bmwjohn2
bmwjohn2
5/21/12 6:02 p.m.
elderly neighbor has 1969 bonneville wagon, i think large engine, bought 1971, rarely driven since, usually in concrete driveway. car was briefly stolen 3 years ago, some trim and muffler taken, now she can't find keys, surface rust minimal.thoughts as to value in midwest, finding trim? etc. Had been started in drive regularly for many years. Looks ok but oxidized from distance, Thoughts? comments? I think this is a frame car that might make a good tow car for a trailered GTO or similar.
5/22/12 9:44 a.m.
It is a frame car but I'm not sure about its tow capacity. Pictures would help a lot, but there were several engine choices; not all were big blocked.
Hard to believe a 6 cylinder would pull that thing around.
Lemme know if you pass on it.
Dan
From NADA:
Option note: Only select engines/options below that are in addition to standard equipment and equipment noted in the manufacturer or year notes shown above. Model names may show standard engine sizes in parenthesis such as "2 Door Sedan (440)"
350/265 HP V8 Engine
350/330 HP 4bbl V8 Engine
4 Speed Transmission
400/366 HP Ram Air V8 Engine
400/370 HP Ram Air V8 Engine
428 H.o./390 HP 4bbl V8 Engine
428/360 HP V8 Engine
428/375 HP 4bbl V8 Engine
6 Cylinder Engine
Air Conditioning
Bonneville Brougham Package
Firebird 400/330Hp (*)
Firebird 400/345Hp (**)
Firebird Sprint Models
Grand Prix SJ Package
Gto Vacuum Operated Exhst
Lemans Rally Package
Rally Wheels
Tempest Sprint Package
stuart in mn
stuart in mn UberDork
5/22/12 7:05 p.m.
The standard engine in a '69 Bonneville was a 428 cubic inch motor rated at 360hp. Front disk brakes were still an option that year but I wouldn't be surprised to find them on a Bonneville wagon. You can always retrofit them if this car doesn't have disks. They were big, strong cars with plenty of power, and it would make a fine tow car.
There's not a lot of reproduction stuff out there for full size Pontiacs but a couple sources are
Performance Years Pontiac: http://performanceyears.com/
Ames Performance: http://www.amesperf.com/
California Pontiac Restoration (CPR): http://www.pontiacparts.net/
For used parts try
Steve Barcak at Pontiac Heaven in Arizona, he has a huge all Pontiac salvage yard: http://www.pontiacheaven.org/
Also Steve Snyder at Indiana Pontiacs: http://www.indianapontiacs.com/
Finally, if you buy it the Pontiac owner's club is a good resource: http://www.poci.org/
bmwjohn2
bmwjohn2 New Reader
5/29/12 4:17 p.m.
well I did make 1 mistake. It is a 1970 and she says it is definitely a 455, the blue books don't show that in a 1969 but do in a 70. The scary thought is trim cost and rust, as I priced brakes, cooling, suspension, etc. and all seems reasonable except the American car curse of having multiple parts sources i.e. do you have the "deep hole" m/c or the anodized shallow hole, etc. Still thinking, thought was get mechanically good but not a full resto as I would lose $ on that, I think.
63tr4
63tr4 New Reader
5/30/12 5:53 p.m.
Darth Vader it and hit the highway !
Rupert
Rupert Reader
6/8/12 10:12 a.m.
Hey,
Go with it! I loved the '66 Catalina 2+2 I had! Of course it only had the small 421 H.O. motor but it still sucked a lot of gas through the Tri-Power carb setup. Maybe the 3.91 gears was part of that issue, but the wagon should suck up a bunch too.
Tim Suddard
Tim Suddard Publisher
6/24/12 7:56 a.m.
We love our old Edsel wagon and these cars are going up in value quickly, as people rediscover them. If that car is in decent shape it is a good investment.
pBtBu88xQPQS6SUa529j610NNDsNLKtR3GNVqF7FitnghQmwMBRasCCREgPZwLaK
