1 ... 49 50 51 52 53 ... 63
SkinnyG (Forum Supporter)
SkinnyG (Forum Supporter) PowerDork
4/9/23 10:25 p.m.
Finished the zig-zag through the front X:
Next the corkscrew through the rear X.
4/9/23 10:40 p.m.
In reply to SkinnyG (Forum Supporter) :
Nice work!
4/10/23 8:23 p.m.
  First, we need to go UP from the unmuffler:
Then I'll need a 6" straight to connect to the left side of this, up over the frame, and into the fenderwell ahead of the wheel. Man, this took forever.
Kendall Frederick
Kendall Frederick GRM+ Memberand New Reader
4/10/23 8:27 p.m.
How's the solar flux working for you?  I have a jar somewhere, but never really used it much.  What do you mix it with?
Mr_Asa
Mr_Asa UltimaDork
4/10/23 8:43 p.m.
We used it fairly regularly on the FSAE team.  Did a good job.  Mixed with water, I think?  Been a couple years since I've messed with it though
Kendall Frederick
4/10/23 9:13 p.m.
I tried it with water a time or two, but did not feel like it mixed well.  Google (well, Harris, the mfr) says mix with alcohol and that methanol is preferred.  I would expect regular rubbing alcohol would work fine but haven't tried it.
Mr_Asa
Mr_Asa UltimaDork
4/10/23 9:16 p.m.
In reply to Kendall Frederick :
Maybe it was alcohol.  Like I said, it was a while back.
4/10/23 9:26 p.m.
I bought the Solar Flux years ago, because it seemed more convenient/cost-effective than having another Argon tank and reg.  It works well, I mix it with Methyl Hydrate at the moment, because that's what I have on hand. The tin recommends Methanol.  I had recently used it on the outside of tubing where I was welding on the inside.
All of these welds were done with back-gassing off a second regulator Tee'd off my tank, I just haven't put the tin away.
Kendall Frederick
4/10/23 9:42 p.m.
Thanks for the info.  I need to put a tee in after the flow meter where I can back purge, but I am planning some stainless sheetmetal work that could probably benefit from the flux.  Now I just gotta find it..
4/10/23 9:49 p.m.
I would T and run a second reg.  I backflow only around 5cfh, and you need a bit of time for it to fill up the space.
4/14/23 8:34 p.m.
Christmas!
HP Tuners, AEM Wideband, Spider Caps, Plug Wires, AND a Classic Instruments panel all arrived today!
I'm enjoying the selling of my '77
4/14/23 9:40 p.m.
Spider Caps:
wheelsmithy (Joe-with-an-L)
wheelsmithy (Joe-with-an-L) GRM+ Memberand PowerDork
4/15/23 8:14 a.m.
Outstanding!
4/16/23 12:10 a.m.
Definitely need another band clamp - there is no way this psycho corkscrew of a tailpipe can be one piece and installable.
obsolete
obsolete GRM+ Memberand HalfDork
4/16/23 1:00 a.m.
Are those not the same thing?
eastpark
eastpark HalfDork
4/16/23 9:28 a.m.
Spider Caps:
Cool! What are your first impressions of these? I'm thinking they'd look good on the winter steelies for the wife's car.
4/16/23 11:14 a.m.
I have no idea.  It's an alcohol.
4/16/23 11:15 a.m.
Spider Caps:
They're pretty.  I haven't mounted them yet, so I don't know how annoying they will become.  For winters, I'd definitely use never-seize on the wee screws that hold the caps to the mounting plate. I'd hate to try and remove them when they're seized.
Hmmm..... Thinking....  I guess one could just drill and tap holes in the wheel center, and not use the backing plate at all.....
4/16/23 10:03 p.m.
4/22/23 1:34 a.m.
Line Lock arrived. Good, as I'm going to be doing the brake lines soon.  More of a novelty than required, but I've never had one before, and kinda want one.
4/28/23 10:04 p.m.
And fabricated an air filter elbow as well:
TurboFource
TurboFource HalfDork
4/29/23 7:28 a.m.
Nice work!
I just use rubbing alcohol with the Solar Flux
4/29/23 11:28 p.m.
I did have to cut a bit off to actually fit the filter.  Just.
5/1/23 12:24 a.m.
Back on the fuel filler, with the vent to make filling much easier:
i have mentioned this before, but i'll say it again: i'm a huge fan of your work.
5ORHjI5g1HOvV2jZFqU6eADaCWG6of6wZ27P9lrOfFzxk4I2dJG1LkPTNmQno77y
