Adam 525i- with the belt tensioner, my thinking was that it's only 4 years old with about 30K miles on it. Had the car not chucked a valve guide, I would have been motoring along without a concern in the world about it. (Also, the car is a stick, so it's got that extra timing belt guide around the crank pulley that makes it really hard for it to jump time..) But, I thought about it and you're right. I'm ordering a fresh tensioner. All the idler pulleys and the T-belt are the same 4 yo/30K miles, so they're staying. Also, I'm doing this job in situ. It would make more sense to pull the engine, but I don't have access to a garage or a hoist right now.
Saturday:
The lower shoulder bolts on the valve cover were a BEAR. I tried everything- heated the valve cover and bolt up with a MAPP gas torch, penetrating oil etc. I was eventually able to get 2/3 of the lower bolts out, but the center one wouldn't budge. I took all the other bolts out and whacked the valve cover around a little, hoping that the movement would break the bond between the bolt and the valve cover. No dice. I ground the entire head of the bolt off, hoping that I could gently pry the valve cover off. No dice. This was the only thing that worked.
Finally got the pass side head off
Cleaning it up, trying to keep the crud out of the cylinders:
Got the new head on the pass side. There were some irregularities with the torquing procedure (namely, I followed the loosening torquing sequence from the disassembly procedure for the first pass "gasket crushing" procedure rather than the assembly sequence. ) After that, you back the bolts off 180 deg 2X and then torque in three steps, two passes of torquing to an angle and then some extra angle torquing on the center two bolts. I did all the post-gasket crushing torquing and angling in the proper sequence, so I hope I'm OK. Not totally happy with the surface of the block either, but I did my best to clean everything up.
Lost Sunday due to bad weather and a case of "I am to old for this and need a break."
Memorial day:
Got the driver's side head off this AM.
Transfering the "I can't believe it's not VTEC" valve timing module to the rebuilt head.
X
Mostly back together. Intake manifold was gummy as hell inside, I did what I could to improve things. Also cleaned up the PCV valve which was pretty sluggish due to gum.
I've got to get that T belt tensioner, get some fresh studs for the cyl head/cat converter fixings, couple bits and bobs and we'll put it together and see what happens. Also have to adjust the valves once I have the timing belt hung- but wanted to put the valve covers on in the meantime to keep grit and weather out of the works.
