1 ... 6 7 8 9 10
roninsoldier83
roninsoldier83 GRM+ Memberand HalfDork
9/28/24 4:10 p.m.
After doing some more research, I'm retracting my previous statement about removing the entire subframe when I install the new oil pan on my own car (to give myself some extra space). There's a very substantial amount of work to be done in order to fully remove the front subframe.
Yesterday in the junkyard, while the subframe was dropped per se, I could have done more to drop it further without the need for a full removal- namely I could have removed the front sway bar mounts and the front coolant hose that's bolted to it, which, I believed, would have dropped the front portion a good bit lower. It also probably didn't help that someone had removed the transmission mount(s), so the powertrain was hanging very low in the engine bay, giving me less space between the engine and the subframe, while also making me a bit more fearful of disconnecting more things to avoid being crushed by an engine in a junkyard.
While watching this video, I noticed that he appeared to have quite a bit more room to work with than I did yesterday, leading me to believe I likely won't need to remove the subframe entirely:
roninsoldier83
9/29/24 1:42 a.m.
After watching all the things on the YouTube, for a RWD car, this video was by far the most detailed, efficient and informative:
For any AWD guys- woe is you- I've watched the FCP Euro oil pan gasket swap video on an AWD car- good night! The RWD version appears to be a cake walk by comparison.
newold_m (Forum Supporter)
newold_m (Forum Supporter) Reader
9/29/24 10:38 p.m.
On my N54 E90 I did the oil pan gasket replacement twice due to leaks. first time was during Covid where I wasn't driving the car much and had all the time so dropped the subframe and while replacing the gasket again (seriously BMW!) more recently kept the subframe in place, but lowered it to fish the oil pan out. Honestly while dropping the subframe was more work initially, overall frustration level was lower and all the bolts were readily accessible but YMMW.
One thing I would recommend especially if you're planning to track the car is check your coolant expansion tank. Mine cracked a couple weeks ago and made a big mess, luckily it was after I had parked and shut the engine off so, other than a big mess, no harm was done. FCP has Febi replacements for $70 and it's an easy replacement. While there also replaced the cap with an OEM for peace of mind. This was on a 2009 with 113k miles --  granted with the turbos all the underwood plastics are subjected to more heat cycles.
roninsoldier83
9/30/24 9:53 a.m.
In reply to newold_m (Forum Supporter) :
Thanks for the feedback!
I suppose I'm not attached to either method (fully removing vs just dropping the subframe). I suppose I was just trying not to have to remove the tie rods/control arms/steering rack if I don't have to. If I get in there to start working and the frustration level results in my blood boiling there's a good chance I'll just take the whole thing out. We'll see. I'm in no rush.
The last time I took a peek at the overflow tank I didn't observe any noticeable wear, but it certainly won't hurt to check again. I might just replace it when it comes time to install the OEM N54 oil cooler sitting in my garage, as I'll be draining the coolant anyway. I haven't really heard of N52 folks having that problem (less heat on that side of the engine bay?), but you never know!
roninsoldier83
9/30/24 9:27 p.m.
For the record, the OEM drain plug bolt is M12x1.5:
^^^That's a Febi replacement from FCP Euro. Also, there was absolutely no need to chase the threads. I just cleaned them with a wire brush and the new bolt/plug screwed right in, smooth as butter.
I almost forgot I've had an OEM aluminum oil pan sitting in my garage for about a year now. I bought it for dirt cheap before I knew that the manual cars had steel pans.
I took a few photos of them side by side:
This is the BIGGEST difference between them- the aluminum pan bolts to the transmission, whereas the steel pan does not:
While aluminum has a higher thermal conductivity and should in theory remove more heat from the oil, in this particular case, it certainly isn't lighter. I weighed both of them using my cheap bathroom scale:
Aluminum pan= 10.4 lbs
Steel pan= 8.4 lbs
The steel pan is actually 2 lbs lighter.
I'm sure the aluminum pan would remove just a bit more heat than the steel pan (who knows to what degree), but I wouldn't exactly say is has any heat removal fins on it (like my S2000 does).
