Two things have happened recently in my life that make it seem like owning a truck would be a good idea; I got a 21' trailerable sailboat for free that I'd like to take out and my girlfriend and I are buying a somewhat rundown house with almost an acre of land. The budget? Extremely low, which explains how I've ended up looking at this thing:
At its core, it's a 1993 Ford F-250 diesel with the 7.3l IDI and the ZF manual gearbox, or so I think. At some point someone put a dually rear axle on it and the cool flatbed. My friend purchased it in probably 2008 or so and used it as a waste oil collection truck for his business. That didn't last long and after having been retired it sat in his lot for a number of years and then was moved to the side of his new shop where it's sat for another two years. Back in the aughts, my friend's company not only collected waste vegetable oil from restaurants but also converted cars and trucks to run on waste oil. This truck has one of his conversions which still works, amazingly. My girlfriend and I have taken to calling it the garbage truck because it is garbage, was previously used to suck up garbage, and will be eventually used by us to move garbage to the dump.
Anyway after some junkyard batteries, a jump pack, and some ether (more on that later) it roared to life and we managed to get it out onto the street for its first drive in awhile. It was immediately apparent that there were no brakes so it went up in the air for some investigation:
Tracked it down quickly to this:
So after putting a new line it runs, drives, and stops. Turning is a problem because the power steering fluid ends up on the ground very quickly. There's also a stuck front caliper. And the other brake lines look suspect, to say the least.
I have a rockauto cart with new calipers, pads, hoses, a power steering pump, a lower balljoint for the passenger side, and some filters ready to go. I also know a guy with a landscaping company that replaces all of his trucks' tires every six months, so I'll pick up some used ones from him. Purchase price for this bad boy? Probably $500, the deal is yet to be inked.
Now I mentioned the ether earlier and that will be a recurring theme for this truck. The number 7 glow plug is broken off in the head and at least four others are stuck. At some point those cheap plugs were put in and now here we are. After some investigating, I've decided to eventually install a remote ether start kit and just go with that. This truck is not worth removing the heads and having the plugs extracted!
This will be my first foray into full-size truck ownership (RIP my trusty $700 Ranger), so any words of wisdom are appreciated.
