We admit that we sometimes
take our faithful 1978 MGB for
granted. After all, we’ve owned for
nearly three decades. It was time
to give it some attention, so we
dropped its ride height to bring it
closer to the original GT V8 specs.
We used a method that took just
an hour at each end: Moss Motors
lowering springs …
In my opinion, the only right way drop an RBB is to swap the x-member. Otherwise, I don't think you're really solving the problems.
NOHOME
UberDork
10/29/15 10:15 a.m.
For the rear, this is the answer:
It is affordable, bolts in and is height adjustable. MUCH better ride than stock. Validation of ride improvement is that wife would ride in car after the conversion while before it was a buckboard.
On the front, rather than do the front crossmember swap (harder than you think) I would go with a combination of drop spindle and slightly shorter spring.
MGBs with wide tires and ultra low stance look really great, but they are not at their best as far as the driving experience is concerned.
The ultimate would be to go with a front suspension from the same supplier as the rear 4 link:
Once again, a bolt in component that was designed to work with today's wheel/tire technology.
And just so y'all know that I amnot shilling for CCC, here is another front suspension alternative for those with a bit deeper pockets. Its from Fast Cars by Ted. Note the spify T-shirt in the picture.
In the back, fastcars prefers a 3 link approach that while far from "bolt in" is effective.
MGARuss
New Reader
1/3/24 11:50 a.m.
Looks like you are giving up an inch of ground clearance in the rear to the bottoms of the springs. Is that a noticable downside of this approach?
In reply to NOHOME :
@NOHOME - who's kit are you referring to in your post? Can you repost the pictures?. . . . they have since disappeared. Thank you.
