1 ... 9 10 11 12 13 ... 19
SRPe_Matze
SRPe_Matze Reader
3/17/23 7:26 p.m.
tailor made for me
BigIron
BigIron New Reader
3/17/23 9:07 p.m.
What sort of ride height and wheel travel are you looking at?
SRPe_Matze
SRPe_Matze Reader
3/18/23 8:56 a.m.
currently no suspension is installed.  one bar per wheel currently determines the neutral height.  the ground clearance is then 3 inches.
the poles are very suitable for the actual height during the construction phase. I have a high spring rate, which already takes aerodynamics into account.  it is a GT3 version and initially serves as a base.  the optimal spring rate is determined in the test.
here the original of a GM Racing Corvette C5-R
SRPe_Matze
SRPe_Matze Reader
3/20/23 7:13 p.m.
SRPe_Matze
SRPe_Matze Reader
3/22/23 7:01 p.m.
SRPe_Matze
SRPe_Matze Reader
3/26/23 1:13 p.m.
SRPe_Matze
SRPe_Matze Reader
3/31/23 4:13 p.m.
bigger is better
SRPe_Matze
SRPe_Matze Reader
4/1/23 3:17 p.m.
Negative : first sandpaper finish
Step by Step
SRPe_Matze
SRPe_Matze Reader
4/5/23 6:15 p.m.
SRPe_Matze
SRPe_Matze Reader
4/13/23 3:20 p.m.
finished painted
SRPe_Matze
SRPe_Matze Reader
4/14/23 4:02 p.m.
Grunion
Grunion New Reader
4/15/23 9:44 p.m.
Absolutely stunning work! I can hardly wait to see it run. Let us know when?
SRPe_Matze
SRPe_Matze Reader
4/16/23 9:25 a.m.
Thanks.  I just enjoy fulfilling my own wishes.  maybe I spread courage and motivation.  the first trips are scheduled to take place later this year.  I hope I will make it.  its a lot to do.
SRPe_Matze
SRPe_Matze Reader
4/16/23 4:33 p.m.
white_fly
white_fly HalfDork
4/16/23 10:23 p.m.
Thanks for posting all these in progress shots. Your parts look incredible.
SRPe_Matze
SRPe_Matze Reader
4/17/23 5:37 p.m.
I hesitated for a long time.  Now I'm glad I made the effort.  The first step is done.
SRPe_Matze
SRPe_Matze Reader
4/19/23 6:14 p.m.
SRPe_Matze
SRPe_Matze Reader
4/22/23 1:24 p.m.
SRPe_Matze
SRPe_Matze Reader
4/23/23 3:21 p.m.
SRPe_Matze
SRPe_Matze Reader
4/23/23 6:21 p.m.
SRPe_Matze
SRPe_Matze Reader
4/24/23 4:54 p.m.
Carbon Part 1
SRPe_Matze
SRPe_Matze Reader
5/15/23 5:30 p.m.
Rear window covered with black foil. To do this, mark the cutting line horizontally with the laser. this is what is always done wrong with curved window panes.
SRPe_Matze
SRPe_Matze Reader
6/3/23 4:19 a.m.
finally something is working again. the 2nd set of rims made to order is here.
390mm discs in 18 inch rims.
SRPe_Matze
SRPe_Matze Reader
6/8/23 4:34 p.m.
SRPe_Matze
SRPe_Matze Reader
6/10/23 3:49 a.m.
DVu52Jy3ReTs0qcp8cVSxtobxJF0teYlVnVVNddI3kz3IPJyCvcRmX1BnNinbntn
