He just got out of the Army. Owns an 08 GTI which will be tied up in shipping. He's got decent knowledge of cars, but wants to start doing HPDEs and AutoX with me. Figured it was best to buy a cheap car to wad up into a corner, rather than one he was still paying on.
Found this 87 'Rocco on Craigslist for $2000. Needed brakes, had about 150k on it. Interior claimed to be "mint". It's 4 hours away. I have a vacation home around an hour away form there.
Go up on Friday night, and drive to pick her up on Saturday morning. Get there, hood is rusted. Needs replacement. Fenders are dented to E36 M3, luckily they are cheap. Minor rust on hatch and under rear fender flare. Nothing structural, all can be fixed with ease.
Brakes were completely gone, reverse-lockout gone, gearbox shifts like complete garbage, needs bushings or motor mounts or both. Tires, however, new Kuhmo Ecstas..
Took it for a test drive, motor pull strong to redline, doesn't smoke, has a rough idle.
Offer $1600 cash, including a new Bentley Manual. Drive her back an hour to the garage with no brakes and not being able to reliably shift into 1st. Commence tune-up and new brakes.
PO converted to lug studs, did not have the key for locking wheel nuts. No tire shop open @ 4:00 on a Saturday. Luckily they were just parts-store specials. Lug studs also seized into rear rotor. Having to track down 8 Lug Bolts in Rural Michigan on a Sunday morning. Good luck. Also didn't have anyone to press races into the rotors. Have to go back in two weekends and finish up the rears.
Here's a pic to make this more interesting:
The e-brake Mechanism for the rear calipers are seized. I don't see rebuild parts available, and ones from Advance are $80 each. Is there a more Grassroots solution? Also, we need to order up some new studs from Apex Competition, any idea on length?
Luckily the shifter rebuild kit is fairly inexpensive, is there anything else to keep in mind? I figured fixing the lockout and replacing all bushings with poly/delrin units. Same goes for Motor mounts.
The CIS-E fuel system is an absolute cluster berkeley. The car has a vacuum leak from somewhere and will not idle. It requires me to keep it at about 1/2 throttle. Would it be alright to just buy new Vac line and loop any hoses related to the intake (other than power brakes) and cap off/plug the rest?
As far as that goes, Megasquirt is a possibility really soon. Should just need a FPR, Injectors, Fuel Rail, and lines. Is there a rail I can source from a Junkyard, rather than going with a pricey billet one? From my limited research it seems as though converting to MS on one of these is pretty straightforward.
Anything else to look out for?
