Frustration in the Batcave. Pics now, text soon. Actually I am going to edit the hell out of this but because the pictures are on the tablet, but trying to type on the tabletnalwaysnlooks likenthiscunlessnintypenvery slowly... yeah.
But first, I was to celebrate 220k day.
Before that, I had some free time at work, so I dug the POSsubframe out of the shed and measured it carefully.
It's more twisted than bent. Might actually be good enough. So...
Went for broke and just moved the pivots as far up and out as I could get.
And now, in the den of frustation...One of the things I had been skillfully procrastinating was dealing with the fan.
To recap: I want a "simple" driver, and this means a belt driven fan. Don't want to run an electric with a 40a alternator unless it is manually controlled, and I would prefer a keep your head out of the car experience. I have swapped a series 4 13B in to the car, with the water pump housing that came with it. This requires a series 4 fan clutch. I did not know until after I put it together that there is a cospatial anomaly with the fan shroud and series 4 fan, and you need to use the 12A fan according to the Internet.
Did I mention that R&R'ing the fan clutch involves removing the nuts from the mounting studs, and then removing the studs with needle nose pliers, because there is nowhere near enough room to pull the fan clutch off over the studs?
I undertook this task. Yanked it out and installed a 12A fan on the Series 4 clutch. This conglomeration on the left, the series 4 fan on the right. Notice they are about the same diameter.
Long and arduous story short, the fan still hits the shroud. It looks like the engine is sitting up too high. I happened to have acquired a genuine Racing Beat 13B conversion motor mount bracket, and it seems to be the same height as my straightened-out 12A bracket. Shrugging and deciding not to put too much effort into this because a 12A is going back in soonish, I just eliminated the shroud. And used the 13B fan after all, because it looks more aggressive, which might mean something flow wise.
Next it was fuel pump time. I have a fuel pump mounting plate On The Way, but not in time for my time constraint, so I opted to just booger-mount the cheapo going to be replaced soonish fuel pump to the original hole in the floor that the PO nut and bolted a different cheapo pump into. Key on and the pump rattles! And it quieted down, signifying that it was pulling fuel and making pressure? Ran off to the BP with 7 gallons' worth of fuel carrying capacity, and dumped all that, ten ounces of 2 stroke oil, and a can of BG "44" in the tank. Set the battery on the charger for some extra oomph while I inserted four spark plugs and found a set of plug wires, which also had a distributor cap attached.
Went to crank it and....
...the battery is still not enough to crank the engine. It's on charge overnight.
