1 ... 12 13 14 15 16 ... 32
TheV8Kid
TheV8Kid HalfDork
1/6/18 6:57 a.m.
Day 77 - March 6, 2017
Made Wastegate flanges.
mazdeuce - Seth
mazdeuce - Seth Mod Squad
1/6/18 7:16 a.m.
Combination of band saw and belt sander for a lot of the thicker metal?
TheV8Kid
TheV8Kid HalfDork
1/6/18 7:24 a.m.
The rough shape was cut out with a sawsall. Then we chucked it up in the mill for the holes and machining the flats. Then used the belt sander to round the corners.
TheV8Kid
TheV8Kid HalfDork
1/7/18 6:04 a.m.
Day 78 - March 7, 2017
TIG welded exhaust pipes.
TheV8Kid
TheV8Kid HalfDork
1/8/18 5:41 a.m.
Day 79 - March 19, 2017
Fabricated wastegate exhaust tubes.
TheV8Kid
TheV8Kid HalfDork
1/9/18 5:17 a.m.
Day 80 - March 20, 2017
Started making steering column support. Welded wastegate tubes. Cut holes in fenders for exhaust.
mazdeuce - Seth
1/9/18 6:39 a.m.
Wait, that front fender is rusty. My understanding of fiberglass one piece front ends says lack of rust is one of the advantages.
TheV8Kid
TheV8Kid HalfDork
1/9/18 7:42 a.m.
The fiberglass front end was not purchased until November of 2017. We're getting closer. There will be a big jump in time for when we started working on the Sunbird soon.
TheV8Kid
TheV8Kid HalfDork
1/10/18 5:17 a.m.
Day 81 - March 21, 2017
Tacked in steering column.
TheV8Kid
TheV8Kid HalfDork
1/11/18 5:18 a.m.
Day 82 - March 22, 2017
Began making more ducts. Began to stiffen front end so that it can be one removable piece.
TheV8Kid
TheV8Kid HalfDork
1/12/18 5:16 a.m.
Day 83 - March 23, 2017
Mocked up front grill.
mazdeuce - Seth
1/12/18 6:19 a.m.
Does it lighten the car to tie the steel front bits together as a single piece? How heavy is it?
TheV8Kid
TheV8Kid HalfDork
1/12/18 6:53 a.m.
In reply to mazdeuce - Seth :
It does not lighten the car. Removing the inner fenders does though.
A removable steel front end is helpful when you need to work on the car. Changing spark plugs is a lot easier when you have a tire to sit on. smiley
My dad may know the weight of the steel front end, but I do not. I can tell you the difference between the steel and fiberglass was 97 pounds. Plus we removed more by making the support structure lighter. It was over 100 pounds off the front end when we were done.
sleepyhead
sleepyhead GRM+ Memberand HalfDork
1/12/18 9:45 a.m.
I think I'm gaining a new appreciation/understanding of the cars at DragWeek
TheV8Kid
TheV8Kid HalfDork
1/12/18 11:53 a.m.
This provides a good illustration.
mazdeuce - Seth
1/12/18 12:00 p.m.
Do I see six points of attachment?
Very much watching this and trying to store away the details for the future. laugh
TheV8Kid
TheV8Kid HalfDork
1/12/18 12:05 p.m.
Yep. We could get away with 6 on that car, because the distance between the front of the door and the beginning of the wheel opening was so short. The Nova will require 8. The Datsun required 8.
TheV8Kid
TheV8Kid HalfDork
1/12/18 12:17 p.m.
This will lighten the car. Thats the Datsun btw.
TheV8Kid
TheV8Kid HalfDork
1/13/18 6:50 a.m.
Day 84 - March 27, 2017
Continued mocking front end. Finish welded steering column support.
TheV8Kid
TheV8Kid HalfDork
1/14/18 7:43 a.m.
Day 85 - March 30, 2017
Made struts the tie the front end together.
Here is where the project stalled out. We started working on the Sunbird around this point, and this car went up into storage.
wheels777
wheels777 SuperDork
1/14/18 10:11 a.m.
Queue the elevator music....the Nova was moved aside from 3/30/17 to 10/26/2017.
The Volvo below was originally going to be our $2012 Challenge car, but we missed that year.  We worked on it from April to the end of June 2017.  Picture below is from day 42 (01/10/2015) of that build.  We worked on the Volvo from day 65 to day 82 in that build in 2017.
At the same time April to June 2017, we prepped Bugzilla for local racing, took it to Carlisle to display in the GRM Stand in May 2017, and then the Road Kill Zip Tie event June 30 and 7/1/2017  (discussed on other threads).
We ended up so energized by the Zip Tie, that we came home 7/2 and converted the Sunbird from a SBC/T400 combo to the 5.3/Turbo/T350 package that showed up at the Challenge in October of 2017.
Then we were reinvigorated at the Challenge to get back onto the Nova and the fiberglass front end showed up at the Maple grove swap meet.  As you will see, everything will be changed to allow room in the budget to the  fit the front end in.
Here a peak at the Volvo.  But someone loved it more than we did.
Recon1342
Recon1342 Reader
1/14/18 12:53 p.m.
You guys do amazing work...
Patrick
1/14/18 1:29 p.m.
I’m sad the volvo moved on, i was there in mid work stages and it was shaping up to be crazy
DeadSkunk
DeadSkunk UberDork
1/14/18 2:07 p.m.
With all these projects when do you guys find time to go golfing?
wheels777
wheels777 SuperDork
1/14/18 2:07 p.m.
When you see what we have planned for all the different racing adventures you'll appreciate why we had to cut the Volvo loose.
pBDXK0cTZB5Mzgi8QzHGboLJoqje8icqEKZigfpgF3jxPcvA3uYFbeyQNixsCyJL
