1 ... 19 20 21 22 23 ... 35
wawazat
wawazat SuperDork
4/24/22 8:24 p.m.
I'll replace that too.  Thanks.
tester (Forum Supporter)
4/24/22 9:15 p.m.
You are really close to getting it back on the road. Good luck! yes
wawazat
wawazat SuperDork
4/24/22 10:24 p.m.
Thank you.  I hope so.
Recon1342
Recon1342 SuperDork
4/24/22 11:09 p.m.
In reply to wawazat :
If you need to, take a breather. I've stepped away from projects for a couple of days before; kinda gives you fresh eyes when you come back.
Also, prayers for you and your dad from the Recon household.
JBinMD
JBinMD New Reader
4/26/22 5:19 p.m.
Maybe just give the starter a whack with a hammer and try again?
****This.  But maybe try the SFH or the MFH instead of the BFH.  Just had to replace the battery in our C-Max because of a mystery drain that would randomly leave the car dead.  Was very odd because I would check the battery and it would be 12.6-12.8V, so fully charged, but then a little later the battery voltage would be dropping quickly and it wouldn't start the car, but no large amp load could be found.  It turned out to be that the battery still had good voltage but its capacity had gone from 65AH down to, like, 2AH.  If you put *any* load on the battery the voltage would collapse like an NBA/soccer player getting fouled.  blush  Yes, sometimes I are idgit.  Anywho a new battery cured all problems (so far).
Indy - Guy
Indy - Guy PowerDork
4/26/22 5:22 p.m.
How's your Dad doing?
wawazat
wawazat SuperDork
4/26/22 6:46 p.m.
He's home now and feeling better.  Thanks for asking.  Hospital couldn't find anything definitive with his heart or brain so after his symptoms subdued he came home.  Waiting on regular doctors visits this week for additional insight.  I appreciate the concern from you all proving again what a genuinely good group of people live around these parts.  I'm touched by your kindness.  Thank you.
I'm replacing the battery this week.  I'm considering a Costco purchased Interstate-700 CCA 3 year replacement for $99.  Best price for the specs.  I was looking at AGM batteries and again Costco has the best price at $159.99.
Dusterbd13-michael
Dusterbd13-michael MegaDork
4/26/22 7:51 p.m.
Glad to hear about your dad. Mine had Similar stuff last fall. Its scary, and at 41 and him 76 im not ready yet. I know how you feel, and if you need anything, reach out. We got you
Battery: im buying the mid grade Walmart now. Cheap, readily available, and easy to swap. Last one was $75?ish
Indy - Guy
4/26/22 8:33 p.m.
Good news about your Dad.  I remember meeting the two of you at the HR Power Tour.  Looked like you guys were having an amazing time.  I'm glad it looks like you guys are going to be cruising in the Cougar again this summer yes
re: Batter.   Do you have a spare one you can swap in to verify that it's the battery before purchasing a new one?
Recon1342
Recon1342 SuperDork
4/26/22 8:38 p.m.
Drag the battery to the nearest parts store and have them load test it.
wawazat
wawazat SuperDork
4/28/22 8:25 p.m.
I had a few minutes before cooking dinner to take a look at the car.   I put a socket on a breaker and turned the motor about 90 deg just to verify nothing had gone horribly wrong internally.   That fear alleviated, I'll hit the key in a bit to see if the solenoid might have loosened up in the sub freezing temps and with the crank turned a bit.   Should that not address the issue, I'll proceed to a percussive maintenance procedure on the starter solenoid, loosen the starter, and if necessary replace it with another one I bought last summer brand new that a local racer wanted to sell.  Fingers crossed.
wawazat
wawazat SuperDork
4/28/22 8:26 p.m.
BTW-Dad checked out fine at his cardiologist and neurologist and feels good today and since he came home.
4/28/22 9:15 p.m.
Good news about Dad!  I'm glad to hear it.
wawazat
wawazat SuperDork
4/29/22 2:32 p.m.
SUCCESS!   So far anyways!
Installed the new battery, hit the starter and it spun the motor!  I pulled th me coil wire and cranked it a few times to get the oil to circulate.  Popped out, reconnected the coil wire, put the trans in neutral and she started.  Looked down and no wheel motion!!!   So no energized input shaft condition.  I've got some work stuff to knock out then off the jack stands for a drive tonight!
Woooo Hooooo! laugh
Indy - Guy
4/29/22 2:51 p.m.
Two Thumbs up on both accounts yes yes
NOT A TA
NOT A TA UltraDork
4/29/22 4:42 p.m.
Glad to see the battery thing worked!
NOT A TA
NOT A TA UltraDork
4/29/22 4:43 p.m.
Did dad ever have Lyme disease?
wawazat
wawazat SuperDork
4/29/22 5:56 p.m.
Not that I'm aware of but I'll ask him.
Something's still not right unfortunately as clutch still isn't releasing fully.  I got everything prepped/checked for a quick drive-fluids, lug torque checked, tire pressures adjusted-and fired it up in neutral.  Depressed the clutch pedal and wouldn't go in to any gear.   Shut off engine select 1st and start the engine and can feel a load on the motor bring down the revs so it's still not releasing fully.  I thought I'd fully adjusted the clutch pedal for maximum travel but that's next step for investigation.  Dang.
84FSP
84FSP UberDork
4/29/22 7:16 p.m.
Keep the faith - you are close sir.  You doing any of the conferences in Detroit next week?  Maybe we can grab a beer.
wawazat
wawazat SuperDork
4/29/22 7:29 p.m.
Yeah I'm not feeling great but I'm not defeated Dave.  I did fix the backwards clutch disc and am still making progress I'd just hoped this would wrap things up.  It hasn't so back at it.  I'm trying to eke out some additional MC travel via the linkages but have already ordered its replacement.  It'll be in on Tuesday and eliminates all that.
I'm not attending next week.  Will you be coming in later this month to the Injection Molding and Design Expo?   I'll be at that show.   I'll also invite you to the event Engel is doing with Sabic June 2nd.
Norma66-Brent
Norma66-Brent HalfDork
4/30/22 6:10 p.m.
Your so close man. So close
wawazat
wawazat SuperDork
4/30/22 7:24 p.m.
Yeah I was under the car and adjusted the slave cylinder to max it's stroke.  Gear engagement is much easier but clutch still isn't releasing.  I think the MC is the issue and I'll work on the linkage a bit more as I await it's replacement due to me on Tuesday.
wawazat
wawazat SuperDork
5/4/22 10:16 p.m.
Weather cleared as did my schedule so I tore in to it tonight.  Pulled the steering column and then pedal assembly out.  Removed the clutch MC and all of its associated bits too.  I've got a question for Malwood USA, the maker of the new clutch MC assembly so I'll call them in the morning to discuss then start reassembly tomorrow night.
wawazat
wawazat SuperDork
5/5/22 9:36 a.m.
Spoke with Malwood USA, got my questions answered right away so tonight is reassembly time.  Great support from Malwood!
Noddaz
Noddaz GRM+ Memberand UberDork
5/5/22 9:49 a.m.
I am glad to hear your Dad is doing better...
What did Malwood say?
qCqCdNZJlb3VCXdEOOP9ZPUdXih5N0CgJJObZx24bqk4ATVta8AEusRqYEj1yHXH
