With all the work out of the way, it was finally time to race this freaking thing!! Saturday was a test and tune, and the race was on Sunday. Since I still have my old rally wheels and tires from the E28, I decided I would use them up for the TNT and save my newer, nicer tires for the race. Thankfully, I can somehow fit 6 wheel/tires in the back seat!
I had some time before it all started to fix two little issues in the most rally-x way possible. The crappy intake that came with the car doesn't seal very well, so someone whipped out some aluminum tape and we sealed it right up! The intake tube was also moving around a little too much in its heat shield, so half of the cardboard roll of aluminum tape came to the rescue. This is next level stuff right here people!
With the old wheels on the back and the new ones on the front, it was time for more pretty pictures!
Then it was time to take it out and see what it could do. The test course was tight and rough, but the M3 felt pretty damn good considering! After a few runs, the rear "diffuser" fell off, but no biggie. I turned the car off for a few minutes to go and do something or other, and hopped back in to get going again. Unfortunately, I was greeted by a CEL and a low coolant warning. Crap!
Oh no, this isn't good:
It looks as if a zip tie that was holding up the upper radiator hose broke which caused the hose to fall down into the fan, which then proceeded to explode itself all over and into my nice aluminum radiator. This is not good. I frantically searched all the local parts stores (remember, we race in the middle of nowhere) and of course none had a radiator or fan. After calling Josh, he called Jim, who happens to have an E36 M3 as well. Long story short, Jim came through in the clutch and pulled his nice Behr Z3M radiator and Bimmerworld electric fan kit off his chump car and brought them with him the next morning! Then I called Brian up for one more favor- could he pick up my special fan clutch removal tools from my house, along with all my BMW coolant and distilled water? Well sure, of course he could, because Brian is awesome!
With that all figured out, it was time to get the car ready for the new parts that would arrive in the morning. Shawn and Katie let me park the car on their trailer overnight so I could get easy access to everything. This is one instance in which an open deck trailer is awesome!
The Pelican and Bentley books both say you have to remove the fan before you can get the radiator and shroud out, but I guess with no fan blades I had some extra clearance. Great success!
Much fail....
Look, the parts fairies left me goodies!
Boom, installed and burped with minutes to spare! Big thanks goes out to Jim for bringing the radiator and fan and for helping do the wiring while I did other things, to Josh for helping with wiring, and to Brian for grabbing stuff from my house. I couldn't have done any of it without you guys!!
Well, it was finally crunch time. How will the car do out there? I got the car up to the line, launched, and then.....nothing. It felt like the car had 10 HP. WTF??? Did I somehow blow the motor up? Oh wait, what's the flashing on the dash? Oh right, the traction control light. I better turn that off. Ahh, much better! On my second run I was feeling more confidant and the car felt great out there. Steering was tight and responsive, the suspension was absorbing everything, and I had more power than I knew what to do with. BANG! What was that? Hmm, I must have bottomed out or something. I pulled in and immediately knew something was wrong, as the back of the car was sitting way too low on the driver's side.
berkeley.
And just like that, my fancy articulating Rogue Engineering rear spring height adjuster failed, the spring was sitting cocked, the top plastic perch had fallen out, and the car had clearly bottomed out very hard.
Yeah, those threads stripped right off! I guess these aren't rally tough.
Oh, but the carnage didn't stop there. There is not supposed to be this gap at the top of my Bilstein struts. I really hope this doesn't mean it's blown. I was able to tap it back down with a hammer, but I have no idea what's going on inside the shock. Can anyone speculate on what happened here? I assume these are gas shocks....does this mean it's now depressurized? Or was this just the bumpstop going up way higher than it should have. Or both???
I then checked that strut tower, and it appears as if some paint flaked off, and I'm pretty sure there's a tiny crack now. berkeleying great!
Thankfully, Josh came to the rescue again with a spare 8" 300 lb spring he had lying around, so I threw that in and drove home.
F-ck. This. S-it.
Oh, and to top it off, the car started stalling at idle when I had the AC on during the drive home, which it's never done before. And I'm also getting some whine through the speakers with the AC on, which is also a new problem. I wonder if the compressor is going bad.....WTF.
