ClemSparks
ClemSparks PowerDork
4/29/13 9:27 p.m.
Mitchell wrote: I like the bed! Plan to add on the loops that allow 2" x 4"s slot into the sides?
No plans to add...
But...that's because they're already there!:
ClemSparks
4/29/13 9:29 p.m.
DoctorBlade wrote:
ClemSparks wrote:
DoctorBlade wrote:
ClemSparks wrote: uhhh...yeah. Last photo shows them. Though...I'd rather something a little less...uh...period correct. Hello McFly!
helps to out the glasses on, I suppose
Just to be clear...my "Hello McFly" comment was an allusion to the truck in "Back to the Future&quot...not directed to you, Doc.
I'm a geek, so that's what I thought you were referring to.
So...I'm gonna make like a tree and get outta here!
GameboyRMH GRM+ Memberand UltimaDork
4/30/13 10:53 a.m.
Nice, you gonna add wooden sides? I think it would look good. The truck looks much better with the body lift removed.
Also I had a wacky idea the other day you might like, but it's not that cheap because it requires a relocatable winch: winch-powered crane (swing arm with pulleys) on the bed near the cab. Could be useful if you often lift heavy stuff from the ground onto there.
ClemSparks
5/5/13 9:00 p.m.
So...here's what I'm up against with the wiring:
So...if anyone has a wiring diagram for a [roughly] '87 Toyota, I sure could use it!
Thanks,
Clem
ShadowSix
ShadowSix HalfDork
5/5/13 10:30 p.m.
I've got a couple .pdf's that might help, sent you a PM (I think).
ClemSparks
5/9/13 10:35 p.m.
No new photos today, but it now has a nice rebuilt caliper on the driver front, new brake pads, and the wheels are straightened out (directionals are directional, after all)
Clem
ClemSparks
5/9/13 10:37 p.m.
GameboyRMH wrote: Nice, you gonna add wooden sides? I think it would look good. The truck looks much better with the body lift removed. Also I had a wacky idea the other day you might like, but it's not that cheap because it requires a relocatable winch: winch-powered crane (swing arm with pulleys) on the bed near the cab. Could be useful if you often lift heavy stuff from the ground onto there.
I will probably make some sides at some point. I do like the crane idea. I could use it to lift heavy stuff up there to move around on my new property (it's got a trench full of trash I'll need to clean up, over time).
Clem
TAParker
TAParker New Reader
5/10/13 4:05 p.m.
That's gonna be sweeeeeet!!!!
zOSSidS269XvEZlYgrbCFfXPy7iaJf2VBxItny4AQtEIppJWLtJX7FiwQdF9vekI
