Next time you want to bend pipe drive up it length wise. It's better at controlling the radius and you can swap ends and get the same bend. If you really need to get exact then if you drive about 15 minutes south to Sammamish you can use my pipe bender all you want. From the pic's I've seen it looks like your just up in Redmond.
java230
SuperDork
3/31/17 12:18 a.m.
In reply to brad131a4:
Next time! I'm in Kenmore.
I didn't get the bends in plane very well
java230 wrote:
In reply to BrokenYugo:
These are aggressive as Steers go, they are well siped, I might think if grooving or siping them more tho
My thinking was taking them to something like this, groove out some of the sipes.
java230
SuperDork
3/31/17 9:22 a.m.
Yeah something like that seem doable. I have never grooved anything though!
The other thing to remember is I am not as heavy as a big rig, I dont know if drive/steer differences will be as big. Im hoping to be around 13k total
I thought about grooving those tires too, but I just can't see them ever balancing out that well. For a mud truck, sure. Highway truck? Probably better to trade them in to Les Schwab or something and just get the drive tires on the front. Your front wheels are driven anyway, why not have drive tires?
What size are your front tires? Let the hive search for more options for you.
java230
SuperDork
3/31/17 11:03 a.m.
In reply to Petrolburner:
Thats a good point. I didn't think about balance.
Does les schwab really give you any credit back? These have like 2k miles on them, i think I have the paperwork too.
The current size is 225/70/19.5, id like to go 245/70 as I think thats about all I can fit onto the 6" wide wheels... 265 would be better but they call for a lot wider wheels.
Leaving town, means I need to wrap the bar up as the bolts it uses hold the bumper on....
A little crooked.... and I have to add some tabs to support the lights it looks like.
Finished up the kerosene tank mount
Out in the woods
Chill dog
Nice sunset
Chuckanut Dr is a bit tight in this thing
Propane fill goodies came in.
Completely wasted. Collapsed easily by hand and zero rebound.
Propane tank is in! My god that was not fun, its tight, like really really tight, cant lift the tank up, it has to be tilted and wiggled into place.... Apologize in advance for crappy pics, its tight. :D
The front side of the tank got through bolted through the floor, its under the fridge, which meant fridge had to come back out. Back side I couldn't do that as it would have been right inside the door. So I made some brackets, they go under the flange on the tank, pickup both bolts, and then bolt sideways through the floor member. Getting all that lined up with the tank in place was interesting.
Brackets with the lovely blue paint
And in place.
Remember it was tight? Its touching the spring hanger.....
A little sawzall action and more better. Hopefully that not enough to cause structural issues in the hanger.
Tucked up nicely, you cant even see it if your not looking. It will get a healthy coat of bed liner next.
So they finally cleaned up that rockslide, cool!
Get stuck behind any Canadians doing 10 under?
java230
SuperDork
4/5/17 10:57 a.m.
Yeah on the Friday before we went up luckily! No I think it was me trying to keep at the speed limit.... It was challenging at some points. I did pull off once as I had someone behind me for awhile, otherwise it was pretty quiet.
Looks good! I wouldn't worry about the tiny shaving off the spring hanger. Although when you wrote it my immediate thought was, "Not good!"
java230
SuperDork
4/5/17 12:22 p.m.
Yeah I think it will be ok its a 1/4-3/8" wide slice at the widest part. If not I guess I will find out!
wae
Dork
4/5/17 1:02 p.m.
I can't tell, is that behind or in front the of the tire? Any concerns about picking up road debris or a blowout impacting the tank?
Its ahead of the tire. Yes there are some concerns, but this is an ASME tank. That means thick walled which should help.
I talked to a guy on pirate4x4 who had had a blowout hit his tank. No issues. The valves/bungs are away from the tire which I thought would be the most vulnerable part.
I will give it a healthy coat of bed liner to keep the rock chips down.
This is too cool! I've been kicking around the idea of getting an old ambulance with a 7.3 for cheap and turning the back into kayak storage, maybe a dirtbike, and cots.
In reply to crankwalk:
Do it! Add heater and your good to go for ak camping! I'm hoping to drive this up there soon! Wife said no ambos.... But I'm super happy with how this is Coming together
I hate to be a killjoy but I'd at least fab up some type of steel skid plate type barrier for the propane tank. I've had a few blowouts owning an rv, and some can be fine, and others look like god himself came down and bent steel, It's just not worth the risk. We just had a few folks die in an rv down here in a propane fire that was the result of an accident. Different I know, but worth the time to get some peace of mind. Other than that- awesome build!
In reply to grover:
No need to feel like a killjoy! I post to get opinions, I really am making it up as I go... I am looking at a skid, will help with keeping stuff from packing up on the front side from going over the top too.
Tell me about your blowouts, I've had two and it was just sidewalls both times.
While even cheap BBQ tanks are super overbuilt and this tank is heavier than that, something shielding it for additional fireball (that much LP will make a RV sized fireball no problem) insurance definitely wouldn't be a bad idea.
java230
SuperDork
4/6/17 10:10 a.m.
Yeah its 11.9 gallons, or 50lbs of propane. Dont want that size fireball period.
Nothing real exciting, but a little more progress. Made up the first battery cable, big thanks to Cascadian for letting me borrow his crimpers! They are sweet. Self adhesive shrink tube is awesome.
New cable let me install the shunt for the Victron battery meter. While I like the RJ45 connections for the meter, damn getting those heads fished through holes sucks!
Gotta install this end still... But it works!
I second a shield for that tank. Don't forget that when a drive tire blows out, the tread likes to come off in one large slab and try to take out everything around it before ejecting itself out onto the highway.
java230
SuperDork
4/6/17 10:00 p.m.
In reply to SyntheticBlinkerFluid:
Yeah... Enough people have said things I'll figure out a way to protect it a bit
Nice! If you make it to southcentral AK send me a message.
java230
SuperDork
4/6/17 10:48 p.m.
Will do! I've got family in Anchorage. Hopefully in the next couple years
Its a jungle behind the fridge...
But the stove works!! (and my phone sucks at pics...)
