Alan Cesar
Alan Cesar Associate Editor
6/13/12 2:58 p.m.
We keep blowing up our turn signal switch on the 1967 Shelby GT350 project. This problem is driving us bonkers.
http://classicmotorsports.net/project-cars/1967-Shelby-gt-350/mysterious-taillight-problem/
VClassics
VClassics Reader
6/14/12 10:29 a.m.
If it were me, I'd look into letting a relay or two carry the load, rather than the switch.
BoxheadTim
BoxheadTim GRM+ Memberand UberDork
6/14/12 12:39 p.m.
I agree with VClassics that some sort of relay or other type of electronic switch is probably a good idea.
However I'd also check basically every connection between the switch and the actual lights for corrosion or otherwise increased resistance. Given that W = V x A, if you don't get enough V the current draw would increase...
I assume that you have checked that the correct bulbs are fitted? Does the Shelby by any chance use lower wattage bulbs?
Karl La Follette
Karl La Follette SuperDork
6/14/12 2:56 p.m.
Sounds like a pinched wire somewhere
rconlon
rconlon HalfDork
6/15/12 10:07 a.m.
This must be refering to the column switch. I would take apart a switch or two. I bet the OEM is a better made unit with more robust contacts which I assume are failing under the load. LEDs or a relay should solve your problems. I would also not rule out a problem with the flasher relay or partial grounding in a front turn signal lamp housing.
Cheers Ron
Tim Suddard
Tim Suddard Publisher
6/18/12 10:20 a.m.
We couldn't find any wiring problems and the car does not have a tilt wheel. So far, the LED bulbs have solved the problem.
Thanks for the help.
omPDuiNBgjGG26ieSfyzMXV0Ho3ofTKT1nnKQhe7L8jHQRblq2RSsb7Z7RQiQe8S
