java230
java230 New Reader
3/10/15 11:17 a.m.
How about a mini trailer since I don't really have any go fast projects as of yet... Since everyone likes pics, there is a lot of them, with a little text scattered about in them.
Built this last year to support my summer camping habit, With two 100 lb dogs and a kid the truck got packed to the gill in a absolute hurry. Wife was working out of town and I needed something to keep busy with. I just happened to get a bunch of half pieces of 2x2 tube from a friend and decided it was trailer time.
Sorry in advance for the pics. Welding smoke messes with my camera in the dark garage.
Blue tape mock up on the garage floor. I had a bunch of 22” tubes, and a few ~10’ pieces. Turns out 48x48 works perfect with my camping crap.
Untitled
Got rims from a friend who had changed sizes on his truck. 17’s match the two vehicles, so I can rob the wheels and tires off the trailer in an emergency. With tires and frame size figured I ordered an axle. 3500lb axle, matches my trucks track width, with the softest springs I could find.
Untitled
Untitled
Built a removable coupler, its shared with my other trailer, and I can get a multi axis coupler eventually. And its harder to steal with no ball on it….
Untitled
Cut a bunch of pieces and spent my lunch break using the welding table at work. Having access to tools is awesome… I don’t own a welder of chop saw….. Yet.
Untitled
Spring hangers going on.
Untitled
Ready to tow and finish in the evenings at home. It bounced…. A lot.
Untitled
Untitled
Sides going on. Just tall enough to clear two boxes.
Untitled
Untitled
Welding on tabs for the plywood side inserts.
Untitled
Untitled
Fender brackets. I ordered them online and got impatient waiting for them to come. Welded the brackets on without the fenders… Luckily they fit.
Untitled
Tail gate with latch mounts.
Untitled
Untitled
Getting a coat of POR
Untitled
And then we make lid.
Untitled
Untitled
Prefinished Birch ply for the sides. Rustoleum enamel paint. Of course as soon as I paint it the wind kick up and blows crap into it.... Oh well
Untitled
Untitled
Frame gets a satin rattlecan top coat.
Untitled
Wiring. Just did a 4 pin, I was trying to keep the trailer light, but may add brakes at some point. Love me some tech flex.
Untitled
Untitled
Fenders finally came, they fit, thanks to the dude who reviewed them on amazon with dimensions! Got POR’ed
Untitled
Untitled
Wood got bolted on, and polyurethane caulk was used to seal it to the steel.
Untitled
Untitled
Tail gate was finished with a piece of stainless sheet metal. It was a old door kick plate I had been holding onto for a couple years.
Untitled
Untitled
Untitled
Built some brackets to hold my Maxtrax
Untitled
A sheet of aluminum for the top. I was very temped by all the road work signs as they would fit perfect….. But my wife didn’t like that idea….
Untitled
Gas strut went on also. And my favorite local group….
Untitled
Tongue storage got worked on. CL special piece of diamond plate. Guy had is sizes wring in the add… And was an hour drive each way. It was close enough so I said F it. Hence the square tip….
Untitled
Untitled
Untitled
Fancy tailgate holders, and latches on the top.
Untitled
Untitled
Mud flaps, since they are technically required for inspection…. They have been torn off a couple times already.
Untitled
Rolling out for inspection!
Untitled
Untitled
Shakedown run! So nice to not have the inside of the truck absolutely stuffed, my daughter could actually get out of her own door instead of climbing out the front doors….
Untitled
Untitled
Its been all over the state with me last summer, stuffed in lots of ditches trying to turn around and had been great! I was trying to keep it light, it ended up at 540lbs empty, which is great. I may add brakes still at some point. My truck is heavy enough as it is.
A few pics in action.
Untitled
20140621_101402
20140629_111508 20140628_202651
20140705_165214
Woody
Woody GRM+ Memberand MegaDork
3/10/15 11:20 a.m.
You do nice work!
failboat
failboat UltraDork
3/10/15 11:41 a.m.
very nice, great scenery too
BeardedJag
BeardedJag Reader
3/10/15 11:53 a.m.
Very very nice. I love the tent too.
sethmeister4
sethmeister4 Dork
3/10/15 12:03 p.m.
Wow, that's awesome! Nice work!
Cooper_Tired
Cooper_Tired Reader
3/10/15 12:12 p.m.
Awesome!
java230
java230 New Reader
3/10/15 12:38 p.m.
Thanks Guys! I am pretty happy with it. Will be adding a shelf shortly, it just becomes a pile of stuff.
Petrolburner
Petrolburner Reader
3/10/15 2:37 p.m.
Saw a glimpse of the Winnebago and realized you're Java from ExPo!
mazdeuce
mazdeuce PowerDork
3/10/15 3:01 p.m.
Could you put your shelf on slides so it comes all the way out and you have clear access under it with the lid up?
Fantastic work by the way, and which RTT is that?
java230
java230 New Reader
3/10/15 4:28 p.m.
Petrolburner wrote: Saw a glimpse of the Winnebago and realized you're Java from ExPo!
That's me. recognized you too! Unfortunately with no snow this year winnie hasn't gotten much use. A couple quick trips and a long one up thru BC
mazdeuce wrote: Could you put your shelf on slides so it comes all the way out and you have clear access under it with the lid up? Fantastic work by the way, and which RTT is that?
Thanks! Not with the way the action Packers stack in there. I'm really just going to make a "cubby" to be able to get chairs in and out without unpacking everything. Think 6" tall on the right half of the trailer (from the back) I've got the ply just need some time.
It's a CVT tent. Most awesome.
XLR99
XLR99 GRM+ Memberand Reader
3/10/15 5:14 p.m.
Man that is a nice ADV trailer!! I also like the tent setup.
What's the story on the tank?
java230
java230 New Reader
3/10/15 5:46 p.m.
In reply to XLR99:
Thanks!
We just happened across the tank, didn't know it was there. Did a bit of research, the DOT uses it for avalanche control. I guess there is a second one somewhere else around WA.
irish44j
irish44j PowerDork
3/10/15 6:47 p.m.
I'm officially deleting my trailer build thread after seeing this work of awesomeness....
java230
java230 New Reader
3/10/15 6:55 p.m.
irish44j wrote: I'm officially deleting my trailer build thread after seeing this work of awesomeness....
Naw, yours is what made me think of posting mine! I have no go fast cars to post about at this time.....
irish44j
irish44j PowerDork
3/10/15 7:13 p.m.
lol.....on a side note, nice 4Runner. I miss mine every time I have to drive the plodding Sequoia. Is that the Bajarack tent rack setup you have?
java230
java230 New Reader
3/10/15 7:39 p.m.
In reply to irish44j:
Thanks, the 4runner is awesome, its about to hit 200k!the rack. Is a cheapo rola on mounts I built for the oem rails.
irish44j
irish44j PowerDork
3/10/15 7:49 p.m.
ah yeah, based on your fab skill I should have assumed that you'd build rather than buy!
java230
java230 New Reader
3/10/15 8:37 p.m.
irish44j wrote: ah yeah, based on your fab skill I should have assumed that you'd build rather than buy!
Thanks, no real fab skills.... Its a piece of angle iron and some bolts. I did weld together the basket! Lol
A rack is on my want to build list...
6TAd2Fm17qBRgtPBtLRtWhAMmVLG5BcnjzXemijHMwld36O4B8Jc978LPs6bIOUn
