1 ... 4 5 6 7 8 ... 10
bluej
bluej UberDork
10/8/19 5:10 p.m.
Drag goals: 14.99 w/out soiling the track cus boom.
Edit: a bpu miata is exactly the benchmark for Betsy this year. What do na8's run?
Edit2: looks like high 15's
RedGT
RedGT Dork
10/8/19 7:31 p.m.
¯\_(ツ)_/¯ said:
What if we just put a big button on top of the dash so I have to take my hand off the shifter to use it?  Guarantees the truck gets a moment to settle out before I can hit it again cheeky
I like this.  Especially the visual of "shift and then slap the huge 'easybutton' on the dash until the next shift"
bluej
bluej UberDork
10/10/19 12:07 p.m.
that seems... not the safest option, hah.
Good news is I tested the fuel solenoid again last night, but this time feeding the inlet side, and no leaks.
It also occured to me that my companies ny office has a bunch of people in it that could help me learn how to program an arduino quickly to do the nitrous control. I'm liking this option..
¯\_(ツ)_/¯
¯\_(ツ)_/¯ PowerDork
10/13/19 8:55 a.m.
Taking care of some little cosmetic stuff- half a can of plastidip for the window trim:
And a can of hammered finish rustoleum for the bumpers:
Needs a good cleaning but is looking pretty good for a $350 truck.
bluej
bluej UberDork
10/13/19 9:05 a.m.
saweeet! laugh
¯\_(ツ)_/¯
¯\_(ツ)_/¯ PowerDork
10/13/19 10:27 a.m.
In case anyone doubts the validity of the "free from the side of the road" seats, here's the brand new towel I used to wipe upholstery cleaner off of them:
Dusterbd13-michael
Dusterbd13-michael MegaDork
10/13/19 10:50 a.m.
If thise seats were black, id be trying to get you to bring a drivers side with you so i could take tje flofits back homewith me from the challenge....
bluej
bluej UberDork
10/13/19 11:39 a.m.
No way, these are staying w/ Betsy. They're way better than the exploder seats I yanked from the yard.
irish44j
irish44j MegaDork
10/13/19 4:28 p.m.
Happy to see you did the window trim. I was gonna be annoyed if you didn't have time to :)
irish44j
irish44j MegaDork
10/13/19 4:30 p.m.
Also, watching this thread is making me occasionally look at 80s pickups rather than short-wheelbase 80s SUVs for my next project.......
sleepyhead the buffalo
10/14/19 12:19 a.m.
Ditto
¯\_(ツ)_/¯
¯\_(ツ)_/¯ PowerDork
10/14/19 1:52 p.m.
I just want everyone to know that Josh is sending me a nitrous kit he bought on eBay, for me to install on his truck, with less than 10 days to go before I drive it 1000 miles to go compete on his behalf.  He must have more faith in my skills than I do cheeky
¯\_(ツ)_/¯
¯\_(ツ)_/¯ PowerDork
10/18/19 8:52 p.m.
Ok, this looks.. involved.  And upon closer inspection the previous owner of this nitrous stuff was at a "pipe tape on AN fittings" level of knowledge.
Did some wiring first, tucking a relay up near the battery and installing the WOT switch, a purge switch, a steering wheel button, and a master arm switch from a pile of random automation equipment I have from my previous employer.  The whole deal is also wired to the ground on the factory clutch switch such that it should shut off when I shift, even with the throttle pinned.
Then, plumbing.  The solenoids need to live somewhere and this big intake chamber was in the way:
So I removed it and made a combination plug and nitrous nozzle adapter out of a PVC cap:
It's all a little bit of a disaster:
I also made the mistake of cranking the wheel back and forth to check that the steering wheel button wires have enough slack and it pumped power steering fluid everywhere.
