1 2 3 4 ... 37
cmcgregor
cmcgregor HalfDork
12/12/16 1:44 p.m.
Does the spray foam have a hose that you could extend into the channel, then withdraw as you spray? It might be worth drilling one bigger hole to facilitate that
java230
java230 Dork
12/12/16 2:47 p.m.
In reply to cmcgregor:
Im sure I could add one. I use the commercial gun so it doesn't have the "straw".
Any thoughts as to how many holes would be an issue? Those channels are all of the structure.
cmcgregor
cmcgregor HalfDork
12/12/16 3:10 p.m.
Hrm. That I wouldn't hazard a guess at. How many holes are already there? Is there a convenient one near the top or bottom you could just make a bit bigger?
java230
java230 Dork
12/12/16 3:11 p.m.
Top of the channel is open (but hard to access). No other holes.
2K4Kcsq
2K4Kcsq HalfDork
12/12/16 5:42 p.m.
I might have to trade some backcountry access in the kristi for a nights lodging in this! I like how committed you are to the ultimate ski mobile. we all love mountain towns and all the winter night life but who can afford staying there??? this is very cool and useful. even more so for backcountry trips. keep up the good work man
java230
java230 Dork
12/12/16 6:32 p.m.
In reply to 2K4Kcsq:
Sounds like a CO trip is in order!
Yeah I'm really stoked with this truck. I have a lot of work to do still. I'm out of funds for the time being.
But can seal should be here Wednesday, and then I can start cutting....
2K4Kcsq
2K4Kcsq HalfDork
12/13/16 10:44 a.m.
that would be great. cant wait to see the interior take shape.
java230
java230 Dork
12/13/16 10:46 a.m.
Just for clarity, here is the wall section. I am taking about filling the hollow area.
2016-12-13_08-39-38
My door showed up, but the UPS guys had their way with it :mad:, edges are good and dented in a few places....
Screenshot_2016-12-12-18-56-08
Picked up a used inverter/charger as well, only 1250 watts, but should run a microwave (i hope!). Charges at 55 amps, a bit slow there as well, but the price was right. Came with a 200A Blue sea breaker too.
20161213_082551
ebonyandivory
ebonyandivory UltraDork
12/14/16 6:51 a.m.
I've been interested in this type of build dating way back to the early Turtle Expedition trucks.
Jealous!
java230
java230 Dork
12/14/16 10:41 a.m.
In reply to ebonyandivory:
Me too!! Im really excited
java230
java230 Dork
12/14/16 11:07 a.m.
k here's a question.
I have dual 120 amp alternators, what amperage should I assume my house batteries might see? A full 240? Ther are two starting batteries to run through, and 25' of wire. And 120 amps is going to be peak output.
Thoughts? Is a 200amp breaker good on the main house to starting battery run? I have a 150 amp combiner I was planning to use, but that seems undersized now.
From the Manual is says:
"FEATURES < 150 amps continuous rating, 400 amps closing current (2 seconds), 200 amps for 5 minutes < Suitable for alternators up to 200 amps, up to 18 volts"
Good for 200A alternators? Seems like they de rate the alternators a fair bit.
java230
java230 Dork
1/5/17 9:45 a.m.
Whats in the crate?
Windows!!! Not fancy flush pane ones, but they are double pane insulated ones, they latch and slide very nicely, I am very happy.
java230
java230 Dork
1/8/17 2:36 p.m.
headliner dropped and moved forward.
No going back now! It was a bit scary to take a sawzall to my new truck.... Rough cut in the box.
Window out, got 3/4 of the way around, then it broke... ugh
Yikes!
Need to cut the inside lip down to 1/2" still. Ran out of blades.
Window infill pieces, ran out of time today....
curtis73
1/8/17 4:07 p.m.
java230 wrote: k here's a question. I have dual 120 amp alternators, what amperage should I assume my house batteries might see? A full 240? Ther are two starting batteries to run through, and 25' of wire. And 120 amps is going to be peak output. Thoughts? Is a 200amp breaker good on the main house to starting battery run? I have a 150 amp combiner I was planning to use, but that seems undersized now. From the Manual is says: "FEATURES < 150 amps continuous rating, 400 amps closing current (2 seconds), 200 amps for 5 minutes < Suitable for alternators up to 200 amps, up to 18 volts" Good for 200A alternators? Seems like they de rate the alternators a fair bit.
Its unlikely that it will ever see 240 amps to the batteries. Batteries will only take at a rate the is dictated by the chemical reaction, the surface area of the plates, the amount of charge, etc.
BrokenYugo
BrokenYugo MegaDork
1/8/17 6:07 p.m.
The only time you'll see anywhere near 240 amps between the batteries and the alternator is when you're pulling that kind of load with accessories.
java230
java230 Dork
1/8/17 6:36 p.m.
hmmm so what can i expect 4 250AH 6V AGM batteries to draw when they are 90% depleted?
2K4Kcsq
2K4Kcsq HalfDork
1/8/17 9:02 p.m.
tell me more about your windows. need something for the snowcat and I like the looks of what you have there.
java230
java230 Dork
1/8/17 9:14 p.m.
They are double pane rv windows. Slide in from the outside with a clamp ring on the inside.
They will make whatever shape you want. Motion windows is the mfg, not cheap, but seem good so far.
2K4Kcsq
2K4Kcsq HalfDork
1/9/17 8:19 a.m.
awesome thanks!
java230
java230 Dork
1/10/17 9:19 p.m.
Cut....
20170110_144547
Hole.....
20170110_144959
Door!
20170110_145712
Got the window infill panels done. Used the cutout from the box! Has a rib on either piece, makes a nice stiff panel.
20170110_163600
golfduke
golfduke HalfDork
1/11/17 7:23 a.m.
Maybe I missed this, but what are you planning to do with the opening in terms of the gap between the cab and box? I'd assume that there's a bit of flex between the two, no? Just curious.
java230
java230 Dork
1/11/17 7:49 a.m.
In reply to golfduke:
I have an accordian seal that will go there. Big piece of floppy rubber, speced for 2-7" gaps.
Hopefully my new saw shows up tomorrow like it's supposed to so I can get the seal on! I'll take a pic next time it's out of the box.
golfduke
golfduke HalfDork
1/11/17 8:06 a.m.
Awesome. I figured you had a plan before you actually cut the back of the cab up, but missed where it was gone over, haha. This rig will be awesome. If I could make something like this and still have it capable of pulling my car trailer, that would be the be-all, end-all of tow vehicle/camper/car hauler setups.
java230
java230 Dork
1/11/17 9:56 a.m.
golfduke wrote: Awesome. I figured you had a plan before you actually cut the back of the cab up, but missed where it was gone over, haha. This rig will be awesome. If I could make something like this and still have it capable of pulling my car trailer, that would be the be-all, end-all of tow vehicle/camper/car hauler setups.
The guy I bought it from pulled a 26' enclosed car trailer with it.... Probably a bit too much weight (its registered for 14k.) but it did it just fine. Thats why he stretched the wheel base, to keep the leverage from the trailer down.
Yeah I had a sort of plan before I cut it, not too much though.... Getting it back together will be fun.... Lots of curves to fight the seal around.
This is the seal I am using
camaroz1985
camaroz1985 Reader
1/11/17 10:38 a.m.
What are you doing for a back seat in the truck, or will it just fold down to access the box?
1 2 3 4 ... 37
mzT84sy2Kq2WXFF7h44nB6uTbslttPK6ib6SG2si4liEhMhMNaCEJasuL7bcwvvB