Interesting facts: according to BMW parts websites, they have the same MSRP prices (although the used aluminum pans are dirt cheap on eBay and there's a boatload of them by comparison). On sites like Rock Auto, the aftermarket aluminum pans are less than half the cost (some as little as a quarter of the cost). Maybe it has to do with production numbers? Or the odd shapes that BMW intentionally dented into the steel pan?
Either way, just figured I would share my findings.
roninsoldier83
11/11/24 1:14 p.m.
Well, I'm once again thinking about selling the 128i. Yeah, I know.
I am losing motivation to really build it into a track car. I'm just burnt out on constantly building track cars, from both a financial and physical perspective (I've finally healed my back and am back into heavy calisthenics/working out- I would like to keep it that way). I've had some fun tracking cars over the years, but I don't believe I want to travel down the hardcore track car build again.
And as far as a fun street car goes, well, I made that a much tougher proposition by purchasing my F87 M2 not too long ago:
^^^On its own, the 128i is a great street car. I found myself taking it frequently in my previous lineup of cars, as it certainly felt more streetable than my previous S2000, while still being a fun machine. Now? Well, the problem is, the M2 is good. Really, really good- at pretty much everything. On the street, for just about anything I want to go and do, I've found myself leaving the 128i parked and just grabbing the keys to the M2 (sans snow driving). It feels similar to the 128i, excepted upgraded in pretty much any way you can think of. The 128i has a bit better steering feel, but otherwise, the M2 is better in every way- FAR more power (especially at our elevation), better suspension, better diff (you can feel it), better shifter, better brakes, quieter, just as easy to drive, far higher fun factor, etc.
For a daily, I technically have a work car. For a semi-daily, or more relaxing car to drive, the Mazda 3 Turbo is a nicer, newer, more relaxing place to be. For a fun/spirited drive, no question, the M2 is hands down more fun.
Which has led me to the conclusion: if I'm not going to track the 128i, I should really sell it. I hate that I've put so much time, money and effort into it, only to sell it, but I would hate even more to just leave it parked and collecting dust while I'm paying insurance on it. It should probably go to someone that will use it more than I will.
EchoTreeSix
EchoTreeSix New Reader
11/11/24 2:16 p.m.
In reply to roninsoldier83 :
My wife is going to kill me if I show her this car again. Save a life and keep it LOL.
I get it though. M2 seems like the next step from the 128i. Just like the 128i would be a step up from my car. berkeley.
roninsoldier83
11/11/24 2:45 p.m.
In reply to EchoTreeSix :
LOL, sorry brother. I just posted it for sale locally. I don't have much faith that it'll sell anytime soon- it's a RWD coupe in Colorado and we just got over a massive 3 day snowstorm lol. There's a good chance it'll be around until at least the spring time/tax season.
Problem is that the 2-series is essentially just a newer 1-series. The M2 and 128i have nearly identical usability, seats, seating positions, etc., so neither of them is more likely to be driven more often based on usability, but the M2 is actually a substantially nicer, quieter car to drive (minus the sweet exhaust sounds!), and when it comes to fun, it's not even close. The 128i is really good, but I think the F87 M2 is likely the most fun BMW M-car I've ever driven.
If I had a larger garage, I might consider keeping it, but as of now, I only have 3 garage spots, which are taken up by the M2, the wife's Challenger Scat Pack and my Mazda 3 Turbo. I could park the Mazda 3 Turbo outside, but it doesn't make any sense- the Mazda is much newer, far lower mileage, worth roughly ~2.5 times more money, still has a warranty, etc. If I had a larger garage, I would park the 128i inside and simply cancel the insurance on it while it's not in use... but sitting outside, I'm paying full coverage on it while it sits in the elements. It doesn't make a whole lot of sense to keep paying for insurance, registration and maintenance on a car that's just sitting outside, not being driven.
adam525i
adam525i GRM+ Memberand SuperDork
11/11/24 6:13 p.m.
I think it is the right call, hopefully the 128i goes to someone that appreciates the time and energy you put into it and can really enjoy it.
