SyntheticBlinkerFluid
3/27/14 10:58 a.m.
So I replace the front right wheel bearing on the Durango last night and I realized I didn't know that the torque specs for the axle nut, so I decided to look it up online. The first place I found said 180 ft-lbs, so I decided to double check on the Dodge Forum and yep, 180 ft-lbs. WOW! That's a lot.
So went to set my torque wrench and realized it only goes to 150 ft-lbs.
150 it is!
turboswede
turboswede GRM+ Memberand UltimaDork
3/27/14 11:07 a.m.
Get a bigger torque wrench.
Mezzanine
Mezzanine Reader
3/27/14 11:19 a.m.
Yeah, I just torqued axle nuts on my SAAB this weekend. They were something like 220 ft-lbs. Luckily for me, I had inherited my granddad's large torque wrenches including a 3/4" drive model. Thanks Granddad!
3/27/14 11:35 a.m.
turboswede wrote: Get a bigger torque wrench.
At some point, don't really have the money for tools right now.
Knurled
3/27/14 11:35 a.m.
Wait till you see a VW with 16mm thread bolt. It's like 150ft-lb plus 180 degrees or something equally silly.
oldopelguy
oldopelguy SuperDork
3/27/14 11:39 a.m.
Sounds like a 240# guy standing on a 9" wrench to me...
Will
Will SuperDork
3/27/14 11:41 a.m.
250 lb-ft for the axle nuts on my Supercoupe.
Mitchell
Mitchell UltraDork
3/27/14 11:49 a.m.
3/4" torque wrench from harbor freight, with a 25% off coupon. I have had to use mine quite a lot lately; frame bolts and lower control arms had bolts far exceeding the capabilities of my 3/8" wrench, and I Donny have any 1/2" tools (though I have started to get loose sockets in 1/2", so that I can use them with either of the sets that I have).
I read a lot of warnings that over/under torquing the axle nut could significantly reduce bearing life.
Tom_Spangler
Tom_Spangler GRM+ Memberand Dork
3/27/14 11:53 a.m.
SyntheticBlinkerFluid wrote: 150 it is!
Or at least 150 plus an extra quarter turn or something. But yeah, best way is to get a bigger torque wrench.
tpwalsh
tpwalsh Reader
3/27/14 12:00 p.m.
Yep, stand 1 foot from the socket. BOOM! 180ft-lbs. (adjust length depending on weight)
turboswede
3/27/14 12:04 p.m.
When will you have the money to do it right because you'll be doing it again? I've heard rumors of issues with Durango's and front wheel bearings, so I don't think I'd screw with it personally.
Knurled
3/27/14 12:09 p.m.
They don't fail any more or less often than other vehicles of its size. Burp it on with an impact gun and call it good.
Now, the upper ball joints, THOSE do fail disturbingly fast on Durangos and Dakotas.
yamaha
yamaha UltimaDork
3/27/14 12:17 p.m.
150lbs + 45 degrees should do it.
Vigo
Vigo PowerDork
3/27/14 5:50 p.m.
All those numbers sound like "impact" to me. But what do i know!
Ian F
Ian F UltimaDork
3/27/14 5:55 p.m.
DING!
This is normal. I have a 3/4" drive torque wrench from H-F for doing these. Goes up to 250 ft lbs.
patgizz
patgizz GRM+ Memberand PowerDork
3/27/14 5:58 p.m.
Vigo wrote: All those numbers sound like "impact" to me. But what do i know!
winner.
Ranger50
Ranger50 PowerDork
3/27/14 6:00 p.m.
Those are German spec.... Gutentight!
ncjay
ncjay HalfDork
3/27/14 6:03 p.m.
You may not have one nearby, but Advance and Auto Zone have tools you can borrow. Not sure about a torque wrench that goes to 250, but it may be worth a look.
dean1484
dean1484 GRM+ Memberand PowerDork
3/27/14 9:15 p.m.
I know that improper torque on tge hubs on my expedishion shortens the hub life quite a bit.
3/27/14 9:32 p.m.
Well E36 M3, I see a trip to Harbor Freight in the near future
RexSeven
RexSeven UberDork
3/27/14 9:36 p.m.
The flywheel on an FC RX-7 has to be torqued down to 350ft-lb! You need one of these to make sure it can be torqued down or removed properly.
http://www.racingbeat.com/RX7-1986-1992/Flywheels/22000.html
Tom_Spangler
3/27/14 9:54 p.m.
RexSeven wrote: The flywheel on an FC RX-7 has to be torqued down to 350ft-lb! You need one of these to make sure it can be torqued down or removed properly. http://www.racingbeat.com/RX7-1986-1992/Flywheels/22000.html
I still have mine! Bought it 15 years ago during my FB days. I don't know why I keep it, I'll certainly never own another engine with cursed spinning triangles. Unless I'm removing it to put a real engine in.
Knurled
3/27/14 10:05 p.m.
I just use good ol' 2135Ti to remove, then when installing, torque to 150ft-lb, mark the flywheel at one of the nut's points, mark the nut at the point directly counterclockwise from that, then invite Mr. 2135Ti back over to play connect-the-dots. Never an issue.
RexSeven
RexSeven UberDork
3/27/14 10:19 p.m.
If you're willing to sell then there's plenty of us triangle voodoo practitioners that could use it.
Ian F
Ian F UltimaDork
3/28/14 4:43 a.m.
Knurled wrote: I just use good ol' 2135Ti to remove, then when installing, torque to 150ft-lb, mark the flywheel at one of the nut's points, mark the nut at the point directly counterclockwise from that, then invite Mr. 2135Ti back over to play connect-the-dots. Never an issue.
Not a great idea on single-use locking axle nuts...
mefTRFC17EnWAw88ZFPocqgdwb84uuQi47EW5b4Bz9Sh1F0doA6rELyDEUhB1rFV
