1 2 3 4 5 6
jfryjfry
jfryjfry SuperDork
2/5/23 9:58 a.m.
I like seeing this on the front page and love the wheels
jimbbski
jimbbski SuperDork
2/5/23 4:50 p.m.
I only just found this thread.  A friend built a Festiva back in 2011 for Lemons racing and did the same engine swap. I later re-freshen the engine for him. He later picked up a late model 1.8L Miata cylinder head. Due to the relocated intake ports I had to weld extra aluminum plate to the bottom of the intake to allow it to bolt up to the head. The head has better intake ports and a bit more cam timing.  He also later built his own ECU to run the engine. He moved to NJ but later emailed me that the car put down 145 HP at the wheels! Not bad!
chiquito1228
chiquito1228 New Reader
2/5/23 10:21 p.m.
Am hoping my cammed bp05 is around that power. I would like to used a bp4w but am already invested in my current cams
slantsix
slantsix HalfDork
2/6/23 12:58 p.m.
Nice Build Thanks for sharing,
What material did you use to build your front air dam?
Also is it easily removable?
chiquito1228
chiquito1228 Reader
2/6/23 7:14 p.m.
For the air dam i used 1/8 HDPE plastic. Its rivet on with aluminum tri fold to the bumper its all one piece
slantsix
slantsix HalfDork
2/7/23 6:41 a.m.
In reply to chiquito1228 :
Awesome, Thanks!
chiquito1228
chiquito1228 Reader
2/18/23 8:51 a.m.
Finally header is done. Just need to weld a v band and wrap it
TurboFource
TurboFource Reader
2/18/23 3:53 p.m.
Nice!
chiquito1228
chiquito1228 Reader
3/18/23 12:20 a.m.
Wheels are on. Redid my intake now its a true cold air intake also added  a front reinforcing to the core support. Header will need some tweaking to make it work for now am using the previous header i had. Just want to get it going for next month track event.
TurboFource
TurboFource Reader
3/18/23 8:03 a.m.
Looking good!
BlueInGreen - Jon
BlueInGreen - Jon UberDork
3/18/23 9:13 a.m.
Very cool. Those wheels are  just right  yes
chiquito1228
chiquito1228 Reader
5/31/23 11:56 a.m.
Past weekend we had the our memorial event at Blackhawk. Festiva did real good. Me not so much. I do need alot of seat time to get comfortable. But I was a able to knock 2 seconds off my lap times.
chiquito1228
chiquito1228 Reader
5/31/23 11:57 a.m.
Will be changing spring rates for next event. I was getting alot of body roll
TurboFource
TurboFource HalfDork
6/10/23 2:54 p.m.
May need your advice on a Festiva Challenge build.....
chiquito1228
chiquito1228 Reader
6/10/23 9:18 p.m.
In reply to TurboFource :
I send you a pm with my number
TurboFource
6/10/23 9:24 p.m.
yes
chiquito1228
chiquito1228 Reader
6/11/23 4:18 p.m.
TurboFource
6/11/23 4:27 p.m.
How did it go?
chiquito1228
chiquito1228 Reader
6/12/23 9:38 p.m.
Those pics my buddy took at the track.
Got a chance to swap one of the coilovers spring. 1 down 3 to go.
chiquito1228
chiquito1228 Reader
6/16/23 2:06 p.m.
Rear setup. Left side is the previous right side new setup. Different bumpstop and top spring isolator
chiquito1228
chiquito1228 Reader
9/2/23 2:19 p.m.
Had a chance to attend a autocross event at a local oval track. A bit different that actually racing a track but got to take home a 1st place. Didn't get any pics of the festiva in action since I went my myself.
chiquito1228
chiquito1228 Reader
9/2/23 2:20 p.m.
chiquito1228
chiquito1228 Reader
9/2/23 2:21 p.m.
chiquito1228
chiquito1228 Reader
9/2/23 2:24 p.m.
Debating on installing a cage to be able to attend scca hill climbs event for next year
TurboFource
9/2/23 5:10 p.m.
Awesome !
1 2 3 4 5 6
b7dgZyc0kMvJQXmND2o1yTJ4ojvGnHIC0Hwe1FNHSpazfUseFs5jIK0VrvLi77v7
