mthomson22
mthomson22 New Reader
5/22/11 8:48 a.m.
I just picked up 84 e30 318i. I know I'll never make monster power out of the M10, heck not even modest power. I intend to autocross and trackday it and am fishing for suggestions on how to make the most out the platform I have to work with. Preliminary thoughts are header and exhaust, cold air intake, shock/spring upgrade, some light 15" wheels, and new rotors/pads on the front.
I'm open to any insight as this is a different animal than my current 91 Miata.
I should point out that the 318 is an automatic also.
thanks, mark
SlickDizzy
SlickDizzy GRM+ Memberand SuperDork
5/22/11 9:25 a.m.
Beware of the transmission; they are NOT robust and tend to fail quickly under stress. You will probably lose power with a header and exhaust due to the backpressure drop, unless you get a nasty cam for it and port the head. CAI will do nothing but make a cool "whoosh" sound. The ONLY way to get power out of the M10 is a serious cam and head job, or FI. Suspension-wise, it is an E30, how far you want to go solely depends on the size of your wallet.
A buddy of mine in high school had one of these with a 5-speed. It was remarkably slow. You already have the Miata, why this? If automatic is a must, I'd try to find something that will hold up better to track duty. The ancient 3-speed mated to an 80-some HP engine that needs to be revved to go anywhere is a pretty bad combo.
Luke
Luke SuperDork
5/22/11 9:48 a.m.
Was fuel injection not the norm for US 318i's?
I test-drove a 318i manual, once. It was obviously underpowered, but peppy enough. Lots of gear shifting required to keep the engine on the boil. So, I'd be looking at a manual swap, if anything.
SlickDizzy
5/22/11 9:50 a.m.
Luke wrote: Was fuel injection not the norm for US 318i's? I test-drove a 318i manual, once. It was obviously underpowered, but peppy enough. Lots of gear shifting required to keep the engine on the boil. So, I'd be looking at a manual swap, if anything.
I meant Forced Induction, not Fuel Injection.
WilberM3
WilberM3 HalfDork
5/22/11 9:56 a.m.
you could swap a later 24-valve M50/M52 engine with its likely stronger transmission for both more power and presumably more durable, but to be honest i dont know exactly how strong either stock trans is.
the nice thing is that an 84 318 is the lightest e30 built.
any e30 will respond nicely to the mods youve listed, but i'd also carefully inspect the rear brake hard lines as by now they may really need replacing, along with rear subframe bushings and possibly fuel tank. i'd add SS braided brake hoses to the list too.
are there any shift kits available for german automatics? i dont recall if a 318 has a trans cooler, but i'd see about adding one if it doesnt.
SlickDizzy
5/22/11 10:05 a.m.
Okay, I just found your other thread and can offer a few suggestions...
These websites are going to be your friend for race parts: Ireland Engineering Turner Motorsport Pelican Parts
Any BMW owner needs this site bookmarked for the awesome diagrams and part # cross-referencing: Real OEM BMW
If $5k is your budget, you have some room to play. Try to find a later M40 (16v I4) or M50 (24v I6) engine with the later 4-speed auto attached. Like Wilber, I have no idea if it will be any stronger, but at least you'd get an extra gear. Either way, add a heavy duty trans cooler, and put some Redline synthetic fluid in it right away, and it might go the distance for you. I don't know of any shift kits available out there, but they could exist.
Do all the suspension bushings (pick your favorite material, it's out there for the E30), then drive it and tune from there. As said above, SS lines are always a good investment. Maybe convert to rear disc brakes? I would do wheels and tires before any other suspension stuff, E30's are pretty tossable and neutral from the factory when everything is fresh.
If you really want to stick with the M10, or just have a boner for the "old-school way" like I do (I'm currently building an antiquated Subaru EA82 to period WRC spec with a bunch of rare low-production parts) there is power to be had, but it won't be cheap. Look into Schrick cams, and send the head off for a major work-over. Get some 9.5:1 compression pistons, then slap it together and make the next big decision - you could run carbs, ITBs, or even standalone EFI at this point. THEN a header, full exhaust, and good intake will make a hell of a difference. It will sound totally awesome too. This setup will net you somewhere around 170HP, and be period correct. Not your only option, but certainly one way to go.
Good luck with the project, now that I've seen your other thread everything makes a lot more sense to me.
Joshua
Joshua Reader
5/22/11 11:00 a.m.
The 'i' on BMW's means fuel injection.
One of the BMW magazines did an article a few years ago on the 318, it's supposed to be very easy to turbo and make decent power. I think the magazine was Performance BMW but I could be wrong.
mthomson22
5/22/11 11:12 a.m.
Thank you Slick, that's exactly the type of info I'm looking for!!! I do like old school, and for whatever bizarre reason do love small underpowered cars...maybe my inner John Morton shining through
I'm pretty excited about tinkering with this, and trying a track day after some initial messing about with it.
The carb/itb route sounds interesting but for now I'll stick with the injection until motor rebuild time.
For now I'll concentrate on adding lightness and handling.
Any specific exhaust recommendations? I like reasonably loud
mark
SlickDizzy
5/22/11 11:26 a.m.
