1 2 3 4 5 6
oldeskewltoy
oldeskewltoy Dork
9/10/13 5:59 p.m.
hmmm... you didn't mention if you had actually worked on the brakes yet....
Strike_Zero
Strike_Zero SuperDork
9/10/13 7:36 p.m.
In reply to oldeskewltoy:
You are DA MAN!!
I'm still working the interior. The car had some really knackered seat belts . I grabbed some from a 88 Tercel. It physically bolts in the space, but I think they may be a bit too long or the reels are at a wrong angle. It doesn't lock when you pull it aggressively. Still have figure that out.
I also pulled the rapidly decaying wood steering wheel.
Since I'm not stripping the sound deadening tar out, I have to finish cleaning for some paint.
Strike_Zero
9/17/13 9:10 p.m.
The kittens have been moved since last Wednesday. I've been working to get rid of the "stink" left by them and the "stink" still haunting those MR2 seat I grabbed from Pull-a-Part.
I pulled out some stuff today in preparation for an all week thrash!!
Enjoy the pics. . . .
Strike_Zero
9/17/13 9:11 p.m.
Strike_Zero
9/17/13 9:12 p.m.
Strike_Zero
9/17/13 9:15 p.m.
Strike_Zero
9/17/13 9:16 p.m.
Strike_Zero
9/17/13 9:18 p.m.
Strike_Zero
9/17/13 9:22 p.m.
Trying to decide how I wanna finish the wheels off . . . I'm thinking red lip, black spokes and red in the small channel in the spoke . . or just leave em red. . .
mazdeuce
mazdeuce SuperDork
9/17/13 9:45 p.m.
Just leave them red.
You must have pretty chill neighbors.
Strike_Zero
9/17/13 10:28 p.m.
In reply to mazdeuce:
All my neighbors believe in letting people be . . . That and I invite them over for grilled food and beer
sethmeister4
sethmeister4 Dork
9/17/13 11:14 p.m.
Looking good! I think the red wheels looks cool too...what color will the car be?
Strike_Zero
9/17/13 11:49 p.m.
I'm thinking dark gray, a dark silver, or black . . . Haven't decided at this point.
oldeskewltoy
oldeskewltoy Dork
9/18/13 12:16 p.m.
Strike_Zero wrote:
do yourself a BIG favor... replace the control arm pivot bushing... Rock Auto... or if you want urethane.. Prothane, or Energy Suspension should have them listed.
get new hoses too
JoeyM
JoeyM Mod Squad
9/18/13 12:24 p.m.
the wheels look good.
Strike_Zero
9/18/13 12:43 p.m.
Gots a box full of stock brake items from RockAuto.
I decided not to replace them as they where NEW when I pulled the stuff off the Cressida from a Pull-a-Part trip. There were three month old suspension work receipts in the glove box.
At a stop right now to get sammiches . . . but the rear end is nearly complete. The drum brakes were a breeze!! The first side took about 30 mins, the other took about 10 .
The po boogered up the diff fill plug pretty good; I can get a wrench or socket to grab it . . .
Strike_Zero
9/18/13 12:45 p.m.
In reply to JoeyM:
Thanks!! There is something to that prep, sand, clean, primer, sand, clean and paint thing
I have to get some black paint to do the little channels in the spokes and then clear . . .
JoeyM
JoeyM Mod Squad
9/18/13 1:42 p.m.
I'm sure that prep makes all the difference. I did lousy prep on the geo, and the rustoleum blue that I used in the chanels on the spokes has peeled. :(
Strike_Zero
9/18/13 2:26 p.m.
Woowhooo got the fill plug off!! Gotta hit the parts store for a replacement . . .
mazdeuce
mazdeuce SuperDork
9/18/13 2:31 p.m.
Can you go over your general prep and painting procedures, especially on the suspension stuff? I've got pieces coming off soon and I really don't want to bolt them back on ugly. I like to learn from people that seem to do a good job.
hobiercr
hobiercr GRM+ Memberand HalfDork
9/18/13 4:05 p.m.
LOVE the MKII Supra wheels. I have always though this was one of Toyota's better looking stock wheels. They even look better red.
(and those are some damn cute kittens)
Strike_Zero
9/18/13 4:52 p.m.
Real easy . . .
  • Clean the wheels
  • Scuff them REALLY well. I used a drill and a 2" ball attachment equal to a red scuff pad.
  • Once you get a really dull finish, blow away all the crap with an air gun
  • Clean the wheels and dry thoroughly
  • Put on some rubber gloves
  • Prep the wheels using prep wipe of alcohol and let dry
  • Prime the wheels and let it dry to touch
  • Go over the primed areas with a red scuff pad
  • Blow the wheel clean
  • Prep wipe and let dry
  • Paint your favorite color
  • Let it dry to touch and apply clear
  • DONE!!
mazdeuce
mazdeuce SuperDork
9/18/13 5:21 p.m.
Awesome. Same general procedure for suspension components and such? I'll probably be starting with the bracketry on the front of the motor when I change the water pump.
You build has had me searching craigslist by the way. I like it.
Strike_Zero
9/18/13 8:55 p.m.
Yup . . . I used the same procedure on e'erything.
If the parts are greasy, purple power/simply green the E36 M3 out of it and let it dry first.
Strike_Zero
9/20/13 8:29 p.m.
Last update of the week . . .
I mounted the rear axle on Wednesday and the front suspension today . . .
My first drum brake job went off without a hitch!! Between the camera, oldeskewltoy post and doing one side at a time, I didn't screw it up . . .
1 2 3 4 5 6
3PtaNE7HCBuyDrb8qm2eQxeA7FLl0j4u0AV3SYvyUm1b9IOHIsxv5uJcFGpLoQ3o