If/When you get the track itch (you know, when the snow is gone in the spring!) the M2 will handle that with ease as it sits without a bunch of time and energy to get it "track ready"
Good luck with the sale!
roninsoldier83
11/11/24 8:46 p.m.
In reply to adam525i :
My thoughts exactly. The M2 has a dual oil pump system (pretty much eliminates oil starvation with any tires you can think of), an overbuilt cooling system (both oil and water/coolant), an outstanding rear diff and giant OEM brakes- it's essentially track ready out of the box. I don't want to build a hardcore track car anymore (if I did, I would keep the 128i), but for the occasional fun open lapping or autoX event here or there, the M2 is already built for it. I don't anticipate getting back onto a track anytime soon, but if I changed my mind, the M2 is a good place to start, as it seemingly requires next to nothing- maybe just pads (maybe?) and fluid?
And now starts the process of dealing with the long string of questions from tire kickers... my brain hurts already lol.
roninsoldier83
11/13/24 6:49 p.m.
I'm hitting the pause button on selling the 128i (again).
Over the past year (maybe longer), I've been a bit lost. I got into racing cars (autoX and time trials) years ago, which brought out my innate competitive streak. I lost sight of why I went down that path in the first place and somewhere along the way, it stopped being fun. I even made threads about giving it up altogether:
https://grassrootsmotorsports.com/forum/grm/do-any-of-you-ever-think-about-giving-up-this-hobby/258924/page1/
In recent years this hobby has brought me far more pain than it has pleasure. For all of my inherent overthinking, I've struggled to articulate what I've been looking for. For the first time in a while, I started journaling today. I almost forgot how helpful it is to write out my thoughts and feelings. It helps me to sort them out and forces me to dig a bit deeper. The following is my entry for today that I figured I would share in this thread, to help explain all the things, probably not to anyone reading, but more to myself. Read at your own risk:
Today I am at another crossroads with this car addiction of mine. I do not want to obsess with building, buying or selling cars, 24/7. I do not want to be constantly in debt buying the latest XYZ car parts just to be competitive in some league. I do not want to spend all of my time in the garage, hurting my back and destroying my healthy workout and spontaneous date night habits. I’ve always been the type of person to hear about something interesting, no matter how random, and head in that immediate direction with a smile on my face. The idea of a strict competition schedule also doesn’t seem terribly appealing at this point in my life- getting up at 5am on my days off, driving halfway across the state, walking an autoX course for an hour, trying to eek every last ounce of performance out to try and stay competitive, stressing over not being able to make an event due to my other more important priorities- my family, my profession and just living my life in general.
However, that doesn’t take away from a passion of mine. A passion for driving. A love for vehicles. I just don’t want the constant car-building, or car buying/selling obsession anymore. I don’t want to spend all of my time, money and effort on them, just to keep selling them, buying new ones and starting all over again. I no longer enjoy the cycle.
I’ve given some thought about what else I would like to do. Competitive racing might not be in the cards right now, but that doesn’t mean I can’t have a hobby. A passion I chase that helps make life worth living. I’ve talked it over with my poor wife and the small group of people I call friends, pondering what else I would like to do with the excess mental energy that builds up on a regular basis? Then it hit me: not only do I have a passion for driving, I have a passion for writing. I am my mother’s son. That woman was a beautifully creative writer, journaling all of her adventures, thoughts and memories for years, eventually forming them into a book. For all who have read through my long-winded, get-to-the-point word-salads and car reviews, well, I blame her.
With these things in mind, a plan is slowly forming. A plan that involves keeping my lowly BMW 128i.
I think I’m going to start a blog. Maybe travel to different tracks around the country. Learn to take photos, journal my experiences. There are so many tracks I’ve thought about driving on, from the time I first played the original Gran Turismo games as a kid. Why not make a point to start visiting these places? But not in a strict competition with an uncompromising schedule. Turn them into vacations. See the countryside. Stay in random hotels, drive all the tracks I’ve seen on a screen but never experienced in real life and in the evenings experience everything the local areas to these tracks has to offer. Take as many photos and make as many memories as possible, and when I’m good and worn out, sit down behind a keyboard.
