1 2 3 4 5 6 ... 19
SRPe_Matze
SRPe_Matze New Reader
1/7/22 2:02 p.m.
you can basically ask anything.  but I have to write with the translator.  First question racetracks.  I drive Dijon, Eurospeedway, Hockenheim, Monza, Redbullring ec.
SRPe_Matze
1/7/22 2:09 p.m.
to the exhaust.  Built like a Z06 exhaust.  With flaps.  however, these are controlled electrically with a stepper motor via software and GPS.  Depending on the noise regulations on European racetracks.  All pipes are also 3 inches inside and there is more insulation and perforated pipes.  The volume of the damper is slightly larger.  the tailpipes achieve a venturi effect, a DB killer and flow through inside and outside.  nothing is just optics.  everything makes sense.
onemanarmy
onemanarmy Reader
1/7/22 2:12 p.m.
That escalated quick!
This is why I read this forum.   Keep it coming!
SRPe_Matze
1/7/22 2:19 p.m.
I have a lot of fun building it like this and have learned a lot.  taught me a lot during this time and made dreams come true.  there are no obstacles, just different solutions to one goal.
SRPe_Matze
1/7/22 2:24 p.m.
With the combination of sequential gearbox and Winters QC differential in a Corvette, I should be number 3 in the world.  there are still Samsonas (Lithuania) and RTS (USA).  probably unique in a C5.  As a provider of a complete kit, I am also the most expensive.
SRPe_Matze
1/7/22 3:02 p.m.
the spindle was also a dream come true.  The goal was bumpsteer attitude.  without stability and good ventilation of the brake.  the part should do without an adapter.  simulated tested up to 3 tons and 3 G durable.  but also 4x as expensive as commercially available accessories.
SRPe_Matze
1/7/22 3:16 p.m.
SRPe_Matze
1/7/22 3:49 p.m.
SRPe_Matze
1/7/22 3:53 p.m.
SRPe_Matze
1/7/22 3:59 p.m.
SRPe_Matze
1/7/22 4:01 p.m.
SRPe_Matze
1/7/22 4:08 p.m.
Double thermostat better than factory GM Racing
SRPe_Matze
1/7/22 4:11 p.m.
SRPe_Matze
1/7/22 4:14 p.m.
SRPe_Matze
1/7/22 4:17 p.m.
SRPe_Matze
1/7/22 4:45 p.m.
8x 62mm
SRPe_Matze
1/7/22 4:48 p.m.
SRPe_Matze
1/7/22 4:52 p.m.
14 Kw self-built preheater.
SRPe_Matze
1/7/22 4:58 p.m.
wow, nice execution!
SRPe_Matze
1/7/22 5:37 p.m.
SRPe_Matze
1/8/22 5:00 p.m.
SRPe_Matze
1/8/22 5:03 p.m.
SRPe_Matze
1/8/22 5:14 p.m.
SRPe_Matze
1/8/22 5:17 p.m.
1 2 3 4 5 6 ... 19
7ltlVjkv8iM6ruF32k7K6UILjDgkQyWhSvbIT8qIVxDtmQkHSG444BPGPIg9Afza
