mr2s2000elise said:
So the neighbors know this property attracts car nuts!
my oldest not into helping. Youngest loves it. Made them both help me rotate tires. It's a start! They are much younger than your girls
keep up the great work; one of my current favorite builds on the forum. We owned the Pajeros before when new - and brings back memories
The funny part is, the P/O was also a general contractor, so he built everyone's decks and did their renovations for below market rate - so basically they put up with him. He also parked his 24-foot enclosed trailer right next to the house, which is technically a no-no in this neighborhood. I park my 16-foot open deck farther back behind a fence where nobody can see it :)
I'm enjoying this build if mostly because it' totally different from what I'm used to - if you follow my other builds here (Porsche 924, e30 rally car, e21) I'm more familiar with sporty cars, inline engines, and RWD. So building a V6, doing the swap, figuring out all the 4WD stuff is all a learning experience for me, which I enjoy. I've done some SUV stuff before but nothing nearly this deep-in. I do appreciate being able to just slide under the truck on its wheels and do whatever I need to do underneath lol.....this is the opposite of working on the Porsche, with everything totally jammed in perfectly in order to fit in a car the size of a Miata (really, it is!)
The girls tinker here and there. The older used to help me put away tools all the time, and likes using the impact gun to take off tires. I try to get them involved. Though during this lockedown, I've taught both of them to throw and catch a football pretty darn well, so if they're not gonna do car stuff, at least they can already do something that most girls these days can't do!
So, let's get into this afternoon/evening's effort. First spent some more time getting wiring and stuff hooked up (everything in the engine bay is hooked now), and setting up the ground wires (took some figuring out). Also put the battery in (need to buy a tie-down of some sort), and cleaned up all the battery connectors with the wire wheel (they were pretty rusty and oxidized).
Then (speaking of the kids) I got my 12-year old to help out with brake bleeding, which went pretty well overall. It's nifty that for the rear there's only one bleeder (on the passenger side) that bleed both rear drum pistons at once - though it took a while for all the brake fluid to get all the way through the system before it ran clear (some old stuff still in the lines was pretty nasty).
![](https://i.imgur.com/bBTiqw7h.jpg)
Ran into one issue where the front left bleeder screw was clogged. I tried to blow it out with air but no dice, must be rusty inside. Then remembered I had my old Sequioa 4-pots in a box nearby, so grabbed one of the bleeders off of that and got it done. Unfortunately, can't really test them yet.
![](https://i.imgur.com/RiTQGYGh.jpg)
Also bled the clutch line/master/slave cylinders solo, using the "loop" method since all components were new and empty (this method is putting the hose off the slave bleeder and looping it back to the master so it basically just circulates fluid via gravity until all the air is out.
![](https://i.imgur.com/ZFAO5Wzh.jpg)
After some adjustment of the pedal linkage, the clutch pedal feels pretty good - though it's a pretty light pedal compared to the heavy clutches I'm used to on German cars. Reminds me of my old Integra from long ago
Next up, heater hoses. I keep on not finding the correct hoses when ordering (so I have several wrong hoses). I did manage to improvise a bit and make one of the hoses fit, but I still need to find a replacement for the longer one. Also, apparently some prior owner really liked to clamp down his hose clamps, because the heater outlet/inlet pipes were pretty mashed up.
![](https://i.imgur.com/JZMVlzth.jpg)
To get them back to (pretty much) round I found a stepped socket in the right size (3/8ths, I think) and basically tapped it into the pipes until they were round again.
![](https://i.imgur.com/iogfYhUh.jpg)
So, hopefully they don't leak. If they do, may have to figure something else out or just slather it all with some sealant or something, IDK....
![](https://i.imgur.com/ExS1HG0h.jpg)
Attached the intake "elbow" and got the air filter all set up (with new filter) since I think I'm done with stuff on that side of the engine bay, and a few other little things. Still gonna be a while, as I want to get the radiator rodded. The old-school Montero experts say the stock radiators are best (they're 3-core, apparently, and they're brass, so once stuff starts opening up again I'll look into how much that will cost me (I have two radiators). I'll probably at least test the engine before then with the one I've flushed pretty good, but dont' really want to drive the truck much until I have a top-condition cooling system, as these engines like to overheat, apparently.
![](https://i.imgur.com/80ZSMGCh.jpg)
![](https://i.imgur.com/wT0Jqn9h.jpg)
![](https://i.imgur.com/nVKCYqUh.jpg)
Also installed the front driveshaft.
![](https://i.imgur.com/2gqQmSHh.jpg)
