RossD
RossD MegaDork
5/22/18 7:26 a.m.
Nice project!  I love the shelf you built for the top of the car!
scottmasterton
scottmasterton New Reader
5/25/18 9:16 a.m.
In reply to RossD :
Thanks! We use them all the time laugh great for keeping on top of things wink
scottmasterton
5/31/18 7:28 a.m.
Started bits of the dash with fibre glass
scottmasterton
7/16/18 4:30 a.m.
Started work on the indicator stalks, looking a bit rough but with a bit of work should clean up.
Also just been told harness eyes will have to be moved as the harnesses are supposed to be at 45* angle going in to the seat so will need to fix that
scottmasterton
7/16/18 4:31 a.m.
Made inroads to stripping some weight out of the driver side door, original door sans door card weighed in at 16.81kg with glass. Managed to drop weight down to 10.39kg so far but that is without glass. Still think there is more to come and then to replicate with passenger side.
Further progress with the dash mounted the passenger side panel with 4 tags, hole cut for the kill switch - might need to support panel a bit more there for safety, placed the ignition and starter switch.
Starting to see things coming together more and more.
scottmasterton
8/17/18 8:50 a.m.
Some more work on the dash, not sure how the shoes got there laugh
Progress on the switch panel
Almost finished the pedals just need to make a couple more adjustments then work out wether to add grip tape or similar
Started work on the IRS setup
Need to modify the fuel tank a bit more
Trying to work out where we can put tubes for triangulation whilst retaining modified tank and wheel well
duNbfsJwWzbYfrlmRCRU6O1ohJnf2TsqyjC3uacUDc2EfZRpsdWJc9HPMHmIynhg
