (numerically) on these types of cars. Manual Mustangs of the same era had 2.73s stock, and the 3.08 rear end was an option. I believe the automatic Mustangs could be had with a 3.27 rear axle, so a 3.55 in a heavier car isn't too much of a stretch.
The_Jed
SuperDork
2/19/14 8:22 p.m.
I am just puzzled since I was expecting 3.27:1.
My blue LSC has 3.73 gears that I assume were swapped in at some point by a previous owner or maybe installed by some joker at the factory since the diff tag was still in place and it said they should have been 3.27:1.
The_Jed
SuperDork
3/13/14 6:51 a.m.
I just discovered why it took an entire jug of brake fluid to top off the reservoir, the passenger side rear caliper was leaking. I had been driving it for a few days and everything was fine then, when I heard about another inbound snowstorm I parked it in the garage again. I had noticed that the passenger side rear tire was perpetually wet and the brake fluid was low again. Hmmmm...
I pulled the wheel off the other day and noticed the soggy bits. A new caliper is inbound and I'll snap some pics before swapping it out.
Did you ever figure out what the axle ratio is?
NGTD
SuperDork
3/13/14 8:09 a.m.
I had the same thing happen with my WRX. It would only leak in the cold. I am assuming that the seal would shrink just enough in the cold to leak. Mine was the RF.
The_Jed
SuperDork
3/13/14 5:53 p.m.
In reply to Woody:
All my math points to 3.55. I'll go scope out the diff tag momentarily!
The_Jed
SuperDork
3/13/14 5:55 p.m.
![](https://fbcdn-sphotos-f-a.akamaihd.net/hphotos-ak-ash3/t1/p180x540/1899901_10201738099646493_1242042932_n.jpg)
It may be kind of tough to tell but that's water on the floor...![](/media/img/icons/smilies/unhappy-18.png)
![](https://fbcdn-sphotos-d-a.akamaihd.net/hphotos-ak-ash3/t1/q79/s720x720/1606904_10201738099846498_1394365202_n.jpg)
Soggy brake pads and caliper bracket.
![](https://fbcdn-sphotos-b-a.akamaihd.net/hphotos-ak-frc3/t1/p180x540/10001465_10201738100086504_1560484671_n.jpg)
The_Jed
SuperDork
3/13/14 5:56 p.m.
Even though it's not visible, rest assured there is a jack stand just out of view in the first pic.
The_Jed
SuperDork
3/13/14 6:07 p.m.
diff tag:
S442A
27 88 1J17
To teh googlez!
Edit: The sticker in the door jamb has a 5 under the AX field. Everything indicates 3.27:1 just like the blue beater but the tire diameter, trans gear, rpm and speed say 3.55:1.
The_Jed
SuperDork
3/13/14 7:41 p.m.
Assuming some error in the gauges I'm inclined to assume the gears are 3.45:1 or 3.55:1.
The_Jed
SuperDork
3/14/14 8:06 p.m.
The new hardware is installed and I took it out for a drive today. When I get off work tomorrow morning I'll take the kids for a cruise and hit a car wash.
The_Jed
SuperDork
3/23/14 2:44 p.m.
Another data sample for the gearing: 70 mph @ 1:1 (drive) = 3000 rpm.
That puts it closer to 3.45:1 for the ring and pinion.
The_Jed
SuperDork
4/12/14 5:09 p.m.
Finally got around to installing the front sway bar endlinks I picked up about a month ago. Much flatter in the turns now. ![](/media/img/icons/smilies/laugh-18.png)
The_Jed
SuperDork
4/19/14 8:45 p.m.
Did a tune up today; plugs, wires, cap, rotor, and fuel filter.
The_Jed
UltraDork
5/20/14 10:07 a.m.
I had been smelling gas for a while and was hoping the fuel filter was the source. It was not.
A few weeks ago I cycle the key on and off without starting the car, to pressurize the fuel line, and I noticed a slow drip running down from the topside of the tank. Assuming it was a problem with a line and knowing I would have to drop the tank and that I wouldn't have the time to do it, I dropped it off at a local shop to have it repaired. I should have it back by the end of this week.
The_Jed
UltraDork
5/30/14 5:20 p.m.
The fuel leak has been fixed. The "hanger assembly" was swapped out for a new factory O.E. piece since there was a pinhole in one of the old hard lines.
![](http://images.oreillyauto.com/parts/img/large/aix/e2084h-1.jpg)
The_Jed
UltraDork
5/30/14 5:21 p.m.
Just ordered some KYB GR-2 front struts.
![](http://www.coolcats.net/modifying/images/kybstrut.jpg)
I like those KYbs. We have them in our lemony Turbo Coupe and Mustangs...
