TurboFource
TurboFource HalfDork
6/10/23 9:01 a.m.
Anyone ran a TD03 on a small motor?
it says up to a 1.2 liter gas motor but I don't think a Mazda B3 is that high of an output for it's size, more concerned with response than max power. I only need to move about 11.5 lbs of air and at less than the TD03's max pressure ratio of 2.9. Should this be ok? If not, any suggestions ( needs to be cheap for Challenge)?
Thanks!
RacetruckRon
RacetruckRon GRM+ Memberand Dork
6/10/23 1:52 p.m.
That's probably a good fit I would ask what is the full turbo designation? TD03-XXX? The TD0x determines CHRA, bearings and turbine size. The -XXX will be your compressor size. TD04s and TD04HL are used on a  lot of 2-2.5L engines But the -XXX varies a lot and there's a reasonable difference between a -13t and a -15g in performance.
TurboFource
6/10/23 2:20 p.m.
In reply to RacetruckRon :
Which would you recommend?
RacetruckRon
6/10/23 10:51 p.m.
In reply to TurboFource :
For the challenge, whatever is the cheapest.
6/19/23 7:21 p.m.
FWIW the 2l in my WRX had a TD03 and Volvo used TD03s on engines up to 2.5l.  It is a frame size, not necessarily a turbo size.
And yes, it amuses me that Subaru used Mitsubishi turbos.  Probably fair play after Mitsubishi used Nakajima (which became Subaru) engines in the Zero.
7ZnrDiMN2RfIzVmvRqNdeAf4e5Ze7tIJ8TLkW88EhR9hpDW6cmGSUWsrEqZ9VofI
