1 2 3 4
Bigben
Bigben HalfDork
3/2/19 9:19 p.m.
The quest for 2019 dominance.
Well, I guess it's more of a quest to do better than last time.
EDIT:  Here are links to the engine swap and axle swap build threads.
Opel GT SR20DET Engine Swap
Volvo 1031 (Dana 30) Rear Axle Swap
Semi-recent walk around video.
Challenge Opel GT Overview
bigben
bigben Reader
3/2/19 9:29 p.m.
Let's start by making some adjustments to the exhaust.
bigben
bigben Reader
3/2/19 9:46 p.m.
Here is the old exhaust system compared to the new lower restriction design.
bigben
bigben Reader
3/6/19 11:53 p.m.
Elbow welded to the down pipe in order to eliminate a clamp. Woohoo, $10 back in the budget to spend somewhere else.
GarageGorilla
GarageGorilla New Reader
3/7/19 12:09 p.m.
Public service announcement: cinder blocks are a dangerous means of supporting a car.
speedyquest
speedyquest New Reader
3/7/19 12:11 p.m.
Listen to this man, he is speaking truth.
tdrrally
tdrrally Reader
3/7/19 12:12 p.m.
turn that block 90 degrees it will be a bit safe
TurnerX19
TurnerX19 Reader
3/7/19 12:22 p.m.
In reply to tdrrally :
Not safe period. They fail spontainiouslly with no warning.
pinchvalve
pinchvalve MegaDork
3/7/19 12:28 p.m.
90-degrees is a little better, at least it is the direction they were designed to support.  Wood cribbing is the cheap way to support something!
bigben
bigben Reader
3/8/19 1:09 a.m.
Well I admit I didn't use Euler's column equation to analyze my block loading, but at 500 lb load per block I was not too concerned.
bigben
bigben Reader
3/24/19 12:50 a.m.
Getting some work done on a new torque arm cross member which may tie into sub frame connectors at a later date.
bigben
bigben Reader
10/5/19 11:47 p.m.
Nothing like procrastinating to the last minute.
I finally got some time on the car. I hope I can get my to do list done before the challenge!
Torque arm 2.0 and subframe are done.
bigben
bigben Reader
10/25/19 9:15 p.m.
Well the torque arm and crossmember functioned great; however, the front u-joint didn't fair so well when I launched with warmed up Hoosier S80's.
Bigben
Bigben Reader
9/18/22 1:10 a.m.
I really need to update this to the 2022 version.
Let's start with some new safety gear I picked up today from one of this year's Challenge sponsors #Summit Racing.
It was a busy Saturday and I didn't feel like waiting around to order and wait for the warehouse to pull the order, but then I spotted a small sign in the tool aisle that they are having a 10% off sale this weekend because of the Good Guys Lonestar Invitational.  Well that convinced me it was worth it to stick around. I saved over $30 on an Sa2020 helmet and a SFI driving suit. Now at least my gear will pass tech.
Bigben
Bigben HalfDork
2/25/23 8:23 p.m.
More recent walk around video.
I guess it is about time I start posting some updates. I have been putting together some videos of modifications that I will start posting soon.
Bigben
Bigben HalfDork
2/26/23 2:07 a.m.
Here's probably the most significant upgrade for this year's Challenge.  I finally got wider wheels(15x9) and I'm going to splurge on new autocross tires.
preach (dudeist priest)
preach (dudeist priest) GRM+ Memberand SuperDork
2/26/23 7:55 a.m.
Very cool and inspiring for my GT build.
jfryjfry
jfryjfry SuperDork
2/26/23 9:32 a.m.
How have you done in the past?   Looks like a potent little package
Bigben
Bigben HalfDork
2/26/23 10:04 a.m.
In reply to jfryjfry :
10th overall in 2016 and 14th overall in 2019, if I remember correctly.  2019 would have been better if I hadn't snapped a u-joint on the first drag launch.
I cringe when i look at those pictures.  GRM should somehow get together and buy that man some jackstands.
Bigben
Bigben HalfDork
2/26/23 1:26 p.m.
In reply to Purple Frog (Forum Supporter) :
Yep, this has already been brought up and discussed. I have jack stands and ramps too.  Each block is only supporting about 500 lbs. This isn't a full size pickup parked on them.
I know I appear to be an old has-been Boomer, but in my lifetime I've seen so many deaths that could have easily prevented.  A guy 1/4 mile from where I live died last year from not being able to lift a car off himself...
I work in construction almost every day.  I've seen framing hammers drop on a block and it break.  You are supporting the wheel weight on one center web of the block.
Don't take my post as angry, I just care.
Bigben
Bigben HalfDork
2/26/23 9:49 p.m.
Thanks. I appreciate the concern.
Bigben
Bigben HalfDork
2/26/23 10:51 p.m.
After reviewing photos of the 2019 Challenge I decided that I needed to reduce body roll so I took off the solid 7/8" VW sway bar I had on the front and picked up a significantly larger diameter 4th Gen Firebird sway bar. I shortened it to fit, swapped the ends and welded them back on.
Bigben
Bigben HalfDork
2/26/23 11:27 p.m.
During both the 2016 and 2019 Challenge the Pro drivers commented that the original thin wood steering wheel was hard to grip. So, using some felt weatherstripping and a leftover piece of vinyl, I made the steering wheel thicker and hand stitch a steering wheel cover.
1 2 3 4
L45Iu6n6tMBIkInQOoSyFnC20KQVxu5ft03k12lrsw3JDeErqhsEeeIWfYcAZesM