Now that I’m thinking about it, a plan is starting to formulate:
1. Start my own blog/website. I honestly don’t care about clicks or views. I just like to experience life and write about what I’ve seen, even if no one actually reads it.
2. No need to make the 128i super competitive. No need for all the power, or the stiffest suspension, or the widest tires. No need for anything that would ruin it as a street car. Just the necessities to keep it alive and running under stress (the baffled oil pan and oil cooler in my garage are probably a good idea). Honestly, with all the prep I've done over the past 1.5 years, the car doesn't need much else.
3. Start planning the journey. Where I/we want to go. What we’ll do when we get there. Schedule some time off (I think I currently have around ~700 hours of time off collectively at work- I really need to start burning more of it!), grab the keys and make memories. I’ve run entirely too many laps at Laguna Seca in video games to have never seen it in real life… and I’m sure there are plenty of sights to see and new foods to try when we get there!
4. Maybe occasionally sign up for a performance driving school- I’ll admit, I’ve enjoyed every driving school I’ve ever been to and always like getting better, even if there’s no trophy at the end of the season!
5. Every once and a while, do something to the car. Maybe once a year, have a mild project to make it just that much more fun, without getting out of hand or ruining it for cross-country duty.
6. Learn to take more photos. Maybe actually put some time into learning how to take photos that don’t look like complete garbage.
7. At the end of every adventure, write it down. Capture the memories.
I'd like to say that I’ve been looking for a purpose for this stupid BMW, but I don’t think that’s accurate. I think it’s more accurate to say that I’ve been looking for a purpose. After months of contemplation, I think I might have found what I was looking for.
When I come up with a catchy name and actually start the site, I'll be sure to share with my fellow GRM'ers that might be interested in following along.
roninsoldier83
11/22/24 5:35 p.m.
A few updates:
-Hagerty agreed to insure the 128i! I was told again that it's not a car they insure, but the lady I worked with was wonderful and made an "accomodation" to insure it based on projected usage, combined with my already having another BMW on the policy (the M2), she was able to apparently make an argument and they insured it! So, it's now only costing me ~$300 a year, which is a MASSIVE savings over what State Farm was charging me (about 1/4 of the price). At this cost, I don't think I can justify selling the car. Registration is only ~$70/year and all major maintenance items have been done, likely for years.
-I recently went back thru the high powered car wash... not a drop of water inside the car! All the work I did fixing the leaks worked! I figured it was good to go after driving through that heavy downpour a while back, but it's been confirmed- all leaks solved!
-I did start a blog. I've actually never setup a webpage before, so it's a lot to take in. I'm slowly building it and I'll post a link when I feel I've ironed all the things out and added some relevant content.
-I recently took the E82 down one of my favorite driving roads- Deer Creek Canyon. I made a few stops, taking a few photos. This is a good looking little car:
roninsoldier83
11/24/24 2:56 p.m.
Well, I'm still learning blog/webpage things, but I've started the blog. I decided to call it Investigating The Apex.
A lot of the blog content over there initially will be pulled from quite a few posts here on GRM, but instead of being spread out among dozens of posts over 1.5 years, I'll be consolidating them into something more cohesive with a good bit more creative writing and humor.
I also started a FB page essentially just to post things: https://www.facebook.com/profile.php?id=61568812061078
I currently suck at this webpage nonsense, but I'm sure I'll graduate to almost-not-terrible at some point.
roninsoldier83
11/29/24 7:58 p.m.
I've caught up on most of the content in this thread, adding most of it to the new blog.
I've put a ton of work into it, trying to break things down into posts that are more logical in nature, to make it easier for people to read. I've also tried to add more humor and more of a story telling element.
I created an entire section just for the E82, to make the story easy to follow.
Feel free to stop by, take a peek and offer any feedback you can come up with:
OHSCrifle
OHSCrifle GRM+ Memberand PowerDork
11/29/24 11:39 p.m.
Blog is looking good.
roninsoldier83
12/3/24 10:46 a.m.
