I've ordered a "high endurance" 256 GB microSD to use for the recording. It's pretty clear to me that V10 is not cleaning up files as it's supposed to, so I'll just increase the time between dumping the files.
I met Janel for lunch today. She was driving the Tesla, I was driving the M5. I was looking around the M5 and thinking it might be a decent preview of how the Tesla might look in the future. Back in 2002, this M5 was pretty much the best car that BMW could make. It had a lot of tech in it. Some has aged well, some has not. This is the car that introduced the world to the Sport button, gauges that change (a variable redline on the tach) and angel eye headlights. It had a built-in telephone, GPS navigation and a reasonably high-end audio system. It's built on a high volume platform but there are only 10,000 M5s so some parts are rare. It's very similar in performance and weight to our Tesla and is black on black leather with wood accents. They're a good pair.
The phone in the M5 is completely obsolete. Even if you could still make an analog network phone work, you couldn't legally use it in a lot of states because it's not hands-free. There are ways to update the thing, though - you can plug in a Bluetooth upgrade and a microphone that's fully integrated into the car. Or at least you could. Availability is getting worse as time goes on and it's about $400 to make that change. I have added iPod integration so I can use that iPod Classic you saw earlier. Still, the way the phone has aged does illustrate the problems with integrating consumer technology in cars.
The nav system is somewhat out of date. Still works well on long distance point-to-point stuff, but since I haven't updated the maps it's getting less accurate inside cities as time goes on. There are ways to update this at the risk of bricking the unit so I haven't bothered.
The nav system screen is also used to access a bunch of sub-functions such as the audio DSP, signal source, setting the clock, etc. Roughly the same as the Tesla, but using a jog dial under the screen instead of a touch screen. It's not something you'll want to do while driving generally, as you do need to look at what you're doing.
The car itself is aging. There are certain bushings in the suspension that need regular renewal. The S62 engine is a beauty but it's a bit of a high maintenance princess that scares off a lot of people. Right now, the engine is working nicely (just replaced the MAFs and an O2 sensor again) but there's an exhaust bushing that's collapsed so the exhaust makes contact with the body under load and we all know what that sounds like. I have a special aftermarket E39-specific code reader that lets me diagnose this car with more accuracy than a generic OBD-II.
The interior is holding up well overall. It's German leather so it's cracking a bit. The wood applique on the driver's door is coming away, so I need to glue that back on again. The cupholders are broken but they're always broken on an E39 and I did install a nice aftermarket alternative designed specifically for the E39.
The worst experience so far has been a zorched airbag computer. A dead battery led to a jump which took out the computer. This controller can't just be plugged in, it has to be coded to the car and that has to be done by a specialist or the dealer. In theory, I have the tools I need to do that but I haven't gone to the effort of installing the specialty OS into an old laptop to do it. That was about $1k to fix and since there was nobody in Grand Junction who could do it, I put it off for a long time.
So if we take the experience with this car and extrapolate it to the Tesla, I think it's fair to say that the car will still work in 17 years. Some workarounds may be necessary such as using the RFID cards instead of a Bluetooth handshake to recognize the car, and depending on what happens to cellular networks it's possible the nav and voice command systems may shut down completely. At some point, software updates will stop when the software reaches EOL and it this may also require some changes to how the car is used. It won't stop working as a car, but it may need to be firewalled. The simple interior should hopefully age well but I don't think that PU leather will look as good in 2038 as the BMW leather does now. Mechanically I think it'll be much easier to live with than the BMW because it is a less complex system, although I don't know if there's an EV equivalent to a MAF that will make the car drive poorly and use too much energy until you pop in a new one. Fingers crossed that there isn't :) Like all modern cars, the Tesla is a mobile networked platform so there's always the risk of something similar to my airbag problem, a dead controller that needs special tools to replace.
