My brother has a 05 Forister and has a mysterious over heating problem. I asked him to write it up in detail so I can ask the Subru Gurus here. I am going to do a compression test (special high tech one that shows the whole cycle not just max compression) this week and see if it reveals anything.
Any and all sugestions are greatly apreciated.
I was thinking of doing another leakdown test with the motor hot. And of pressurizing the coolant system with the plugs out and leaving it for a while. This is sort of last resort testing at the moment.
What about a clogged cat?
Your thaughts insite is greatly apreciated!!!
My Brother said: Subaru Forester 2005, no-frills model... directly off the lot. Currently had 92K miles. Last year, around this time: Driving down interstate-93 on a fairly hot day (>90 degrees) with my wife in the car. We were going around... 70-75mph or so. I don't normally have AC on, but did for her. After about... 20 minutes of driving the temp started to go up. Not quickly, but consistently. Got to about 2/3 the way up. I pulled off, turned the engine off (left power on so the fans were going) and checked the fluids. They had reasonable amounts and colors (I didn't check the radiator, only the overflow, for obvious reasons.) A nice worker for the highway department let me out an emergency ramp and directed me to a much smaller and slower road. I drove all the way home never breaking... 40mph. Watched the temp like a hawk and it was fine. Took it to my independent mechanic and he couldn't reproduce the problem and didn't find anything wrong. Took it to the dealer I purchased it from and they couldn't reproduce it or find anything wrong. One of them might have flushed the radiator, I don't recall. No "serious work" done. Car worked fine for almost a year, including a 6+ hour interstate-highway drive on vacation across 4 states a few months later. Fast forward about a month ago.... the story starts the same: Driving down interstate-93 on a fairly hot day (~90 degrees) with my wife in the car. We were going around... 70-75mph or so. I don't normally have AC on, but did for her. After about... 20 minutes of driving the temp started to go up. Not quickly, but consistently. Got to about 2/3 the way up. This time I experimented more. I turned off the AC, slowed the car down to around ~55mph and the temp went down a bit but didn't go all the way down. I sped up a bit and it went back up and didn't go down very well. I turned on the heat full blast, opened the window and slowed down as much as I dared on that highway (50?). The temp did go down. Got off at the next exit and went home on a smaller "Route" at 40-50mph, watching the temp gauge. Heat not always on. It was fine. When I got to I-95, I got on that and kept the speed at 55 and was fine. I then experimented again and sped up (without AC) to... maybe 60-65 and the problem came back (definitely lower than my speeds when the problem started.) It didn't go down the way I liked when I slowed down so I turned the heat back on and rolled down the windows. Got home fine. No surprise, I couldn't reproduce the problem leaving it running in the driveway with the AC on full blast. Took it to my mechanic again. He couldn't find the problem but his research showed it as similar to: - Water pump starting to fail, so either doesn't work as well as it could or doesn't always work. - Head Gasket. But this has other signs that weren't there, like anti-freeze in oil and oil in anti-freeze. They both looked fine. So he offered to replace the water pump (something you'd probably just do within the next 10K anyways.) While there he did the belts and the thermostat. I also had him do a leak-down test which showed no problems. I had heard a noise when turning left and he found the front ball joins (?) were going, so I had him do those at the same time. I wanted to keep the car, after all. The car had worked fine since then... until today. But today the story is different. I was going down I-95 (no wife in the car - she isn't bad luck) at around 70mph, NO AC going. It was on defrost/vents (not full-defrost) for what it's worth (does that use the compressor?) Temp set to fairly low, fan on. The temp started to rise. I didn't wait until it got to 2/3 from the top. I changed directions and just went home. At one point it did start going up again, so I got off the phone (calling the people I was visiting to say I wouldn't make it) and turned on the heat full blast. Had I sped up too much? I don't think so, but I was slightly distracted by the phone. Either way, that helped and the temp went back down. The car made it back just fine. At this point I don't think I can take it back to my mechanic, so I'm going to call the dealer and see what they can figure out. Any ideas? I would like to get the car fixed... I had hoped for another 100K at least on this car. But at this point, I don't trust it... and I can't keep a car that I don't trust to drive around. Oh, another point that might matter. When I purchased the car the temp normally ran at a little bit over 1/3 on the temp gauge. About 40-50K of having the car it started to run higher... a bit under 1/2 way. My mechanic said the temp looked fine (within operating spec of the car) when he read it via codes so said I shouldn't worry. It's been that way for awhile and seems fine. --------------------- Eric
