1 ... 13 14 15 16 17 ... 29
Knurled
Knurled GRM+ Memberand UltraDork
6/8/13 6:41 p.m.
If that was my car, I'd Sawzall the bottom third or so of the bumper support out. It looks like the bottom of it may be hurting flow to the top half of the radiator, so most of the air has to go through the intercooler. That's good for the intercooler, but not so good for getting BTUs out of the coolant.
I forget. Before you put the engine in the car did you convert it to FWD-style coolant flow?
An aside, my car was running hot on the street. Put the new suspension on and it was running much hotter, like 210 degrees just driving down the highway. With the car on the lift, I could see that air would preferentially go through the wheelwells and not the coolers. Put the under-fascia back on and it's back to running 160f on the highway.
Well, when I took it off, it was October and it was cold...
EvanB
EvanB GRM+ Memberand PowerDork
6/8/13 6:59 p.m.
If this ducting doesn't get things in line I am going to cut a vent in the bumper like so:
I did not do the coolant reroute when I swapped the engine. I was reading somewhere that the newer (00+ or so) engines had a revised headgasket design that had better coolant flow but I don't know if that is accurate or not.
EvanB
6/8/13 7:01 p.m.
Here is a thread about the revised headgasket:
http://www.miataturbo.net/engine-performance-56/mazdaspeed-hg-vs-reroute-57513/
EvanB
6/19/13 5:08 p.m.
I wonder what this could be used for...
Swank Force One
Swank Force One MegaDork
6/19/13 5:09 p.m.
I probably wouldn't bother with a coolant re-route on an MSM motor. General consensus seems to be that it's dumb. If you DO do it, you have to swap to a different headgasket as well... and.. well... blah.
eastsidemav
eastsidemav Dork
6/19/13 6:44 p.m.
Skid plate time?
EvanB
6/19/13 7:19 p.m.
That's the plan. I just have to decide if I want to put the arrow facing the ground or the engine.
eastsidemav
eastsidemav Dork
6/20/13 6:00 a.m.
EvanB wrote: That's the plan. I just have to decide if I want to put the arrow facing the ground or the engine.
I vote painted side down. Then the scraped off paint can tell you where you are hitting stuff.
EvanB
6/20/13 7:36 a.m.
That sounds like a good reason to me.
fidelity101
fidelity101 Dork
6/20/13 8:42 a.m.
Yeah I have a curvy road sign for mine, it has saved my fancy radiator and oil cooler many times. I'll show you the dents at the July event lol.
EvanB
6/29/13 7:12 p.m.
28 miles of racing and about 5/8 of a tank of gas used at the event today between myself and Chris.
The larger injectors didn't seem to fix the cutting out but it also didn't seem as bad.
The radiator ducting worked great until the tape holding it to the radiator came loose and it created a large gap.
cghstang
cghstang HalfDork
6/29/13 7:37 p.m.
Did the final results end up as indicated by Pete?
EvanB
6/29/13 7:41 p.m.
You were about 3 seconds up after all the cones were added.
cghstang
cghstang HalfDork
6/29/13 7:44 p.m.
Up? Congress?
Did I win or not?
I would say the cut out issue was significantly improved given how much full throttle we/I was using. And the sealed ducting vs. non sealed ducting was a night and day difference for everyone taking notes.
EvanB
6/29/13 7:54 p.m.
That took a few edits.
Yes, you did win.
Knurled
Knurled GRM+ Memberand UberDork
6/29/13 9:31 p.m.
I'll get you next time, Gadget!
I wonder if this is where I should point out that I was only getting 3/4 throttle...
Knurled
7/5/13 12:16 p.m.
Grip:
EvanB
7/7/13 7:59 p.m.
cghstang
cghstang HalfDork
7/22/13 8:44 a.m.
fidelity101
fidelity101 Dork
7/22/13 1:04 p.m.
EvanB wrote:
twin mazda powa!
EvanB
7/27/13 6:35 p.m.
The event today was a bit muddy.
EvanB
7/27/13 7:32 p.m.
Video of Chris starting, bonus footage of another car spinning through the finish in the background.
http://youtu.be/MJPypOkLu3I
Knurled
7/28/13 3:33 p.m.
http://www.youtube.com/watch?v=M3ot0JPj1_0
http://www.youtube.com/watch?v=Knk2w643t2s
cghstang
cghstang HalfDork
8/6/13 2:51 p.m.
SLALOMCROSS
EvanB
8/11/13 6:31 p.m.
z6VitlWbxfykA3MPVd5nOBGXPZfW6Tkio6razuIXx2eX1kz6pbIsifA46IQhv4wX
