swing69
swing69 New Reader
10/2/13 2:49 p.m.
Hi. I just need 2 dimensions to make my life so much easier and care free. Here it goes:
84 944.
What is the distance between the two front LCA bushings (R vs L) ? AND what is the distance between the two rear LCA bushings (R v. L )?
THANK YOU! I really really need the number..... Mike
turboswede
turboswede GRM+ Memberand PowerDork
10/2/13 3:50 p.m.
They are the same. This was discussed on Jim's Facebook page as being approximately 26", which I concur is also correct based on my 924 and 944 turbo.
On the 924/944 the rear mounts are adjustable to allow for chassis movement and wear, but most set them to be parallel.
swing69
swing69 New Reader
10/2/13 9:03 p.m.
SWEET thanks.
thats what I needed to know. my front bushings are 18" apart, rear 19.5"
I wonder how much a problem that is.......
turboswede
10/3/13 8:57 a.m.
Its a strut-based suspension, there isn't much right with it to begin with. Limit the travel as much as possible and dial the bumpsteer out as much as possible in the range of the available travel and ship it.
KmuHd953PxkOhT8kRyk1ENGAy5YMdwwjnhtePueVEEoDpmhBP1rQdOWpPC19krpe