The current big issue is fuel- the initial plan was to use these adapter things, but they don't actually fit the dumb fuel line clippy:
Then I tried to find a way to adapt to the threads for the Schrader valve at the end of the fuel rail, but after removing the valve, dropping it into a spot behind the intake which is apparently made of knives (ow), and retrieving it from said plastic knife hell, I can't find anything locally that has a small enough pipe thread.  And these fuel lines are weird plasticy things that I'm not sure I can tee into.  Hmm.
If I solve that I only need to do a bunch more wiring, make a bottle mount, and rig up a wideband.  Also pack for a 2000 mile round trip.
Patrick
10/18/19 9:10 p.m.
Is the schrader valve port a standard -4an?  All my gm stuff is as well as the mercedes, i think it's relatively standard.  Short -4 line from rail to fuel solenoid after pulling the valve core = fuel supplied.  Feel free to text me if you need help (330) two four two 07sevenone
irish44j
irish44j MegaDork
10/18/19 9:18 p.m.
IDK what your travel plans are, but if you want to stopover here in DC and can't stay at Josh's for one reason or another, you're welcome to crash at my place and head out early, or late, or whatever.
gumby
gumby GRM+ Memberand Reader
10/18/19 9:18 p.m.
Unless Ford has changed things, the Schrader port in the rail should be 1/16" NPT
¯\_(ツ)_/¯
¯\_(ツ)_/¯ PowerDork
10/18/19 9:29 p.m.
In reply to Patrick :
Unfortunately it's a regular bicycle sized one,  and is 1/16npt when unscrewed.  Thanks though!
Patrick
10/18/19 9:47 p.m.
So you need a 1/16npt female fitting to adapt to a -3 or -4an male to send fuel to the solenoid.  I can check my fittings.  We should be able to make it work somehow.  I think i have a 1/16 npt tap too if something needs made.
¯\_(ツ)_/¯
¯\_(ツ)_/¯ PowerDork
10/19/19 3:13 a.m.
Alright, so technically this AN adapter and a line to go from it to the fuel solenoid are all I need, but I'm Bob Costasing out on the nitrous anyway.  Why?  I'm not convinced this engine arrangement will survive nitrous in the first place- it's the wrong ECU, has some sort of intake manifold adapter, on a plastic manifold, occasionally sputters at low RPM, always sputters when tipping into the throttle, and burns some oil.
I've already lost most of a day to this and now it's got me awake at 4am when I really didn't want to be- I think this idea has gone from "LOL Roadkill" stupid to actually stupid.
Patrick
10/19/19 5:13 a.m.
You don't want to try and spray down to a 17.2?
¯\_(ツ)_/¯
¯\_(ツ)_/¯ PowerDork
10/19/19 8:01 a.m.
And then oil down the track 1000mi from home trying to reach for 16s with no trailer?  Not particularly cheeky
Andy Neuman
Andy Neuman SuperDork
10/19/19 9:25 a.m.
In reply to ¯\_(ツ)_/¯
Plenty of PA people coming to ride back with...
bluej
bluej UberDork
10/19/19 9:35 a.m.
Sometimes Betsy just fights ya. She must have known it was a bad idea.
¯\_(ツ)_/¯
¯\_(ツ)_/¯ PowerDork
10/19/19 11:52 a.m.
Must be opposite day- I usually modify stuff and get it dirty but I'm removing mods and cleaning instead.  Shiny!
¯\_(ツ)_/¯
¯\_(ツ)_/¯ PowerDork
10/20/19 9:41 a.m.
Fun fact: a c5 wheel nests almost perfectly inside of an i3 wheel, and a meinl cymbal bag makes a great anti-scuff feature for the front of a nicely painted 20" wheel:
I'm really hoping the tarp doesn't make this look too "rolling probable cause" once I've got it all wrapped up and bungied down, because I really won't want to unwrap it more than once.
RfRJiyztIWuepXchAsKZqLbvCjchGfSa8r9CBVgujqWhuWUk9vE5eGAHtH7n1W3P
