The eagle has landed! My buddy that kinda brokered the deal for me was worried Missouri would shut it's borders for non essential travel. So he loaded the car up Friday night and headed out early Saturday morning. The newer battery with the car was toast. Must have a dead cell or whatever batteries no longer work from. I'm not a scientist. Anyway, I stole the one out of my Montero to get it unloaded. Posts are in the wrong spot, but we were able to get them somewhat connected so we could pull it off the trailer. After figuring out the car won't start in anything but neutral we were off and running.
I love this car.
It sounds good. It looks cool. It's kinda fast?
Anyway, I spent a good hour just kinda looking over the work that's been done to it and seeing what we may need to go fetch from a junkyard. I also went through the pile of parts to see what we kinda spares we have or what could be sold off. There's quite a bit of stuff to look at and go over so I won't paste the 90 pics I snapped. Just the stuff we will address and some overall shots.
The seat brackets on the driver side have to weigh a ton. Way overbuilt, and due to lack of adjustment will need to be address. After the team gets a good look at things we will go over whether a new seat is in the future or if we make this work with the proper safety measures in place. I'm pretty sure I still have a circle track head bracket from a Kirkey. My buddy has more too I think that could maybe bolted on as a halo of sorts.
No wiper motor assembly or arms. I imagine we are going to need that for any possible race days, so that's on the pick n pull list.
Air intake is a jumbled mess. We may leave it. If we find a stock one for cheap it will get swapped out. I was told by the PO that I should look into retaping the intake. He's funny.
Steering quickener is probably too fast for track work. Even so I think the only part of the collapsible column was where the quickener now resides. I need to do some research on that though.
The fuel gauge is pegged out. From a quick google search there's a chip on the back of the cluster that can fall out or be loose enough to cause the symptoms we are having. I'm hoping that's all it really is. Temp guage and all others appear to be working properly.
The e-fan is on when the ignition is turned on. Always. Not sure I like that at all, so we will probably get a relay set back up on a temp switch. The ignition switch itself is an interesting setup. Gotta figure out where and how we wanna setup the kill switch.
The front core support is mostly cut out and some bumper support brackets were fashioned up to kind hold things in place. It's functional but the lower part of the bumper needs support. Really the whole bumper needs a quick release setup because getting it on and off the trailer without scraping is tough even with long ramps. We will worry about that later though.
Looks all the wiring is still there for lights.
There's a set of spare wheels. They are hideous. The tires on both sets are basically round and good for moving the car around. That's it.
Main drive belt is cracked pretty bad. Gonna swap that out immediately.
I forgot about the back spoiler. It's been a while since I've seen the car, so I was planning to fab one up cheap. Looks like it's already done for me, and looks cooler than what I would have came up with.
In conclusion I think we got a great starter car. We mostly just need to focus on maintenance upkeep and getting safety equipment set up. The team should be all here today to go over everything and set our plan of attack.
Untitled by hatchethairy, on Flickr
