AutoXR
AutoXR Reader
7/26/10 9:13 a.m.
got quite a lot done on my $2010 Chellenge entry over the weekend. The car is a 92 civic EG with Koni's from an EF and 13" wheels.
The problem I am having is this. The geometry is completley out of wack on the front end. The A-Arm is on a 45 degree up ward angle and the axle on the pass side has such a massive angle it's pulling out
I thought the solution would be to swap in EG front koni's , I found a guy willing to trade my EF's for his EG yellows, but have discovered they are actually a shorter body.
I have 7" front GC sprints and extended strut hats.
DILYSI Dave
DILYSI Dave SuperDork
7/26/10 9:39 a.m.
First, the diameter of the wheels is not the source of any wonkyness.
Second, can you take some pics?
Finally, IIRC, EF and EG shocks can be swapped, but you need the fork that goes with the shock.
AutoXR
AutoXR Reader
7/26/10 9:42 a.m.
No pics til friday as I work on the car in my dads shop 3 hrs away. I am using EF forks.. no way this can be right!
CwGTorkjOzedZtFjeryDjisLTbbEPDup0oCaJPmyf5oqi2D7ptlAGDK2E6ofrqpN