As I have no welding skills or equipment to speak of, I enlisted the help of my buddy Justin at https://mototechniq.com/ to weld the Condor Speed baffle into my steel N52 oil pan, following video instructions provided by Condor Speed. He's a knowledgeable fabricator and did solid work on my pan- he even tried to teach me a thing or 2 about prepping and welding in the process! I've really got to stop procrastinating and learn to weld one of these days!
The pan is now good to go! Now all that's left to do is the actual work of installing it lol. It'll probably be a couple of months before I buy all the necessary hardware/gaskets and muster up the courage to drop the subframe and get this done.
Condor Speed instructions:
roninsoldier83
roninsoldier83 GRM+ Memberand Dork
3/7/25 8:50 p.m.
I've been putting this off for a few months now. It's time to drop the subframe and get this done.
I've cleaned up the baffled oil pan and got it ready to slap on a new gasket and bolt it right back up, with no interruptions.
It cost a decent amount of extra money, but I ended up ordering new OE motor mounts- "while I'm in there" things, and all new hardware for pretty much anything I could possibly remove. I believe all of their hardware is one time use only stuff. I'm sure there's quite a bit of it you could get away with re-using, but I really only want to do this job once (knock-on-wood).
I'll be taking my time over the next day or 2. Or 3. We'll see how much of a job this really is.
roninsoldier83
3/9/25 3:26 p.m.
We got the new-to-me baffled oil pan installed yesterday. My good friend Justin, at https://mototechniq.com/ was there for most of it. It took us about 9-10 hours. It was a fairly rough job, mostly due to the baffled pan.
Of all the video tutorials I watched on Youtube, assuming you ignore the AWD version that FCP Euro put out (the AWD cars are far more complicated) this one seemed the most comprehensive and easiest method for replacing an oil pan gasket on a RWD E82/E90:
https://www.youtube.com/watch?v=cZmrullsryc&t=2632s
Which makes sense, as the installer appears to be a BMW tech that knows how to get the job done in under book time. For reference, the car in that video is an automatic which has several transmission lines that complicate the job, which are not found on the manual cars.
Unfortunately, I wasn't able to follow that method. For reference, following that method, before Justin showed up to help, I had the oil pan out in ~3 hours, taking my time. Everything was going smoothly.
Honestly, if I was just reinstalling the stock pan, I could have shaved 2-3 hours off of the install time. Unfortunately, when it came time to install the baffled pan, it couldn't be installed as easily as the stock pan due to the baffle plates contacting the oil pickup.
Allow me to try to [poorly] explain.
Following the method in that video, you have to tilt the front of the oil pan down in order to get it to clear the oil pump. You then have to slide the pan a bit forward to get the "ears" on the back of the pan to clear the slots in the transmission backing plate. Here is a quick photo of the ears I'm speaking of:
By minimally lowering the subframe and raising the engine with the engine support bar, I was able to gain enough room to remove the stock oil pan no problem. When I tried to put the baffled pan back in using roughly the same technique, I couldn't get it seat, no matter what we did, as the baffle plate was coming in contact with the oil pickup. We needed more room to install the pan at a nearly level angle. Things got more complicated.
In order to gain the necessary clearance, we disconnected the control arms, the steering rack and pinion, the front sway bar and those pesky T30 torx bolts that hold a small coolant pipe to the top of the subframe. In retrospect, it's not much more work to just fully remove the subframe. Once we had considerably more room, we were able to install the baffled pan using a different angle of approach and get everything seated and torqued down.
Likely because we had unbolted just about everything and moved everything around so much, re-aligning the front subframe was a job that took a bit of muscle and brain power. I was surely grateful to have a second set of capable hands to get everything lined back up.
To keep track of what was torqued down, I used a light blue paint pen to avoid getting confused.
I also installed the new OE Corteco motor mounts. The stock motor mounts were actually in really good shape, but I figured I didn't want to drop this damn subframe again, so I might as well just replace them.
Once we were done, I filled the engine full of ~7 quarts (6.9 is specified) of oil, crossed my fingers and fired her up- all was well!
