1 ... 104 105 106 107 108 ... 116
NOHOME
NOHOME MegaDork
7/9/19 7:45 a.m.
In reply to Shavarsh :
I am going to try that. Did a bit of googling and it is not that rare for them to stick even when the box is new and before ATF is added; shifting on the bench before install will actually do it.
Hail Marry pass time!
Dusterbd13-michael
Dusterbd13-michael MegaDork
7/9/19 8:06 a.m.
There was one time I put a used T5 in one of my cars and it would not shift. What seemed to work was shifting it in gear with the engine off pushing the clutch in fire it up and then shifted into neutral a few times and it freed it up and work pretty flawlessly until I sold it
NOHOME
NOHOME MegaDork
7/9/19 9:11 a.m.
Kinda the plan.
Failing that, opening the box to replace the blocker rings does not seem too far-fetched. Mustang Pete has had more than one of these opened before.
Pete
NOHOME
NOHOME MegaDork
7/10/19 6:21 a.m.
Well, new oil did not make a difference so out it came.  A bit of dismantelation ensued. Turns out the failure had nothing to do with the low fluid level.
And carnage was found. These little "Tabs" are either bent or broken and not doing their job of engaging the blocker ring. What they are doing is preventing the shift ring from going where it needs to go and jamming up the works.
Broke
And as is endemic to most T5 boxes that live behind a Mustang engine, second gear has seen some abuse. It showed no symptoms, but since I am in here might as well toss in a new second gear.
This thing worked perfectly up to the point where it did not. Go figure.
Samebutdifferent
Samebutdifferent New Reader
7/10/19 7:09 a.m.
As you have said all along, there is a learning curve no matter how experienced you are.  While I'm sure you are not surprised at what you found, it does confirm (due to no fault of your own) the somewhat fragile nature of the T5 and you have the answer to yet another mystery.  I'm sure you will put your stamp of approval on the rebuild and it will be a smooth as butter in summer.  Hopefully this is the last major hurdle to make it road worthy and reliable.
NOHOME
NOHOME MegaDork
7/10/19 8:24 a.m.
In reply to Samebutdifferent :
I am lucky to have someone working with me who knows these boxes quite well.
tuna55
tuna55 MegaDork
7/10/19 10:24 a.m.
If I can rebuilt that ancient box in the truck, you can handle this without breaking a sweat.
Sorry I've been away for so long, it's good to catch up on your thread. I love a T5 in this. That's what it should have had since the beginning.
AxeHealey
AxeHealey GRM+ Memberand Reader
7/10/19 11:51 a.m.
It probably feels good that it wasn't caused by you. All back together and on the road this weekend?
NOHOME
NOHOME MegaDork
7/10/19 12:24 p.m.
In reply to AxeHealey :
Depends on parts.
NOHOME
NOHOME MegaDork
7/10/19 11:16 p.m.
Walked into the shop after dinner tonight expecting to see this since it is where we left off
Took me a few seconds to get my sense of reality re-adjusted because what I found in the same spot was this:
Mustang Pete has a sense of humor that I think involves berkeleying with my old brain, and this one was spot on.  But whatever, If I start halucinating mansions in the sky...I'm moving in.
So we did this tonight
It was a good night with all three Petes in the shop for the first time in a while.
Still got to button up a few details, like putting the exhaust back on and adding fluid, but the shifter rows through the gears better than ever and the clutch is working and it is all mounted solid with a driveshaft in place that rotates by hand when the clutch is in.
Pete
Samebutdifferent
7/11/19 7:02 a.m.
This is fantastic!  yes
What a great way for this to come together.  Way to go guys!  We are all ready for this to be on the street.
Ian F
Ian F MegaDork
7/11/19 7:04 a.m.
In reply to NOHOME :
It's amazing how quickly a job can get done when someone who knows what they're doing is left alone to do it.
759NRNG
759NRNG SuperDork
7/11/19 8:44 a.m.
So.....are you gonna put a mural on the inside of the bonnet ala 'vette' guy with a 'Special Thanks to; Mustang Pete' ??
NOHOME
NOHOME MegaDork
7/11/19 9:05 a.m.
In reply to 759NRNG :
There are actually two Petes besides myself who have put a lot of time into the project. When it comes to the Ford mechanicals, it is Mustang's time to play cause he invariably has the situation covered and done while I am still trying to figure out what the way forward might look like.
By the way, Mustang is a huge fan of Fitech EFI  He believes every classic car in the world should have one.
Pete
AngryCorvair
7/11/19 10:03 a.m.
place me solidly in the "hot rods shouldn't stink, or be hard to start, or require seasonal tunes" camp.   EFI and cats for everyone!
JoeTR6
JoeTR6 Dork
7/11/19 10:19 a.m.
We should all down one in honor of Mustang Pete tonight.
I'm definitely in the "EFI is better than carbs" camp.  But it's probably not for everyone.
Samebutdifferent
7/11/19 11:16 a.m.
In reply to JoeTR6 :
You mean I have to wait until tonight?  Who makes these rules?  cheeky
java230
java230 UltraDork
7/11/19 11:26 a.m.
Ha! See someone doesn't hate the fitech!
NOHOME
NOHOME MegaDork
7/11/19 9:26 p.m.
First non-eventfull test drive today. Still just in the hood streets, but nothing bad happened.  Not gone past third gear.  As a matter of fact, I think this thing could live in third gear alone.
Still want to raise the rear ride height by an inch or so but no rubbing with the rolled fender lips. Took the Mrs around the block to make sure that two people in the car did not cause any wheel rub, all good. Punched the gas in second and the Mrs make a squeaky sound. All good.
Final details are going to have to wait till I get the challenge car on the road. I want to take two V8 Volvos to the show on the 29th
Pete
Samebutdifferent
7/12/19 7:34 a.m.
Awesome news!  yes
It's been a long time in coming and you've made it past all the major hurdles.  Hopefully only the fine tuning and tidying up are left to do.  This has been (and continues to be) a great build to watch and I have enjoyed every update.  Looking forward to the next set of pictures or video.  I think Mrs. nohome will be that much more motivated to learn to drive a clutch after an uneventful test run and a quick taste of what it will do.  Squeaky noises are a very good sign.  wink
AxeHealey
7/12/19 8:27 a.m.
Video evidence or it didn't happen!
maschinenbau
maschinenbau GRM+ Memberand SuperDork
7/12/19 8:29 a.m.
Yeah gonna need a burnout vid to prove it's driving
AngryCorvair
7/12/19 8:53 a.m.
without elevens, it's just another Disney moon landing.
NOHOME
NOHOME MegaDork
7/12/19 9:47 a.m.
Bit tricky to do the burnout since I live in a 40 kmh/hr hood with the school next door! But I will try to get some video ASAP.
The kinda good news is that the tires did NOT light up when I goosed the throttle in second. The thing just launches.
I am probably still another season away from being "Done", to where all the mechanical and cosmetic details are addressed, but hopefully the fun factor of driving it will be a motivator. Finding an AC guru to guide me through that bit ( or learning the hard way as I do) is the next big item.
In the short term, its just a case of getting some miles on the car and developing confidence that it will do return trips as a given.  Putting miles on the car will also allow me to make a better judgment of the Fitech.
pres589 (djronnebaum)
7/12/19 9:55 a.m.
How close is the interior sans any of the A/C work?
LPKb6aKbm4JdF6Jmq1PoK1KGnxvALAH30WOS6vekJ6UtACQtmHAcWqX4mZrx7ztq
