My '04 9-5 Aero Wagon is about to hit 175k. It was about time to take it down for maintenance for awhile: the subframe bushings were shot and creaking and the front end was pretty loose overall with most of the bushings being the ones that accompanied the car out of Trollhattan 12 years ago.
I had been slowly collecting up pieces for awhile, but had deferred doing anything after messing my back up again this summer. I figured I should get all this stuff done before winter, which could happen any time between Sep and Jan.
The tipping point came when the coolant bypass valve started leaking.
I figure that some VW engineers were on loan to Saab/GM when this idiotic piece of over-engineering was created, or they were experimenting to see if Colin Chapman's grave would show any seismic activity. I guess the idea is to bypass the heater core while the AC is on to slightly improve AC function, for the US market only. Here's the offending valve and 436ft of hoses on top, replacement hoses on bottom: <img src=""
I noticed the reservoir was a bit low while shooting PB blaster on some fasteners, filled it up, and started off for work. Halfway there, the car informed me that more coolant would be needed. I managed to get home after taking a gallon of sterile water from work, and stopping to buy several gal of distilled water. Three stops and ~2 gallons later we were home.
When my wife got home, she says "Oh, the SID told me the coolant was low yesterday. I forgot to tell you." Thanks dear...