I drove the car for about 15-20 minutes last night and it drove just like it had before. I then left it overnight and checked the pan this morning... to my complete and utter surprise, I didn't see any signs of a leak anywhere! Success!
I'm feeling pretty beat up today, but I'm glad we were able to get everything done.
When I get some more free time, I'll do a more in-depth write-up on my blog and post it here.
3/9/25 4:46 p.m.
Yeah, it's definitely a job that take a toll on you... I did it twice on my E90 in ~6 years and, while not technically difficult, it's cumbersome and tiring.
roninsoldier83
3/10/25 10:09 a.m.
Twice in 6 years? Ouch! That seems excessive! Any idea why you had do to that job twice in only 6 years?
Honestly, if I was just changing the gasket, it's a tiring job, but a good bit less work if you can get the pan in and out while following the instructions in that video. If it wasn't for needing additional room due to the baffled pan hitting the oil pickup, I could have gotten the job done 2-3 hours earlier with a good bit less exertion.
roninsoldier83
3/10/25 7:13 p.m.
I finally finished the blog post. It literally took me all day to write this thing, but I tried to make it as comprehensive as possible for anyone considering this in the future:
roninsoldier83
3/10/25 9:29 p.m.
Someone on a completely different forum just pointed out to me that apparently my lowly 128i was actually in GRM magazine!
I have no idea which issue this is and if I still have a copy of it. Any idea how to find out which issue this was in and if I can order a (another?) copy?
3/11/25 1:46 a.m.
Wish I knew why it failed the 2nd time but certainly wasn't fun doing the job again.. First time was during Covid so I had all the time in the world to work on it. Plus back then car was new-to-me and I was actually interested in working on it. When I had to fix it again recently I didn't cut corners but just wanted to get it done.
rdcyclist
rdcyclist GRM+ Memberand Dork
3/11/25 1:15 p.m.
Should/could you have replaced the rod bearings then? Is that an issue on the S52's?
Also, I thought you were selling the BMW...
roninsoldier83
3/11/25 4:06 p.m.
I suppose I could have replaced the rod bearings while I was in there. While the rod bearings seem to be a problem area on some of the N5x motors, I haven't really heard of them being a problem on the N52. Plenty of N52's on the stock bottom end with over 300k miles on the clock. Not to say that track work can't accelerate wear, but my 128i "only" has 139k miles on the clock and feels healthy. I probably shouldn't think this way, but on an S54 or S65, I absolutely understand being on top of rod bearing maintenance- they're rare expensive motors and I would be paranoid about the bearings... the N52? Well, I don't want anything to spoil a track day, but these are pretty much $500 junk yard engines. laugh
I have a bit of an automotive ADHD problem. I see shiny things and want to switch platforms frequently. I've put the 128i up for sale twice in the past year and took it down both times within a day or two. This is the only car I've ever done that with. Part of the problem is that for the money I think it's worth, the market might not agree and I'm not willing to part with it for some lowball price to some halfwit who wouldn't understand the work I've put into it.
And well, I can't get rid of it now... I just ordered another parts cannon:
-Apex wheels
-RT660+ tires
-Hawk ER-1 pads, new rotors, brake lines & fluid
-Camber plates
-The last of the misc. parts I need to install the 135i oil cooler sitting in my garage
-I also bought an Android tablet so I can download ProTool and start turning off these pesky nannies.
And the car just passed emissions yesterday. I was concerned with them scanning the DME and finding my *gasp* "aftermarket tune" and throwing a hissy fit, but I don't even think they bothered to check.
I bought this car two years ago with the intention of putting it on track. Then I started using it as somewhat of a "daily". Then I bought the Mazda 3 Turbo, which is a better daily. At this point, I'll be damned if I didn't put all this money into this pile of bolts to sell it before I've actually tracked it.
Also: the last time I put the 128i up for sale and took it down, I started my blog immediately thereafter. This thing makes for good content, even if no one really reads it haha!
1 ... 6 7 8 9 10
AOQVrzPfsaueFIEawmyZCWavufKytnFcWUlky8UZvtFgK9omspInkLNF5gt8pE9P
