5/17/10 11:52 a.m.
I actually had a productive day with a car yesterday: changed the oil and transmission fluid, adjusted the clutch, and made the parking brake operational. Anyone else get their hands dirty?
André Rousseau
André Rousseau HalfDork
5/17/10 11:59 a.m.
Oh yeah... Now the garage smells proper.
Karl La Follette
Karl La Follette HalfDork
5/17/10 2:36 p.m.
We have worked out all the kinks in our outdoor lift friday and it is now operational . We put a nissan truck on it and gave it a greasing .
KaptKaos
KaptKaos Reader
5/17/10 6:31 p.m.
Got the cylinders and heads installed on the 914 motor! Going to double check the torque settings tonight. After that's done, in go the lifters, pushrod tubes and pushrods. I should have her in the car by the end of the month!!!
VClassics
VClassics Reader
5/17/10 7:05 p.m.
Dropped a monster B20 into a '73 Volvo 144 and put the transmission back in. This should be quite the sleeper
maseratiguy
maseratiguy New Reader
5/17/10 7:17 p.m.
Whats in the B20?
VClassics
VClassics Reader
5/18/10 10:20 a.m.
Nothing radical, just a street performance setup with an emphasis on a very wide torque curve rather than peak HP:
Custom Ross forged big-bore pistons (2174cc)
Total Seal rings
Stock rods shot-peened
Lightened flywheel
Rotating assembly balanced
HD oil pump
Custom Schneider cam
Isky lifters, pushrods, springs and retainers
Cloyes steel/aluminum timing gear set
Larger stainless intake and exhaust valves
Bronze guides
F head w/ lots of porting and chamber mods
Tighter piston-to-head clearance
10.0:1 compression
Upgraded front and rear main seals
SDS injection
Crank-triggered ignition w/ coil packs
Stock D-jet intake manifold
Stock exhaust manifold and dual head pipes
2.5" exhaust system
rconlon
rconlon HalfDork
5/18/10 11:19 a.m.
I filled the steering box and damper with oil and checked all systems. I then buffed up the paint for a trip to the vintage races but the weather turned sour and did not go.
Ron
Gary
Gary Reader
5/18/10 12:03 p.m.
Took a 3-day weekend mostly to do yard work. But I was able to get a couple hours garage-time in yesterday and started working on getting the new gas tank in my Spitfire. I'm cleaning, priming and re-spraying the area before I put the new tank in.
Joe Gearin
5/19/10 2:53 p.m.
Well, I installed a new gas expansion tank in the M3, and then proceeded to drive from Daytona to W. Georgia, then over to Charlestown SC and back up through Greenville. All told we covered about a thousand miles this weekend, and now my love for the BMW is rekindled!
gjz30075
gjz30075 Reader
5/19/10 4:12 p.m.
Changed out the lower 'A' arms on the Lotus to ones with adjustable heims so I can dial in the toe.
Onward now to my favorite alignment shop to verify my measurements.
5/19/10 6:23 p.m.
Joe Gearin wrote: Well, I installed a new gas expansion tank in the M3, and then proceeded to drive from Daytona to W. Georgia, then over to Charlestown SC and back up through Greenville. All told we covered about a thousand miles this weekend, and now my love for the BMW is rekindled!
Oh yeah, I thought I recognized a car out in the parking lot.
Tom Heath
Tom Heath Webmaster
5/19/10 7:29 p.m.
I worked on my not-so-classic (but awfully fun) Miata.
Click here for the rest of the story...
xUwCvuCsYbW8dBv26hIfi3Q92j3eti7hGmuNEmeOKi0QnuIM9CygDzaH9im0oODz
