enginenerd
enginenerd Reader
11/7/17 9:00 a.m.
In reply to Jaynen :
Probably just indicative of needing a valve cover gasket. Check the pcv system as well and make sure everything is working ok.
While you have the cover off, you should probably change the cam position sensor O-ring. Those tend to leak oil on the heater hoses.
Jaynen
Jaynen SuperDork
11/7/17 12:25 p.m.
Changed the map sensor out this morning and the CEL is gone. So one step closer to street legality
Jaynen
Jaynen SuperDork
11/7/17 4:48 p.m.
Airbag light still coming on after installing this
http://www.projectgla.com/main/product/mazda-miata-airbag-defeat-srs-cancellation-for-aftermarket-steering-wheel/
Not sure what I am missing its flashing 2 then 6 which I think is control unit/drivers side airbag
Dusterbd13
Dusterbd13 MegaDork
11/7/17 5:21 p.m.
Check both airbags to make sure they are actually connected, and actually airbags. If you need a pair to plug in to rest, let me know.  I ain't that far from you after all.
Jaynen
Jaynen SuperDork
11/7/17 6:22 p.m.
There was definitely an airbag in the NB wheel I removed it and put the plug i linked above into it and then put it back unplugged but its blinking the same as before so not a different error or whatever
Jaynen
Jaynen SuperDork
11/15/17 4:42 p.m.
Car has paper plates need to reset all the drive readiness stuff to get it tested. Ordered a new AC and PS belt, valve cover gasket, cam o seal thing, and heater core hoses.
Do I need to drain the radiator to change the heater core hoses? Probably do an oil change anyway but same thing with the valve cover gasket I assume it doesn't need to be drained since its just the top of the motor
Jaynen
Jaynen SuperDork
11/24/17 7:16 p.m.
Readiness finally triggered now diagnosing PO420 which could be downstream o2 or cat
Dusterbd13
Dusterbd13 MegaDork
11/24/17 7:19 p.m.
Yes. Drain radiator.
Flush system with a hose while you are at it. Amazing amount of E36 M3 came out of all 3 of mine.
Jaynen
Jaynen SuperDork
11/26/17 9:22 p.m.
Changed the plugs and plug wires found oil in some of the cylinder further indication I need to do the valve cover gasket which I did already order
onemanarmy
onemanarmy New Reader
11/27/17 12:05 p.m.
Coparts fees take the fun out of buying from them
Jaynen
Jaynen SuperDork
11/29/17 12:28 p.m.
Right? definitely more than I expected but still overall I think was a "good" albeit not amazing deal
enginenerd
enginenerd Reader
11/29/17 8:02 p.m.
On a Miata you don't really need to drain the radiator nor the oil to do either repair. However, I'd recommend a coolant change if you are unsure of its history. These cars don't have great cooling systems so I think anything you can do to help is worth it. Check the plastic of the radiator as well...if it's turned brown it is likely a time bomb.
Jaynen
Jaynen SuperDork
12/24/17 5:03 p.m.
Hardtop and rollbar acquired as well as seat and mounting brackets a la harddog. Hoping the bolt to floor bracket, and hard dog hardcore hardtop is plenty for passing broomstick test
Jaynen
Jaynen UltraDork
2/25/18 4:53 p.m.
Car just returned from its first event. I felt like it acquitted itself well and reminded me again why Miata's are some much awesome. This event was a two day event at VIR which is an amazingly beautiful course. Day 1 was Full Course, Day 2 was Grand course
Jaynen
Jaynen UltraDork
6/15/18 1:23 p.m.
Broke an alternator belt and popped the radiator heading to CMP so time to upgrade :(
Dusterbd13
Dusterbd13 MegaDork
6/15/18 1:37 p.m.
I've got a brand new aluminum one down and Albemarle...
PBD8fuiUotQAWf9fktzYl72lxgTgx4tPOgrAkYrWSaVw9X5wL9VGUO4GUGg1X1TL
