Those were pictures of what was the front dinette/bed, galley, and rear- all gone.
We did what everyone says not to do- buy a project, and gut it. I was quite worried about it's structure with all the cabinets gone (other than some upper ones). But it turns out to be VERY stiff, still. Whew.
What's going to probably happen- the old water closet will become a wet bath. Which will be TINY, but w/o a curtain, I think it will be pretty good. Low ceiling in the back will suck, but I'm going to put in a sky light in the bath (which were in the two we've rented).
The trailer has three levels- one just barely over the ground, one 3 in higher (to accommodate axle travel) and one 3 in even higher. The highest part is shorter than me, so I'll be stooping. But it's not an area that I would be hanging out- so that should be ok. Or at least an ok compromise.
The front will have a queen-ish bed that is a tri-fold- so it won't be out all the time, but it can be made all the time. Behind it will be some kind of dinette, and then the we bath. The other side will have some cabinets next to the bed, then the new galley, and some storage in the back.
When it gets closer to being done, I do plan on adding some lifting shackles to give a little more ground clearance. And a nice vent fan (which it does not have)- so it still has to end up being under 7'11".
Going to update every other support- new water tank (adding gray and black that didn't exist), new water heater, new electrical system (lighten the 120V load, up the 12V loads), new gas lines (old ones were a mess). And the frame needs cleaned up.
Lost a few nights worrying about it, but the more we get into it, the more I think it will turn out pretty nicely.
Still have some gutting to do- live removing the crappy ceiling material- fiber crap. It will be replaced with fiberglass reinforced plastic panels- so just a little less ugly. But nice and reflective, won't break down over time.
Odd how they built things in the past- start with the trailer bed, put down the flooring, add walls right over the floor, add ceiling material, put roof over that. Which means over time, everything has settled- the plywood on the frame settled on the fiber insulation panels on the frame, the walls have pushed down the flooring, the ceiling really pushed down the fiber ceiling panels. Some of that will be replaced so the roof will go up just a little. But this company didn't last too long making travel trailers- just 3 years from what we can tell- 71-74. Which closed a decent pop up trailer company that started a decade earlier.
Almost no information out there about Wheel Camper trailers, but funny that there is another here in SE MI for sale on FB. It helps that these were born here, maybe? (Centerville MI).