I don't think anyone makes an aftermarket exhaust for the M10 318. There are options for the M40 318 that MAY fit, but that's a crapshoot. If you want to see some performance increase right away, I would get the Schrick 284 cam and match that with a header (I think Ireland has them, Schrick used to make really nice ones but they are rare) and a custom 2.5" exhaust (find someone locally that can do mandrel bending). Even with the stock fuel injection and low compression pistons, this should bump you over 100HP and give you a much better soundtrack.
If you do some searching around the good BMW forums (E30tech, r3vlimited, Bimmerforums, Pelican) for "M10 performance" or "M10 upgrades" etc etc you will find everything from mild bolt-on builds to near F1-spec 800HP turbo monsters. The M10 has been around since man discovered fire, and there are newer, cheaper ways to go fast, but due to its history there is a lot of good info out there if you look for it.
z31maniac
z31maniac SuperDork
5/22/11 11:48 a.m.
You'll want to convert to a later style rear trailing arm with disc brakes on the rear, and get newer strut housings as well as they are larger, and have many more suspension options.
carzan
carzan HalfDork
5/22/11 11:53 a.m.
The M10 is good for 400+ HP when properly boosted. The autotragic ain't gonna handle it, though..
http://cgi.ebay.com/ebaymotors/BMW-M10-Stainless-Turbo-Header-Manifold-T3-BMW-2002-_W0QQcmdZViewItemQQhashZitem5198cad307QQitemZ350455780103QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
Just sayin'
carzan
carzan HalfDork
5/22/11 12:06 p.m.
Also:
http://home.mchsi.com/~jroal/
Click on "Cars" button on the top left. Then click on "1984 BMW 318i Turbo" on the bottom right. Good info with before and after videos.
Have fun!
BoxheadTim
BoxheadTim GRM+ Memberand SuperDork
5/22/11 12:30 p.m.
First thing I'd check is the state of the cam, at least in Europe the 318 has a reputation for wearing cams if the oil change intervals have been stretched out a little too far.
jsncarrier
jsncarrier
4/8/14 12:36 a.m.
I have a 85 318I m10
What I know about the car. Distributor sucks balls. I advance mine pretty far, but you have to smog it quick and cold in california. Head always runs hot and oxidizes too high nox, even with factory timing and fuel mixture. if you can financially replace the diZy with a digital system that can be tuned well, do it. Save the hassle of it deteriorating and blowing through caps and rotors.
Remove the airbox, short ram the intake, set a box up to keep the warm engine air out. This is a minimal gain, but a good first step. Performance is all about moving air quick. Also the box is heavy.. so weight is still the enemy, even with the lightest e30.
I replaced my muffler with a glass pack, also widened the piping slightly from the cat back at my local muffler shop. Its still quiet but doesnt sound like a volks wagon, its also a lot lighter.
Ive heard headers might not help because a reduce in back pressure, but as far as I know, hp is a function of how fast your engine moves air. As long as you can meter the correct amount of air and supply the corect fuel mixture, its a relative gain to cfm
yamaha
yamaha UltimaDork
4/8/14 9:48 a.m.
Joshua wrote: The 'i' on BMW's means fuel injection. One of the BMW magazines did an article a few years ago on the 318, it's supposed to be very easy to turbo and make decent power. I think the magazine was Performance BMW but I could be wrong.
I don't think so...it seems much more irratic/hit or miss than that.
The M10 with an auto would be terrifying slow, don't worry about adding any power and just focus on weight/handling. Those will help(and be alot easier) more than extracting power.
OldGray320i
OldGray320i Reader
4/8/14 12:57 p.m.
While mine is a 320i, the motor is the same, but I think the only differences are injection is mechanical vs EFI, and I think the e30 M10s had cast iron vs. steel cranks.
Ditch the water pump driven fan (though I know the e30's had the fan clutch, so might not feel like quite the increase on the e21), look up the ignition recipe on bimmerforums in the e21 section - better plug wires, plugs, hotter coil - and an exhaust. I ran a 2-1/8 mandrel bend exhaust with the stock exhaust manifold (wish I'd done 2-1/4), but I think 2-1/2 on that car would be too big. I found the header, even with the mild upgrades, wasn't quite as strong. All of that really woke the car up, even though it was still just slow.
Since the car runs L-jet, as I recall, you can take the cover off the air flow metere and play with the mixture set up a little. I used to do this on my 280z's, and with a few upgrades on those, it helped a little bit.
As far as I know, the distributor for these cars has the same ignition curve as the old "performance" ti or tii distributors, so it shouldn't be that bad, but I would hazard a guess that anything modern would be a significant improvement.
And for goodness sakes, swap a 5sp in that car!
Oh, and as far as turbo, there was an e30 318 guy on the e21 forum that had dyno'd 360hp on a 2.0 M10. Lots of boost. He blew up the motor trying to hit 400hp.
2002maniac
2002maniac HalfDork
4/8/14 1:23 p.m.
If you really want to get serious you can take the motor out to ~2.3L with an S14 crank and 95mm bore.
I had a 2002 with 11:1 pistons, a schrick 304 cam, and dual 45mm DCOE webers. That car SCREAMED!
But seriously, 5-speed swap it before you do anything else.
hXfVSeODZDEfZKRqwSVu39qtJBapEdFNLDrWVTFaAE7FyfomcKidaFZ3x4bSKV1e
