1 2 3 4 5 6
chiquito1228
chiquito1228 New Reader
10/7/22 1:04 a.m.
Had a chance to add a resonator. The high pitch at high rpms was really annoying.
chiquito1228
10/17/22 12:28 p.m.
Last event of the year at blackhawk. Festiva did real good. Transmission and clutch performed real good. Hopefully next season i wont have any major mechanical issues and just time to focused on learning how to drive.
chiquito1228
10/31/22 10:27 p.m.
ADMIN
Could The title of this post be changed to "BP swap Festiva"
Thanks!
chiquito1228
11/27/22 7:03 p.m.
Winter project for the festiva. Change the headers/exhaust, reinforced the front end and hopefully find some 13x7 wheels that would fit. I would be modifying this honda b series tri-y  header
chiquito1228
11/29/22 7:44 p.m.
Started to cut the honda flange off. Theres going to be alot of rearranging on the primaries but i think i could male it happen.
11/29/22 7:51 p.m.
I feel you.
TED_fiestaHP
TED_fiestaHP HalfDork
11/29/22 9:07 p.m.
In reply to chiquito1228 :
   That actually looks fairly close, I modified a cheap Honda header to fit my early EW type Honda.  Mine was far more difficult, the later Honda header had basically even port spacing, the older 3 valve ew had two pair of ports, two ports very close then a large gap then two ports very close.
    You should be able to make that work, if the rest of it fits the car.  Stainless is more difficult to work with, but the end result is better.
Masterdebator
Masterdebator New Reader
11/30/22 12:46 a.m.
I love this project.
chiquito1228
11/30/22 9:16 a.m.
This is what we get for building something different. Lol
11/30/22 9:17 a.m.
But Mama, that's where the fun is!
fouckhest
fouckhest New Reader
11/30/22 9:34 a.m.
Great project, love this!
chiquito1228
11/30/22 9:37 a.m.
In reply to TED_fiestaHP :
The spacing is closed but the pipes going down are offset to the left, it won't clear the oil pan
TurboFource
TurboFource Reader
11/30/22 3:25 p.m.
Oil pans were meant to be modified....
chiquito1228
11/30/22 5:18 p.m.
In reply to TurboFource :
Lol. Easier to do the header. I think i got it all figure out. Waiting for a bp exhaust flange. Might have to move the radiator a bit to make it work.
chiquito1228
12/21/22 4:24 p.m.
No update on the header. Still waiting on the stainless flange. Decided to shave the valve cover. I really didnt like the ford logo on it and finding a mazda protege cover seems near impossible. Or way too overpriced
chiquito1228
12/24/22 2:28 p.m.
Had an oil leak from the oil pan while it was off decided to make some adjustments to the baffle plate. Made this plate to closed some gaps, hopefully it helps keeping more oil in the pickup around corners
chiquito1228
12/24/22 2:32 p.m.
chiquito1228
12/30/22 10:23 p.m.
Finally got the exhaust flange and also was able to weld some an fitting to the valve cover
chiquito1228
1/11/23 12:25 a.m.
Finally got a chance to start on the manifold. Going to need to move the radiator to make room for one of the runners. Also got my new wheels shipped from UK. What a hassle that was. But at least they got delivered.
chiquito1228
1/11/23 12:26 a.m.
TurboFource
TurboFource Reader
1/11/23 8:11 a.m.
Nice wheels! What size tires you running?
chiquito1228
1/11/23 2:50 p.m.
Nankang ar1 185/60 13
chiquito1228
1/18/23 12:03 a.m.
3 mock up 1 more to go
chiquito1228
2/4/23 7:31 p.m.
Wheels mounted. What a difference on width with the correct wheel size will do. Once am done reinforcing the front end. I will get a pic on the ground
TurboFource
TurboFource Reader
2/4/23 9:45 p.m.
Nice!
1 2 3 4 5 6
uFuMjgkUOaRY2kHyZ3EFlygaCx3tXn4ih1Px3z80a9oNiJR1knQ9lP6NqXzxtIdL
